Is my tc weird? Shifting and RPM Question.
Old Oct 21, 2006 | 02:26 AM
xx0505xx's Avatar
Default Is my tc weird? Shifting and RPM Question.
MY cousin drove a lot of stick shift cars, maybe about 30 or so.. and I let him drive my 07 tc, but he told me that something is wrong with my transmission. He told me that whenever he presses the clutch that my rpm is way too high and takes forever to drop down. I noticed it as well but I have never driven another car before so I was just wondering if it was jsut the tc's that are like that or is it supposed to drop fast when i press the clutch? it really takes a long time for the rpm to drop.. and even when i'm in neutral the rpm doesn't drop right away.
Old Oct 21, 2006 | 02:33 AM
engifineer's Avatar
He hasnt driven that many stick shifts then. They all vary in this respect. It is the rotational mass of the internals and flywheel. There is nothing wrong with the car.
Old Oct 21, 2006 | 02:42 AM
watcher1307's Avatar
If I'm not mistaken, it should idle at about 700rpm. As far as your clutch is concerned, your rpm should go right back to idle when you take you foot off of the clutch. Unless your shifting into another gear, but that's another story. Yes, the rpm should go right back to idle like you were just revving your engine.
This isn't necessarily a transmission problem. Infact, I don't think it's your tranny at all. I think if it were, then your car would stall right after starting it. I don't know what it is for sure though. I would have it checked out. It could be just as simple as your accellerator pedal not communicating with your ecu. That might be why your engine isn't returning to idle as quickly as it should. But it could be more complicated then that. I'm not sure. Have it checked out asap. You don't want to be driving and not be able to shift into neutral and brake.!
Old Oct 21, 2006 | 02:54 AM
CuRiOuSfIsH's Avatar
yuup! it's normal for tC and other cars. My dad used to have a 1987 Nissan Van and it reacts the same way. The RPM's will just hang there. I try to make it better by fully releasing the gas then stepping in the clutch. It's slow but it makes for a more comfy ride.
Old Oct 21, 2006 | 02:55 AM
Baron1C's Avatar
there is already a thread about this, there is nothing wrong with your scion, it was designed this way to help beginers (and camry drivers) shift smoother, here is the link
https://www.scionlife.com/forums/vie...695&highlight=
Old Oct 21, 2006 | 04:33 AM
paul34's Avatar
It's fine, as has been mentioned. Also, he's probably sticking on the throttle longer than necessary... the throttles on our tC's are not only sensitive, but also different than other throttles, sorta.
It takes a little getting used to... that's it, though, nothing wrong
Old Oct 21, 2006 | 09:30 AM
Deathwish238's Avatar
I wonder if it has to do with the electronic throttle at all?
Old Oct 21, 2006 | 02:36 PM
io333's Avatar
It's annoying as heck, but normal for the tC. The ECU is programed to do that, but no one knows for sure why. I wish there was a reflash for the ECU to make it NOT do that.
Old Oct 21, 2006 | 05:40 PM
paul34's Avatar
I always assumed there was a bit of delay in the gas pedal... just let off a tiny bit earlier than you "normally" would and I've had no problems with it.
Old Oct 22, 2006 | 07:00 AM
I don't see why it's such a big deal? It's not like you're gonna shift faster than it takes the rpms to drop to idle....atleast I can't...
Old Oct 22, 2006 | 02:08 PM
you can match the speeds better and faster that way.
Old Oct 22, 2006 | 05:49 PM
I thought it's easier to shift smoothly when the rpms do hang a little?
Old Oct 22, 2006 | 11:51 PM
Yes, as a beginner, I think having the engine speed hang around is good b/c it will give time for them to learn to release the clutch properly. I dont find it smooth b/c I tend engage the clutch 500 above the proper RPM..... so the engine always has to drop its speed, and if I let out the clutch just a bit too quickly, it will have a slight tug. Compared to if the RPMs drop and I engage the clutch right when the engine and transmission speeds are proper, then I can let out the clutch faster without any jerkness..... hence why ppl match rev.
Old Oct 23, 2006 | 04:44 AM
Prototype_xB's Avatar
I love self proclaimed know-it-all's
Old Oct 23, 2006 | 12:58 PM
please add some insight.
Old Oct 23, 2006 | 03:52 PM
monkeysauce's Avatar
Heavy stock flywheels make the engine maintain momemtum longer between shifts. They allow you to shift more leisurely between each gear without the rpms getting too low. Try driving your car like you're not in a hurry, and you'll see how easy it is to shift.
If you don't like the way it works stock, then get a lightweight flywheel. Revs will rise and fall much more quickly.
Old Oct 23, 2006 | 04:07 PM
web's Avatar
web
And say good bye to the liesurely shifting.
Old Jul 27, 2007 | 12:17 PM
tekstyle's Avatar
how heavy is the stock flywheel and pressure plate?
Old Jul 27, 2007 | 12:44 PM
web's Avatar
web
I believe the flywheel is close to 35-38 lbs. Not sure about the pressure plate.
Old Jul 28, 2007 | 12:26 AM
Tcguy85's Avatar
i can be into the next gear by the time the rpm's drop. i deff shift fast enough to beat them.
