Quick question...Do S-pipes throw a CEL?
Old Oct 18, 2006 | 04:24 AM
mpbrown's Avatar
Default Quick question...Do S-pipes throw a CEL?
Like the title, will an spipe throw a cel? it doesnt seem like the stock pipe has a cat on it but i thought it did. So flame as needed, I just need an answer.
and i did search for it guys
Old Oct 18, 2006 | 04:34 AM
-NEMESIS-'s Avatar
no.
Old Oct 18, 2006 | 04:36 AM
TimmyT's Avatar
Scion Society
Yes... The o2 sensor connects to the down pipe. So if you don't have the o2 sensor installed correctly or an antifouler. You will throw a check engine light.
Old Oct 18, 2006 | 04:38 AM
O5_TRD_tC's Avatar
i would say no too, if u do throw a CEL its b/c u broke the sensor.
Old Oct 18, 2006 | 04:43 AM
mpbrown's Avatar
ok only those who have it installed should answer. Thanks Nemesis
Old Oct 18, 2006 | 04:44 AM
przemko's Avatar
i have an invidia spipe and i was driving with it for a while ( no cel ),and after i've put the header the cel showed up.. the problem with invidia spipe is that there is no room to put the antifouler... so i need to look at the CHECK ENGINE every day..damn..
Old Oct 18, 2006 | 05:06 AM
TimmyT's Avatar
Scion Society
Like I said. If you install a Down pipe. And do NOT install the o2 sensor or the antifouler you WILL throw a cel. Plain and simple.
Old Oct 18, 2006 | 05:39 AM
senseiturtle's Avatar
? You mean "test pipe".
The CEL is caused by the lack of a catalytic converter on the header. The secondary O2 sensor thinks the cat isn't working... and since you removed it... it's right.
If you stay stock, and your catalytic converter takes a poop and dies at 120,000 miles... you'll have the same result.
Installing an Spipe alone will not cause a CEL, unless you screw something up and break, incorrectly seat, or forget to plug in the O2 sensor.
Old Oct 18, 2006 | 06:02 AM
sp0t's Avatar
dont you lose power with the CEL on? doesn't it tell the ECU to run in "limp" mode?
Old Oct 18, 2006 | 01:57 PM
Depends on the fault code, and depends on the motors. There is no "limp mode" for a tC, but some faults can cause incorrect engine management, thereby losing power.
Cars that come factory turbocharged with electronic wastegates (like VW 1.8T) will go limp if a MAF sensor goes out, or excessive knock is detected. This feature is to protect the motor, since a heavy lean condition can blow the whole thing to high hell.
Most cars- An emissions fault might deter performance slightly, but not in a "limp" mode. If your A/F sensor (the one on the header) goes out, your car will barely run. If your secondary O2 goes out or finds a fault, nothing will happen.
Old Oct 18, 2006 | 07:24 PM
mpbrown's Avatar
nice, what kind of gains from this? 0-10WHP?
Old Oct 18, 2006 | 09:17 PM
O5_TRD_tC's Avatar
umm i did do the install, and i did exactly what u plan on doing, to install just a s-pipe. I was waiting for my header to come in so decided just to install the s-pipe.
Old Oct 18, 2006 | 09:26 PM
If you delete both cats with a header and midpipe - 8ish.
If you're otherwise stock - 3-5.
No one has dynoed one on a stock system, but I noticed a difference. I run the stock header for legal and autocross class reasons.
yupinmytC
22
Jul 27, 2024 07:08 PM
eujin
Feb 23, 2016 01:18 AM
MeDizzy
Oct 8, 2015 03:31 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
