If I were to up the boost
Old Oct 13, 2006 | 02:39 PM
dachmo's Avatar
Default If I were to up the boost
If I were to up my S/C pully from 9.5 psi (I only see about 8.5) to about 10psi (IceNine had a 12psi pully and sees 10psi), would I be ok with only getting bigger injectors? 550cc? or would I definately need fuel management?
I know IceNine said he was leaning out at 5500 with 10psi and the stock TRD injectors.
I'm not sure of what the TRD Reflash is capable of.
I would definately get a wideband O2 to monitor, but would I need an ECU?
- Dante
Old Oct 13, 2006 | 04:37 PM
soros151's Avatar
It would be highly recommended when changing the injectors.
Old Oct 13, 2006 | 05:58 PM
BuddhasTC's Avatar
^^agreed...you don't necessarily need it per say, but it would be a good idea
Old Oct 13, 2006 | 06:57 PM
tc2nut4's Avatar
If your car lives at redline you can kiss your motor good bye without injectors. If it doesn't you'll get a few thousand miles out of it (could be 1k could be 30k) either way its not worth 3k in parts and labor for a $400 part you can buy now
Old Oct 13, 2006 | 08:52 PM
tikbhoy's Avatar
whatever you do, tuning is the key. just because you bolt on parts doesnt mean it all works together, some may actually hurt your car.
dont take the easy cheap way.
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
brett561tc
Sep 15, 2015 06:33 AM
