built and finally finished a custom sub box
Old Oct 25, 2006 | 05:22 AM
Tcguy85's Avatar
Default built and finally finished a custom sub box
i was pretty happy with the stock stereo system in my tc other than needing some low end punch. so i bought a little setup from a friend that i actually set up for him a few years ago. it's an 10" Alpine Type-R(dual 4-ohm coils) with a Rockford Fosgate 301M monoblock amp(300watts rms at 2ohms). the box i used was a cheap Q-logic ported box which was only 1.5 cubic feet with a 4" diameter port which makes it tuned way to high for my liking.
so i, with the help of my dad built a 2 cubic ft enclosure which with a 3" diameter by about 10" long port tunes to roughly 28-30 hzs. once i fired it up i was instantly surpised how much deeper and louder it was just because of the box size and tuning. i have the subwoofer itself aiming towards the back of the car and the port is in the top of the box. the air coming out of the port is shooting rigt at the hatch window.
tonight i just got done covering the box after riding around with it in my trunk uncovered (just bare MDF) for weeks. i will post pics of it tomorrow now that it looks good finally for you all to see. my trunk space is about 2/3's gone but i never use it anyway, and even if i do i can easily take the box out.
my last system was (in a cavalier) 2 12's in a sealed box with about 450 watts rms to each woofer. this is very comparable to that with a lot less power and a lot less weight. so the point of the story is ported boxes when built and tuned right can be louder and sound just as good as a bigger setup with a sealed box.
pics of the setup to be added tomorrow once it's light outside. sorry for all the !
Old Oct 25, 2006 | 06:46 AM
Dakine's Avatar
Concept in Motion Crew
Post pics ASAP!!!
Old Oct 25, 2006 | 12:00 PM
SCI_TC_GUY's Avatar
sweet.... generally, the loudest configuration in a hatchback is what they call the "CRX Style" ported box which is with the subs up and ports firing rearward... but none the less, kudos to you!
Old Oct 25, 2006 | 02:32 PM
Tcguy85's Avatar
here are the pics, they were taken with my RAZR phone so the quality should be pretty good, but not perfect....
Old Oct 25, 2006 | 02:45 PM
Tcguy85's Avatar
it's pretty loud as it is and has great SQ... but eventually i would like to use a different sub and different amp. but the stuff i have is perfectly fine so no sense in getting something else yet, maybe if i blow this stuff up(which i don't see happening).
Old Oct 25, 2006 | 04:48 PM
07ToOcOoLs's Avatar
doesnt look like a custom box, I think you could have made it a lot cleaner.... and you didnt need to cut a hole in your cover
Old Oct 25, 2006 | 04:50 PM
Neothin's Avatar
just goes to show you how important the install is!
looks good, so much for a lot of cargo space though
Old Oct 25, 2006 | 04:58 PM
Tcguy85's Avatar
it's my first time building a box, but how could it have looked cleaner? and yes i did have to cut a hole in the cover. when the bass starting hitting hard it would get sucked into the port and made all kinds of weird noises. i didn't really like the idea of cutting it but it had to be done.
Old Oct 25, 2006 | 04:59 PM
bignoog's Avatar
hows this for trunk space hahahaha
Old Oct 25, 2006 | 05:07 PM
Neothin's Avatar
hehehehe
Old Oct 25, 2006 | 05:17 PM
SO-CAL_TC's Avatar
Originally Posted by Neothin
hehehehe
Old Oct 25, 2006 | 07:13 PM
nebster's Avatar
Old Oct 25, 2006 | 08:26 PM
Importspeed's Avatar
just remove the cover out of your car lol
Old Oct 25, 2006 | 09:16 PM
mandos's Avatar
hehehehe
OOooo...Go Carlos.
Old Oct 25, 2006 | 09:23 PM
rolstc's Avatar
hehehehe
are those 19"s or 20"s ??
connertc1
Scion tC 1G Aero & Exterior
13
Jan 17, 2017 01:33 AM
CONCRETETC
Feb 9, 2015 08:05 PM
sensez
34
Nov 24, 2004 12:30 AM
fliggah
May 28, 2004 07:51 PM
DjFrOsT
Nov 14, 2003 05:26 AM
