View Full Version : Tach Wire
soros151
10-12-2006, 06:31 PM
I have an aftermarket tach lying around, and thought of using it just for the shift light it has in it. I was wondering exactly where to tap for the tach signal. The tach has 4 wires,
Red, Black Green, and Yellow. I know where the red and black goes to, but where does the green and yellow go. and where is tha tach signal wire? Photos would help a LOT. Thanks in adavance guys, and yes I do go every week to the strip and yes I do need the Shift Light.
soros151
10-13-2006, 11:23 AM
bump...
Borisimo
10-13-2006, 12:07 PM
Maybe this thread will help: http://www.scionlife.com/forums/viewtopic.php?t=130218
soros151
10-13-2006, 12:10 PM
Tach- Black wire data link conn. under dash, pin 9 or the tach wire is also found at the ECM behind the glove box, top plug, pin 5.
and this is what? I don't get it. That's why I made this post, cause I couldn't understand this.[/quote]
ProshopXB
10-13-2006, 12:19 PM
soros151 do you know where your OBD2 scanner plug under the drivers side dash is? If you pop your head under the dash you will find a little black plug... Look for a black wire on it.
or
You can pull your glovebox out and behind it will expose the factrory ECU on the right hand side. On the very top plug is the RPM wire... see the link below and where it says "I" that is the RPM wire.
http://www.zeropointindustries.net/images/greddy-em-ult-web.gif
soros151
10-13-2006, 04:03 PM
At last, a very specific answer. Thanks!
soros151
10-15-2006, 02:38 AM
Okay, tried looking for either the black box, or the black wire, but no luck there, so I took some pics to see if someone can pinpoint the exact location or at least a nearby place where I could find that wire. So...
http://i47.photobucket.com/albums/f192/soros151/DSC03041.jpg
http://i47.photobucket.com/albums/f192/soros151/DSC03044.jpg
http://i47.photobucket.com/albums/f192/soros151/DSC03042.jpg
http://i47.photobucket.com/albums/f192/soros151/DSC03049.jpg
Here is an upside down pic of the ECU without removing the glovebox compartment.
http://i47.photobucket.com/albums/f192/soros151/DSC03053.jpg
and can someone plase tell WTF is this? :P
http://i47.photobucket.com/albums/f192/soros151/DSC03054.jpg
ProshopXB
10-15-2006, 02:43 AM
The white plug in the first pic, below the fuses is the OBD 2 plug... In the pic of the ECU it is the farthest plug away or all the way to the right in it.. refer to the diagram I posted above and look for pin labled as "I"..
soros151
10-15-2006, 02:46 AM
Do I have to open the OBD2 plug?
ProshopXB
10-15-2006, 02:49 AM
There are 2 clips on either side of the plug..that you can push in and it will slide out of the metal bracket that holds it.. then look for the black wire, tap into it by some means and you should be good to go..
soros151
10-15-2006, 02:50 AM
Thanks.
ProshopXB
10-15-2006, 02:52 AM
Thanks.
No prob..let me know if you have any more questions..
soros151
10-15-2006, 02:53 AM
I will.
Tboneterenzi
12-30-2006, 05:54 PM
hey proshop is this the same for the xb, i am in the middle or installing a shift light, and i am lookin for the wire. thanks.
imsonofagun
12-30-2006, 08:50 PM
http://trdsparks.com/install/00602-83400-005inst.pdf
pages 20-28 for the xB. The xA and tC are also listed in there in the pages prior.
Tboneterenzi
12-31-2006, 05:33 AM
thanks i didnt get the trd one, i got the proform one....
http://www.streetperformance.com/ART/PRODUCTS/100719/67005c.jpg
I finaly got it installed and it is soo nice. i just tryed all the different wires in the plug under the fues bot, and i found the one. now i can crank the music, and not have to forget to shift and over rev. But the light is sooo bright, i need to leave the cover on.
soros151
12-31-2006, 05:35 AM
I got a similar one. Nice.
imsonofagun
12-31-2006, 05:42 AM
I don't have the TRD shift light either, but the tach wire listed in the TRD installation guide is the same tach wire used to attach any shift light. Can be used to attach any aftermarket shift gauge too. I used that install guide for my shift light which made it a simple job, no guessing or anything.
06SuperWhite_SoCal_tC
01-02-2007, 03:44 AM
Does anybody know where to tap in to make my boost gauge's light come on with my dash lights???
soros151
01-02-2007, 05:01 AM
any 12V source
Matt_Burgess
01-02-2007, 05:17 AM
Would this tach wire work for a msd window switch ?
imsonofagun
01-02-2007, 05:30 AM
I don't see why it wouldn't work, but just to make sure, ask at:
http://msdignition.com/forum/index.php
blitztc06
03-16-2007, 01:37 PM
did anyone else order a shift light and its like 6" long and wont lay on the steering column without hitting the wheel when u turn....any other location ideas? I was thinking of mounting to right knee plastic thing, because its on an angle and i will still see the flashing light....
blitztc06
03-16-2007, 02:56 PM
Based on wat ive read from the PDF intructions the tach wire can easily connected at the gauges instead of pulling out the OBD II connector and laying on ur back trying to solder when u can just take out one screw above the gauges and pop out the connector and tap into the PIN 26....please let me know if this sounds right, il try it anyway later today after work if i get no reply....with pics lol! :clap:
imsonofagun
03-17-2007, 02:58 AM
I have my shift light connected to the tach wire in the gauge cluster. Easy and works.
soros151
03-17-2007, 03:20 AM
There is nothing easier than the OBDII connection. :rofl: Black wire in the right side. :lol:
blitztc06
03-17-2007, 03:53 AM
No way it took me under 5 minutes to install, check it out....i did a custom mounting which worked out great, just thought of it on the spot (im the first),i just took off the bracket that comes built in and ran the wires through the vent opening slot and made a tight fit so it didnt move around, so much easier because the wires only were 8 inches long so the connector was right next to it (no patch wires)http://memimage.cardomain.net/member_images/11/web/2387000-2387999/2387102_122_full.jpg
http://memimage.cardomain.net/member_images/11/web/2387000-2387999/2387102_123_full.jpg
soros151
03-17-2007, 04:41 AM
I have that same one, but it didn't work for me. Is it the adjustable one?
blitztc06
03-20-2007, 08:02 PM
yes it is adjustable right in the back by 500rmp increments, just a dial in the back. $32 on ebay
soros151
03-20-2007, 08:20 PM
Couldn't get mine to work.... no worries :D
blitztc06
03-20-2007, 08:25 PM
how many wires did you have? because i know most have 5(3 regular, 2 closed loop), you have to cut the 2 looped ones for your 4 cylinder, and then 1 accessory(gauge cluster), 1 ground(bare metal), 1 tach wire(to gauge cluster)
