Hotchkis sway bars
Old Jul 30, 2004 | 02:07 AM
pogseo's Avatar
Default Hotchkis sway bars
i recently installed this sway bar in the front and when i was bolting it to the sub frame i noticed that the u shaped piece didnt match up to the bolt holes and the oem one wouldent fit arround the bar and busshing . Does anyone know how to solve this problem ? please help
Old Jul 30, 2004 | 07:11 AM
Minsk99's Avatar
All I can say is that they are a total pain in the ___ if you do not have a lift. They do fit though. Try loosely putting in both bolts before tightening them down. I had a hard time at first because I tightened one down all the way before threading the other. Also, the bolt heads are really close to the side of the u holder (or whatever its called). I had to bonk the ratchet attachment hard to squeeze it over so I could tighten it all the way. Not sure if these are the problems you are having, but hopefully this helps some. Also, a few months back someone reported that Hotchkis had sent out a batch of rear sways that didn't match up correctly and had to be reshipped. Not sure if this was true or not, but perhaps this might be a similar problem with your part. Try calling Hotchkis and see if they can tell you what's up.
Old Jul 30, 2004 | 03:35 PM
Nick's Avatar
i just ordered the stsge 1 TVS Kit. I will let u know how I did with the install.
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
rvascion
Nov 12, 2020 03:23 AM
SloTC1
Aug 16, 2018 02:45 PM
maximthegreat
Jan 19, 2016 02:31 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
