View Full Version : CAMS for a 2AZ?
TurboTY 11-06-2006, 05:46 AM I really want to install some performance cams in the TC but have had no luck finding them for a 2az....seeing how easy they are to change out, someone has to make them right?
Who makes them and who here has them?
Experiences with them?
Thanks, TY
soros151 11-06-2006, 12:24 PM The only ones there is, is for supercharged guys. No N/A cams for now. They may be easy to change, but not easy, nor cheap to make.
Nick06tC 11-06-2006, 12:29 PM You can have them made check out this thread. The guy has custom cams with pictures:
CHeck his profile.
http://www.scionlife.com/forums/viewtopic.php?t=147082&start=0
TCpete 11-06-2006, 03:53 PM cams for the tc right now are pointless... heads run on timing not on lift. by making the duration of the lift longer you wont benefit because the stock ecu will pull or advance timing. cams would be pointless because of that and also you would need an EMS to control the timing by yourself and not the computers "variable" timing.
Nick06tC 11-06-2006, 05:44 PM Not true. ICENINE has dynos showing a 30whp increase with cams.
TCpete 11-06-2006, 06:02 PM on a supercharger.. and requiring timing control... anyone can make a regrind that "ads lift" and make a dyno of it. please read up on how our engine works in conjunction with timing and not lift. this isnt a honda motor which works on lift..we work on timing. if you make a cam that is preset at an advanced timing to trick the ecu then or course your going to make more power.
and im well aware of him and his thread. funny though because if the cam worked for a SC why not N/A but he could not answer this nor the company that made the cam yet they were charging almost 800 bucks for a set of regrinds they couldnt give any info on. i dont read and beleive everything i see on the internet i hope others here also do either.
Nick06tC 11-06-2006, 06:05 PM Exactly, so why did you say cams on a tC are pointless?
Pointless would mean they do nothing for you. And they do, do something for you.
Reguardless of the means of how it works compared to another vehicle, if it works its not pointless.
Maybe I am missing something.
TCpete 11-06-2006, 06:09 PM Exactly, so why did you say cams on a tC are pointless?
they are because no matter what the ecu will default and retard or advance your timing based on what the sensors are reading.. if your timing is affected then how will you be making more power if the timing is continuously varried and corrected for fuel economy reasons
we dont work on lift like traditional motors.. we work on timing.. control the timing and you can make more power.. a cam alone will do nothing for you if it would do anything it all at this junction.
Nick06tC 11-06-2006, 06:12 PM With proper tunning the Cam does do something. It has been proven with dyno runs, videos, and printouts to prove it.
I imagine you are right, a cam alone wont do anything, but know one would do a cam alone. So you just take it forgranted that timing and all will be controled to not allow it to reset to factory settings.
A cam in the tC does make a difference, it has been shown.
TCpete 11-06-2006, 06:12 PM the only thing which would help you out especially on the intake side is not a bigger cam but a cam with a preset degree already advanced into it...but thats a whole other thread in itself..
the original thread poster would benefit more from a greddy emanage U or cam-com which controls timing and cam angle then actual cams at this point.
TCpete 11-06-2006, 06:16 PM With proper tunning the Cam does do something. It has been proven with dyno runs, videos, and printouts to prove it.
the only thing the tc is benefiting from that combo is the tuning aspect of it... we dont work on lift!!!!!! we work on cam angle and timing.. thats what your missing... give me an EMS on a supercharger and let me advance the timing and open up the exhuast..i can make the same numbers also with alot of work 93 octant and advancing the crap and cam angle of the head. thats what people in his thread were missing... it was basically almost a scam... pay 800 bucks for regrinds when about 400 dollars with an ems and good tuner can do in half the time.
TCpete 11-06-2006, 06:21 PM read this and you will see why cams in our motors are somewhat obselete..
http://www.billzilla.org/vvtvtec.htm
Nick06tC 11-06-2006, 06:25 PM I am pretty sure, he did the cams AFTER the EMS. And thats when his dynos showed the change.
Requardless of the reasoning and theory of anything, you cant deny the increase on a dyno. His numbers are higher than anyone elses, and all he has over others is the CAMS. You might be right, but in his application he had an increase with CAMS. Read through it:
http://www.scionlife.com/forums/viewtopic.php?t=138440&start=0
Nick06tC 11-06-2006, 06:26 PM read this and you will see why cams in our motors are somewhat obselete..
Excelent Site with great info.
TCpete 11-06-2006, 06:32 PM have you seen the mods he has??? read it and then see why and how he got all the HP increase.. its obvious.
Nick06tC 11-06-2006, 06:35 PM Yes I have seen them.
Well we have totally thread jacked. I will let people that know more about it than me chime in. I really am not very knowledgeable on it. I just have watched his build and seen what did what.
Anyone else have info?
Take the time to call Ripp... They dont sit on the computer all day, so calling them you would probably get better information.
You mention VVTi is the main role for cams not doing any good. So could you explain why the VVTi Supras have a boatload of cams for their turbo setups?
MileHightC 11-06-2006, 07:02 PM You mention VVTi is the main role for cams not doing any good. So could you explain why the VVTi Supras have a boatload of cams for their turbo setups?
Ummm...don't believe any of the Supras (2JZ's) used VVTi...that's the main problem with 2JZ-GTE swaps into newer GS300's.
TCpete 11-06-2006, 07:03 PM there is a huge diff. between these 2 motors. you cannot compare the modern day 2z with its faster learning curve and ecu mapping vs the older model 2j which uses a completely diferent designed head based on lift and timing vs. ours that is just lift. also the learning curve and ecu complexity is slower and easier to work with in the 2j(hense thank you HKS f-con ems in helping that out for tuning and timing).
its 2 completely diff. designed motors using vvti. you cant compare one to the other because they both use vvti.
TCpete 11-06-2006, 07:05 PM You mention VVTi is the main role for cams not doing any good. So could you explain why the VVTi Supras have a boatload of cams for their turbo setups?
2js do use vvti.
Nick06tC 11-06-2006, 07:07 PM But you keep talking about the ECU learning. That is easily bypassed, so it is not a factor. You cant use that as a reason, except for when talking about a CAM only swap like hondas do.
The tC has a stong ECU so any major work also includes EMS. Same goes with the cam. So learning, which is your main argument, is not an issue.
This is the degree of my knowledge but, you seam to ignore it.
TCpete 11-06-2006, 07:15 PM k one more time.. ill put it in this theory.. if the cam is bigger and the ecu reads more a/f being mixed.. it will nasturally adv/retard the timing to decrease that to make sure you are running at an economoy and perf. level.. but the thing to that is that no matter what our head runs on timing and not lift. thats the way it was designed.. no matter the lift the ecu will always fight it.. granted even with ems the lift will not be the factor but the actual timing is key. i think thats the part you might be missing.
Nick06tC 11-06-2006, 07:18 PM I must be missing something.
TurboTY 11-06-2006, 10:36 PM Well I understand where both of you are coming from in this debate, but cams and timing will always add power to an engine if you know what you are doing when tuning it.
But I want to install them before I get a tuner for the car so
WHERE CAN I GET SOME N/A CAMS?!?
Oh and by the way the 2jz-gte never had VVTi on it in the Supra, only the newer 2jz-ge (non-turbo) engines in Lexus had the VVTi.
http://www.supravvti.com/
TurboTY 11-07-2006, 02:45 AM Well I understand where both of you are coming from in this debate, but cams and timing will always add power to an engine if you know what you are doing when tuning it.
That is a swap car and not U.S.
Supra was only imported till 1998 in the US and the VVTi was never used on it.
The web page you have is a 2jz-gte bottem end with a 2jz-ge (VVTi) head and turbo.
The guy traded a turbo car for a non-turbo car and then turboed it.
kungpaosamuraiii 11-07-2006, 04:29 AM There are no cams out there right now. You'll have to settle for custom regrinds.
Anyways, a question to TCpete: are you saying that even with an EMS controlling timing, the ECU would still somehow overcome it? I don't see how the ECU would be a problem if the EMS is sending modified information to the ECU to get it to react the way we want it to.
IceNine 11-07-2006, 12:05 PM There are no cams out there right now. You'll have to settle for custom regrinds.
That's the part tcpete is missing.... He's absolutely right when it comes to closed loop controllers. Everything changes when using an open loop controller like the Eman U.
Like Ripp has said, Vortech superchargers really benefit from additional lift on the exhaust side. Show me a 311whp supercharged setup that does it with everything i've done but minus the cams, and maybe i'll believe it. I won't claim to be the expert on all things tuning.
But until then, it's all just talk :)
