Apexi Turbo Timer DIY
Old Oct 29, 2006 | 06:17 PM
yamaha16bw's Avatar
Default Apexi Turbo Timer DIY
OK Since a few people have PM'd about the Apexi Turbo Timer(TT) install. I thought I would post a small DIY about the Apexi TT. Please keep in mind that this is just a guide to give you an idea of where the wires and such are located. It's not my fault if something goes wrong with your car.
This is a link for info on the Apexi TT
http://www.apexi-usa.com/product_ele...=198&pageNum=1
This is a link for the install manual for the Apexi TT
http://www.apexi-usa.com/pdf/product...tation/198.pdf
Some of my pics are alittle blurry so please bare with me.
First things first. Remove the shroud around the IGN. harness.
The next thing I did was mount my TT "brain" box.
Its the small black box wire multi color wires coming out of it. I mounted it on the inside of my center console. Just left of the shifter.
Ok now its time to wire it up. First thing I did was connect all the wires needed to the IGN. harness. The ignition harness is located under the plastic shroud which we removed earilier. The thick BLUE wire from the TT harness connects to the thin yellow wire" 2nd IGNITION +". The thick GREEN wire fromt the TT harness connects to the Thick BLUE wire"IGNITION +" wire on the IGN harness.
Next thing I did was hook up the 12v power wire to a circuit in my fuse bax using a Add-a-circuit which can be found at any auto parts store.
This is a Add-A-Circuit
The RED wire on the TT harness is your power wire. Again sorry about the blurry pic
Once thats connected your should find a good grounding point for the TT's ground wire(BLACK wire). Connect it to a clean solid metal surface. Sorry no pic.
Next connect your E-brake wire(GREY wire)
^^ I have mine wrapped in electric tape but this wire just taps right into the Black wire coming out of the front of your E-brake.
The White wire from the TT is not to be used on the tC. So just cap it off so none of the wire is exposed.
Ok so the only thing left should be to find a place to mount the Control box. This is where I mounted mine just to give you an idea.
I hope this helps anyone with the Apexi TT out. I'm not sure about other TT's since this is the only on I've installed but I'm sure it's along these lines. Please let me know if I missed anything or forgot to post a important part. I installed my TT about 4 months ago so this was all just memories.
Here is a wire guide for the Igniton harness from ProshopXB
Wire: Wire color/ Polarity / Location
12volts: red or white/ + /ignition harness
Starter: black / + /ignition harness
2nd Starter: green / + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Accessory: gray / + /ignition harness
Keysense: black / - / ignition harness
Power Lock: green with blue stripe/ - / driver kick, 20 pin plug, pin 15
Power Unlock: purple with pink stripe (double pulse)/ - / driver kick, 20 pin plug, pin 14
Parking Lights: brown/ + /top of fuse box, 30 pin plug, pin 29
Parking Lights: brown / - /headlight switch
Reverse Light: pink / + / top of fuse box, 14 pin plug, pin 2
Door Trigger: orange (D), blue (P)/ - /top of fuse box
Dome Supervision: blue/ - /L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin: purple/ - /top of fuse box, 30 pin plug, pin 7
Trunk/Hatch Release: orange/ - /driver kick, gry 12 pin plug, pin 12
Tachometer: black / ac / data link conn. under dash, pin 9
Brake Wire: blue / + /brake pedal switch
Parking Brake: black/ - /parking brake switch
Horn Trigger: white / - /horn switch
Save this wire guide cause it will save you alot of time asking about what wires go where.
Old Oct 29, 2006 | 10:10 PM
mike6789k's Avatar
Excellent! Thanks so much for this, i'll definately refer back to this once i get my turbo
Old Oct 29, 2006 | 10:33 PM
zer0's Avatar
Thanks for the pics and write up. It was definatly needed.
Old Oct 29, 2006 | 11:32 PM
yamaha16bw's Avatar
Your very welcome. I'll try and update it when I can get some better pics. But that wont be till I have a need to take everything apart again.
Old Oct 30, 2006 | 02:01 AM
Byta27's Avatar
nice very very helpful
Old Nov 10, 2006 | 05:58 AM
Byta27's Avatar
if u guys could please help me out i have the turbo timer in and when ever i take the key out of the ignition and the car runs from the timer the alarm goes offfff is there anyway to bypass this and if soo how can i do it? i installed it the same way that u did.
Old Nov 10, 2006 | 11:38 AM
yamaha16bw's Avatar
Like your car alarm goes off? If so which kind of alarm do you have? If your turning off the car and the car is still running then the TT sounds like its installed right. Alarms and TT's can be tricky to make work together.
Old Jan 12, 2008 | 09:47 AM
AKUMA's Avatar
i installed the apexi timer exactly the same, but when i turn off the engine the timer goes off also! why is it like that?
Old Jan 12, 2008 | 10:40 AM
bluaeon's Avatar
does 04-06 have the same wiring schematics as 07?
Old Jan 12, 2008 | 04:37 PM
AKUMA's Avatar
mine is 07 and i did it like this but it doesn't work. anyone know why? plz help!
Old Jan 12, 2008 | 07:04 PM
Mightygnu's Avatar
I also have the 07 and looking for a TT
Old Mar 5, 2008 | 05:07 PM
20tCDude05's Avatar
Bump? I am interested in knowing if my tC, which is a 07, will turn off the TT with it.
Old Mar 5, 2008 | 05:18 PM
ippskidder's Avatar
1UP Crew
Wow brought back from the dead, lol.
Bump for answer =)
Thats a good question.
Old Mar 5, 2008 | 05:19 PM
Mr_Meaty's Avatar
what year is yours, yamaha?
Old Mar 5, 2008 | 05:27 PM
ippskidder's Avatar
1UP Crew
I believe his is an 05-06.
I've been talking to him, since 06 on scionlife, lol.
Old Mar 5, 2008 | 08:20 PM
yamaha16bw's Avatar
I have a 06. Ive installed it just like this in my current tC and my old tC and its worked both times for me. Maybe the 07's are different.
Old Mar 5, 2008 | 10:17 PM
java09's Avatar
i have a hks type-1 on my 08 and i used this thread as my instructions! haha works like a charm for me! i still have to make a DIY for this guy i feel like a fkucnig dcik!
Old Mar 6, 2008 | 04:28 AM
yamaha16bw's Avatar
yeah my brother HKS TT is hooked up this way as well. Not sure why yous guys are having issues. Wish I could help.
Old Apr 9, 2008 | 09:14 PM
sk8rdud214's Avatar
Default HELP
no pics came up for me?
Old Apr 9, 2008 | 09:15 PM
sk8rdud214's Avatar
Default HELP
