Problems with GReddy Turbo Timer
Old Nov 10, 2006 | 04:27 AM
fairladyz541's Avatar
Team Sushi
Default Problems with GReddy Turbo Timer
I just got finished installing my Greddy turbo timer and everything seems to be ok. Well, thats untill I turn off the car, it justs turns off. There is no countdown or anything just the word "OFF". I get a volt reading on the timer and everything else works fine. I don't know if wires are wrond I hooked them up as stated in a DIY.........
Old Nov 10, 2006 | 04:38 AM
Prototype_xB's Avatar
Do you have the E-Brake up? Did you wire the E-Brake?
Old Nov 10, 2006 | 04:41 AM
Team Sushi
I tried with ebrake up and down and its tapped into the ebrake wire
Old Nov 10, 2006 | 07:45 PM
Team Sushi
Bump......
Old Nov 10, 2006 | 08:03 PM
DK01's Avatar
Sounds like a remote wire is not hooked up correctly. the relay in inside is not triggering the TT to go off. You sure, you got the correct wire connected?
Old Nov 10, 2006 | 08:06 PM
BOXMAN's Avatar
Fairladyz541 just call the guys at Single Digit.
Old Nov 11, 2006 | 04:24 AM
Team Sushi
The owner of Single Digit Racing is my roomate.......
I havent seen him since he has been working a lot but I should see him tonite, I will see what he thinks.
I have the red wire to red wire in ignition harness
Blue wire to blue wire in ignition harness
Green wire to Yellow wire in ignition harness
Brown wire to Parking brake black wire
Purple is to purple in the ECU harness secound plug from the top
Black is to groound
I need help.......
Old Nov 11, 2006 | 01:30 PM
ProshopXB's Avatar
Try switching the Blue wire from the TT to Yellow and the Green wire from the TT to the Blue. I think you have them backwards. Green from TT goes to Ignition 1, Blue from TT goes to Ignition 2.
12volts: red or white/ + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Old Nov 12, 2006 | 11:48 PM
Team Sushi
Thanks Proshop Xb works perfect now...........
Old Nov 12, 2006 | 11:54 PM
BOXMAN's Avatar
sweet easy as that.
Old Nov 13, 2006 | 01:34 AM
ProshopXB's Avatar
Awsome... glad I could help..
Old Nov 13, 2006 | 10:24 PM
j3st3r's Avatar
Music City Scions
Now THIS is how a posting should go.....a problem......a solution, a thank you and no one bad mouthing or going of topic.....NICE JOB ALL!!!
Old Nov 13, 2006 | 11:30 PM
zer0's Avatar
Could we Archive this in the "Sucessfull thread section" please?
Old Nov 14, 2006 | 02:33 AM
ProshopXB's Avatar
Man I must have missed that section..
tckid21
Mar 12, 2017 09:16 PM
Flyfishfreak
Jun 10, 2016 02:55 AM
cessblood
Sep 15, 2015 06:50 AM
my06tc
Jun 25, 2015 12:18 AM
onesicbowtie
22
Oct 20, 2003 10:25 PM
