vvti24
11-03-2006, 11:14 PM
I have tein basics and plan on purchasinf the trd rear swaybar.. have any of guys had problems thier compatbility? just requesting for results with the combo...
View Full Version : Tein Basics w/ trd swaybar vvti24 11-03-2006, 11:14 PM I have tein basics and plan on purchasinf the trd rear swaybar.. have any of guys had problems thier compatbility? just requesting for results with the combo... O5_TRD_tC 11-03-2006, 11:22 PM i have ss-p and trd rear sway, no problems here. i dont think u would either. -NEMESIS- 11-04-2006, 01:35 AM i have the same setup ^^ no probs here either. Baron1C 11-07-2006, 02:53 PM how does the setup handle, i push my car hard on back roads(twisties) and the highway, how about on rough roads?? -NEMESIS- 11-07-2006, 03:44 PM if i was going to make the tC a track car i would get a stiffer sway bar than the trd. But that would only be beneficial if you had very sticky tires to go along with that. But for slightly spirited driving this set up would be more than enough. But On very rough roads i feel that the spring rate is too stiff. But if you soften you shock settings it is much more managable. Just don't slam the teins all the way down if you want to get the best performance. Otocan 11-08-2006, 06:29 PM nicely put -NEMESIS- - but I had my TC on Hotchkis front and rear sways, and they did not affect the ride much until you started turning and noticed how flat the car was through the corners. What the sway bar will do though, is transfer the force from one shock to the other, so instead of hitting a bump on the left side and the left side only absorbing the bump, the right side will as well since the sway's job is to transfer the force as evenly as possible across both sides of the suspension. When I went back to stock after using the hotchkis, the first thing I noticed was the body roll. the second thing I noticed was what I mentioned about bumps now being independent to the side the bump was on, which did make the ride a bit smoother, but nowhere near worth the trade off for superb handling characteristics |
