Rotate and balance tires
Old Nov 1, 2006 | 03:25 AM
WillJitsu's Avatar
Default Rotate and balance tires
I just recently had my first oil change done at 5,000 miles at the Scion dealership. I just got to thinking last night that I haven't had my tires rotated and balanced. Should I have requested for them to do that when I got the oil changed? Is it a good idea to do it at every oil change? And lastly, does anyone know what the extra charge for getting that done is since the first 3 oil changes are free. Thanks!
Old Nov 1, 2006 | 03:32 AM
kdog_1981's Avatar
rotate tires is around 18 bucks at the dealer. or free by yourslef!! And yes do this every oil change.
Old Nov 1, 2006 | 03:37 AM
WillJitsu's Avatar
Thanks for the quick reply
Jackass's Avatar
If you are doing oil changes every 5000 miles, then yes you should at least get them rotated every oil change. Every 5-10k miles is usually a good practice to get into. I only get mine rebalanced when I feel a shake when driving. Otherwise I just jack the car up in my driveway and rotate them myself.
Old Nov 1, 2006 | 03:40 AM
kdog_1981's Avatar
No problem!
Old Nov 1, 2006 | 04:09 AM
ehj's Avatar
ehj
For the price of 2 rotations, you can buy yourself a hydraulic jack and a pair of jackstands. Not the best quality, but it'll work.
Old Nov 1, 2006 | 04:11 AM
WillJitsu's Avatar
Yes, but what about balancing? Don't you need special equipment for that?
Old Nov 1, 2006 | 04:21 AM
sciontc_mich's Avatar
yes well you only need balancing if you are noticing vibrations above 40mph.. (usually when out of balancing shows up.. between 40-70mph).. if not no need to do it..
but rotation yes.. i would say every 3000 to 5000.. low profile tires require more rotations than other tires..
Old Nov 1, 2006 | 04:37 AM
ehj's Avatar
ehj
From my experience, the only time I need balancing is when I hit plenty of potholes or hitting the curb.
The older the tire gets, the greater the chance of needing balancing, but harsh bumbs will knock it off balance.
I normally don't need balancing until about 70% thru the life of the tires. Also, if you want to go cheap, only balance the fronts.
Old Nov 1, 2006 | 07:51 AM
speedelement's Avatar
The local America's Tires does it for free+tip, not sure if that's standard nationwide.
Old Nov 1, 2006 | 10:35 AM
kdog_1981's Avatar
In your service manual oil change every 5,000 miles and tire rotation (front to back) every 5,000 miles as well.
Old Nov 1, 2006 | 05:13 PM
AZURETCTONY's Avatar
My dealership told me to rotate tires every 7,500. I switch between stock and aftermarket sets of wheels/tires so I jus keep track when and at what mileage I swap them.
Old Nov 1, 2006 | 05:53 PM
kdog_1981's Avatar
just makes it easier to keep track by doing it on oil changes.
Old Nov 2, 2006 | 02:52 AM
Well I run full synthetic Amsoil oil and do my changes June 1st and December 1st per year. So yeah the chrome rims come off Dec. 1st for Jersey winters but I put them back on usually March or so.
evolving_machine
Oct 21, 2023 01:16 PM
afoulk
Dec 31, 2016 02:53 PM
baker08tc
Apr 9, 2015 09:47 PM
pier0723
Mar 17, 2015 03:14 AM
EcksBee
Dec 20, 2003 12:12 AM
