Greddy turbo install question
Old Oct 23, 2006 | 06:50 AM
DK01's Avatar
Default Greddy turbo install question
Anybody with the Greddy turbo kit have any problems with the radiator hose hitting the i/c piping connecting to the throttle body? I am planning to install my kit this weekend myself and looks like that area is a tight fit. Any help is appreciated.
Old Oct 23, 2006 | 12:13 PM
SicktC06's Avatar
Ask Rabid_lemming... He just installed a Greddy Turbo... do a ranking search on him, he's in GA and has a black cherry pearle tC.
Old Oct 23, 2006 | 12:54 PM
zer0's Avatar
I mocked mine yesturday, You should be fine. As long as you have the stock rad hose.
Old Oct 23, 2006 | 04:14 PM
DK01's Avatar
Yeah, I read Rabid's post, very helpful but nothing about the radiator hose.
Zer0, were you able to move the hose to the side to make room for the i/c piping?
thanks guys
Old Oct 23, 2006 | 05:55 PM
MysTiKchRis's Avatar
The Charge pipe does touch the upper radiator hose. I Wouldn’t say its a big problem though.
Old Oct 23, 2006 | 11:51 PM
mike6789k's Avatar
[imsg]http://i17.photobucket.com/albums/b65/mystikcjris/DSCF4707.jpg[/img]
teflon on the oil lines! BIG NO NO!!!
Old Oct 24, 2006 | 05:22 AM
Is Teflon really that big of a problem?
Old Oct 24, 2006 | 05:38 AM
tc2nut4's Avatar
yeahhhh...... HUGE problem
Old Oct 24, 2006 | 08:35 AM
noTCed's Avatar
why is it a problem?
Old Oct 24, 2006 | 12:38 PM
zer0's Avatar
No idea, ive never had a problem with it.
They say it can flake off and go into the turbo, but ive never heard or seen this happen, ever. Teflon has never flaked on me.
Only way I see it going into the turbo, is if you remove the feed line. Also NPT/RTV sealent can chunk up and go into your turbo, via same scenerio. So you cant win.
Old Oct 24, 2006 | 12:59 PM
yamaha16bw's Avatar
On the inner threads where the oil makes contact with the teflon. The oil will break it down and cause it to "flake" off and once it gets in your turbo its bad news. I'm on my 2nd turbo because of it. Dont use it! Right now I dont have any tfelon or rvt silicone on any of the oil lines and I dont have any leaks.
Old Oct 24, 2006 | 01:05 PM
zer0's Avatar
It takes years for teflon to break down. correct? Also applying the teflon right, the oil will not touch the upper threads.
Old Oct 24, 2006 | 03:25 PM
-NEMESIS-'s Avatar
If teflon tape is applied correctly and you don't by the cheap stuff, You will not have a problem.
Old Oct 25, 2006 | 12:54 AM
mike6789k's Avatar
yea i guess if you just install it on the outer threads and make it really tight you will have no problems!
wiltonhall
Jun 23, 2025 10:09 PM
cessblood
Sep 15, 2015 06:50 AM
my06tc
Jun 25, 2015 12:18 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
