brake light malfunction!!!
Old Nov 5, 2006 | 06:37 AM
vvti24's Avatar
Default brake light malfunction!!!
For some reason, my brake light indicator on the gauges is flickering everytime i accelerate.. i have no idea why this is happening... Is this an electrical, wiring, or brake problem? or is it another way of telling me i need brake fluid? It tunrs on and off, it flickers whenever i turn fast or wot.. somebody help..
Old Nov 5, 2006 | 06:49 AM
SquallLHeart's Avatar
there's a switch where the brake handle is.... it's probably loose.. or something in it that's just causing it to trigger whenever you move..
just open and take a look.
Old Nov 5, 2006 | 02:55 PM
trialsindude's Avatar
Strictly Scionized
fill your brake fluid
go out look under the hood, look at brake reservoir notice it is low fill with DOT 3 viola finish
Old Nov 5, 2006 | 05:28 PM
engifineer's Avatar
Dont fill it.. replace your pads if it is that low. Or find the leak and THEN fill it. That light is the brake warning light, not just the e-brake. It detects low fluid, uneven brake pressure, etc. When your pads are worn low enough, the fluid will drop in level far enough to turn on the light, or sometimes only when you move the fluid around enough to trigger it (like taking off).
On mine, when the light flickered, it was time to change the pads on the front. If you fill it back up, you will spill fluid when you put on the new pads. So check your pads and replace them if needed, the level will be right where it used to be. The only way fluid level will drop is a leak or worn pads.
If it isnt the pads, check your calipers, master cylinder, etc for leaks if the fluid is low.
If the fluid isnt low, then start checking the ebrake sensor to see if that is bad.
But I would guess your pads are worn significantly
Old Nov 6, 2006 | 02:21 AM
vvti24's Avatar
i had my pads checked at the dealer and they said i have over 50percent more left until it needs replacement... idk i might just check the wires next to the handbrake, cause i did mess with it when i installed the short shifter..
Old Nov 7, 2006 | 01:15 PM
engifineer's Avatar
did you check the fluid?
Old Nov 7, 2006 | 02:22 PM
vvti24's Avatar
the fluid was in the middle not at max but not at minimum....
bostondaniel
Scion xD Suspension & Handling
15
Sep 12, 2020 03:16 PM
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
bruceb25
Nov 23, 2014 04:52 AM
