Center bore?
Old Oct 16, 2006 | 11:04 PM
SteevieO's Avatar
Default Center bore?
I found a good deal on some 15x6.5, 4x100, 38 offset rims. I don't understand center bore. They are 73 mm. Will that work?
Also if I wanted a little wider tire to go on the 6.5, what size should I go to?
Old Oct 17, 2006 | 02:41 AM
moonray's Avatar
Default Re: Center bore?
Yep. Just get some hubcentric rings to help center the wheel on the hub assemblies.
Old Nov 17, 2006 | 03:48 AM
CozShnoz's Avatar
Default Sorry to bump, but...
I might buy some 17's from my dad that have a center bore of 72.6 and I understand the xB's is 54.1, so where do I go from there? Are the hubcentric rings necessary? Do you have to have them made specially for your own application? Is there a place you know of to get them? What exactly are they? Does anybody have a pic of them?
Also, the rims are 17x7 with an offset of +42... Does anyone know if that will cause any issues? Sorry for being a n00b, but all my wheel/tire knowledge is directly related to Subaru applications...
Thank you,
Dewey :D
Old Nov 17, 2006 | 04:20 AM
06B0X's Avatar
I just purchased some rings for $14 shipped
Check e-bay item 180050427302
Those are the ones you'd want to get. I haven't installed mine yet but intend to very soon.
Old Nov 17, 2006 | 04:26 AM
CozShnoz's Avatar
Cool, let me know how that works... and maybe post some pics?
Thanks!
Dewey :D
Old Nov 20, 2006 | 08:43 PM
INTENSE_POWER's Avatar
you can pick upi hubcentric rings at most local wheel shops as well.
it helps center your wheel to the hub when installing. It is something that is Def. recommended. and you don't have to worry about your wheels being off center. wobbling at high speeds and makeing your tires wear unevenly
Old Nov 20, 2006 | 10:00 PM
CozShnoz's Avatar
Thanks for the info. everybody!! Sorry I forgot to post an update, but I just ordered them from our local tire store and they'll be here by next Monday. :D
kb1sxv
Oct 21, 2015 05:00 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
