Apex Specific Prob?
Old Oct 17, 2006 | 04:36 AM
soros151's Avatar
Default Apex Specific Prob?
Hi, I just wanted to know the exact problem of why the Apex hasn't been succesfully used on the tC. I have read the other threads, but no specific answer yet.
Old Oct 17, 2006 | 05:32 AM
WeDriveScions's Avatar
FairladyZ541 is the guy who worked with a shop to get it running... he's the guy to go to about it for sure.
Old Oct 17, 2006 | 01:58 PM
deathbyc4's Avatar
you talking about the safc-ii?? why doesnt it work on the tC? Works on mine.
Old Oct 17, 2006 | 04:52 PM
soros151's Avatar
If it does work on your tC, did you set it up all the way from 1000RPM? or from 4000RPM and upward?
Old Oct 19, 2006 | 03:24 AM
tCyoung1's Avatar
they have a nasty habit of setting off CEL's if tuned before 4000 RPM. but Sound Performance found a way for it to work with their turbo kit. too bad they won't tell us how
Old Oct 19, 2006 | 04:09 AM
soros151's Avatar
I believe they used a retunr fuel, but somehow fairlady is not using a return line an he has tune from 500RPM and upward.
Old May 19, 2007 | 12:04 PM
2azfeboost's Avatar
So if tuned above 4000rpms, no cel? Cause I have a cel and mine is tuned below 4000rpms
Old May 19, 2007 | 06:59 PM
soros151's Avatar
Supposedly
Old May 19, 2007 | 09:10 PM
jjos1's Avatar
From my understanding you can only use the safc 2 to tune open loop (4k) and above, on closed loop the ecu learns that somthing is altering it and then throws a cel. So the only way I can think of tuning using a safc 2 is with a Dezod black box for closed loop and the safc 2 for open loop.
Old May 20, 2007 | 12:38 AM
2azfeboost's Avatar
Ok I set the neo for 4000 and above in 500rpm increments, then I reset the ecu by removing the negative of the battery, and for a while it was fine. Eventually, the cel came back on. Any ideas?
And why does my car bucks back and forth???
Old May 20, 2007 | 01:51 AM
alkamistpapi's Avatar
does the neo have the same wiring as the safc II
Old May 20, 2007 | 03:47 AM
2azfeboost's Avatar
Yes I believe so
Old May 20, 2007 | 06:35 AM
soros151's Avatar
Disconnect the main O2 sensor from the header, and use a bolt for the space. The car will stay in open loop nno matter what, and still be driveable. Tune the apex, and have no problems then.
Old May 20, 2007 | 01:35 PM
2azfeboost's Avatar
Do you mean the 02 sensor viewable in the engine bay? Or near the spipe?
I never heard of doing this is it safe? And will my car be damaged due to the cel the neo is causing?
So put a bolt on the 02 sensor and the cel wil go away?
Old May 20, 2007 | 07:48 PM
soros151's Avatar
There is a thread in here in SL, about the procedure. I have never tried it. U can search for it somewhere in the tC forums. But seems simple enough. It is the one visible in the engine bay.
Old May 21, 2007 | 05:13 AM
2azfeboost's Avatar
Ok well ill get it checked at autozone. Is it possible the cel is not harmful to my engine?
Old May 21, 2007 | 10:21 AM
soros151's Avatar
I'm telling u, look for the thread. I'm pretty sure, that it's not harmful, but I'm not responsible for anything.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Denzel
Oct 14, 2015 10:15 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Andreas24
Sep 15, 2015 02:10 PM
umnitza
Sep 1, 2015 08:06 PM
