Valve Cover Torque Specs??
Old Nov 2, 2006 | 01:24 AM
tCjosh's Avatar
Default Valve Cover Torque Specs??
I already searched and came up with nothing, but if there is a page on my question, please post it up here.
I'm going to take my valve cover off to polish it either tomorrow or Friday, and I wanted to know what the torque setting is for the valve cover bolts?
Thanx in advance!!!
Josh
Old Nov 2, 2006 | 01:27 AM
11thhour's Avatar
it's tight method is good enough...
NOT good enough
Old Nov 2, 2006 | 03:10 AM
jjos1's Avatar
Got your gasket too ?
Old Nov 2, 2006 | 04:11 AM
soros151's Avatar
watching
Old Nov 2, 2006 | 11:33 AM
zer0's Avatar
Old Nov 3, 2006 | 04:27 PM
senseiturtle's Avatar
Thanks zero.
I was about to answer ... " Good'n "
Good'n tight!
Old Nov 3, 2006 | 09:32 PM
jjos1's Avatar
Good luck with your valve cover, I'll be taking mine off tonight to powdercoat it along with some other stuff :D
Old Nov 4, 2006 | 06:08 PM
tCjosh's Avatar
Thanx Zer0!!! I polished my valve cover on thursday and it looks pretty good. Just got to do some more polishing on it since I didn't have enought time to do it. I'll post pics up later...
Old Nov 26, 2006 | 02:52 PM
RSracer's Avatar
Were you able to reuse the existing gasket?
Old Nov 27, 2006 | 02:03 AM
jjos1's Avatar
You could probably reuse the gasket, but I would rather get a new one just to be safe they are not very expensive. When I did mine I put a new one on.
Old Nov 27, 2006 | 02:25 AM
soros151's Avatar
Looks AWSOME!
Old Nov 27, 2006 | 02:35 AM
jjos1's Avatar
Thanks, now I just need a greddy kit in there
Old Dec 14, 2018 | 05:18 AM
Tracecross's Avatar
Default Valve cover
Hey, where you get this valve cover from? I like it. I have an 07 tC.
_________________________________
Old Dec 27, 2018 | 08:07 PM
62Fender's Avatar
Valve cover torque specs:
Center bolts x 2 - 10 lbs ft
Flange bolts x 6 - 8 lbs ft
Flange nuts x 2 - 8 lbs ft
Old Apr 7, 2024 | 08:36 PM
Meeshel's Avatar
Default Thank you so much 62Fender;4292219 this is the only place on the internet I could it
Thank you so much 62Fender;4292219 this is the only place on the internet that I could find this information! Appreciate it!!!
QUOTE=62Fender;4292219]Valve cover torque specs:
Flange nuts x 2 - 8 lbs ft[/QUOTE]
Old Apr 11, 2024 | 12:30 PM
62Fender's Avatar
Forgot to mention, Toyota says to torque the Center Bolts first. Then torque the Flange Bolts and Flange Nuts in a star-pattern, inside to out.
noskatehate22
Nov 1, 2012 01:54 AM
mrhat
Feb 22, 2010 04:31 AM
jetblast
Sep 2, 2008 02:29 AM
xbbox
Mar 1, 2008 04:17 PM
corpan32
Jul 26, 2005 02:33 PM
