question...?...
Old Nov 13, 2006 | 01:36 PM
spECIal's Avatar
Default question...?...
i have 2 12cvr kickers in my tC
well, when i got my system, bout 8 months ago, it came with some amp wit 2000 max watts (yea, i didnt know bout rms then, i jus saw high numbers ) well, my amp cant handle the power anymore
after about 1 30min drive, the subs will take like a 5 minute breather than cut back on and so on. so yea, my amps lil power protective thingy comes on.
wat amp would u guys recommend for my 2 12's?
i could careless bout the price, but it would be nice if u can give me a variety.
im jus in need of something that'll help push my subs to the max.
also, sometime late next year i myte add a 15" kicker.
would i need a separate amp for this?
again, wat would u recommend.
one more thing, yea i kno
but um.......in the future i also want an amp to power to my speakers.
so, if i had my 2 12's, my 15, and speakers, would i need 3 different amps???
all help is needed, thanx
Old Nov 13, 2006 | 02:35 PM
skimpydime's Avatar
1000/1 jl audio will work great with any pair of subs
Old Nov 13, 2006 | 07:12 PM
spECIal's Avatar
thats it, no other opinions?
wat if i get the 15" sub later on?
Old Nov 13, 2006 | 10:24 PM
sciondrgn's Avatar
What amp are you running now and how do you have the speakers wired and whats everything set at on the amp?
Old Nov 13, 2006 | 10:29 PM
spECIal's Avatar
i dont have the speakers wired now, they are jus stock. that is jus for future reference.
the amp i have now is called "Koiiler".
wat is everything set at? i have no clue
Old Nov 13, 2006 | 10:44 PM
sciondrgn's Avatar
What I mean by setting is like the gain ****..
Two things usually will cause an amp to go into circuit protection or clip.
Either the subs are wired incorrectly or do not match the amp and causing it to go into a lower ohm load then it can handle
or
the gain is turned up so high its causing distortion
What you need to do sub/amp wise is to match the subs ohm rating you want with an amp that has the power and configuration to support the subs.
Honestly getting 2 12's and a 15 would be WAY overkill and prob not even fit easily. again if thats something you want to do you can go with 3 amps or your could get away with 2.. its all going to depend on your subs you want to go with and there wiring configuartion
Old Nov 14, 2006 | 02:44 AM
skimpydime's Avatar
one thing you really want to remember is get the same series amps and speakers (meaning dont mix an alpine 12 and a JL 15 or a jl 6wseries with a jl 7wseries) because when you mix the timing might not be the same or the freq could be off.
but really the / series is a great way to go, they 1000/1 will power almost anything and it has some good features like no matter how you wire it (series or parallel), it will alway displace 1000 watts check it out.
Old Nov 14, 2006 | 06:31 AM
ADRdesignCo's Avatar
i support the JL 1000/1. :D im upgrading the the 500/1 for my single compvr 12
Old Nov 14, 2006 | 01:27 PM
SCI_TC_GUY's Avatar
don't mix sizes or types of subs... if you're going to eventually get one 15, then sell what you have and spend more on the 15/enclosure/amp...that's JMO
Old Nov 14, 2006 | 01:51 PM
spECIal's Avatar
i see wat ur sayin, but is it bad to mix sizes.
does it cause sound problems?
i was jus lookin into doin that for looks.
however i plan to have my setup i think it'll look nice to have to smaller subs on the sides then the big one in the middle.
Old Nov 14, 2006 | 02:06 PM
SCI_TC_GUY's Avatar
the only way you'll want to di that is if you have the 2 12's playing different frequencies than the 15... for example, build a large sealed box for the 15 and have it running 10-50Hz and then allow the 12's to go from 50-70 or 80 Hz... but even then it's not going to sound as good as if you just had the 12's or the 15 playing on it's own
Old Nov 14, 2006 | 02:20 PM
spECIal's Avatar
Old Nov 14, 2006 | 02:26 PM
SCI_TC_GUY's Avatar
The main concern with mixing sub sizes and types is cancellation. Basically sonic waves trying to battle over movement and cancelling each other out.
Old Nov 14, 2006 | 02:29 PM
spECIal's Avatar
so ur pretty much sayin its pointless.
like the 15 will jus drown out the 12's ?
Old Nov 14, 2006 | 02:32 PM
SCI_TC_GUY's Avatar
that's why I say to use each sub size/type for specific frequencies. otherwise you'll get funny response and possible loss of output.
You may look into some Elemental Designs equipment... Absolutely awesome equipment for the pricepoint it's at...
www.edesignaudio.com
You even get a discount for being a ScionLife user... type "forum" in their search bar and you'll see the forum discounts.
Old Nov 14, 2006 | 02:39 PM
spECIal's Avatar
alrite, so it is possible to have the 2 12's and 15 without sounding horrible. cause i really want that setup, but not if its going to kill my sound.
i'll peep the site
Old Nov 14, 2006 | 02:49 PM
SCI_TC_GUY's Avatar
like I said, enclosure design and crossovers are going to be your friend in this situation. Those will help you seperate the frequencies being produced through each speaker
Old Nov 14, 2006 | 03:01 PM
spECIal's Avatar
alrite, thanx :D
yhwhdesign
Jun 11, 2021 03:34 PM
Luisfc1972
Scion tC 2G ICE & Interior
Sep 20, 2015 05:45 AM
mikeac
Sep 15, 2015 03:24 PM
TheRealShark
Aug 5, 2015 05:08 PM
Mpwr
Jul 17, 2015 08:39 AM
