I need help with my rims!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 13, 2006 | 09:40 PM
Xbguy1's Avatar
Default I need help with my rims!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok i have aske this 2 or 3 times before but today i took off my stock rims and just placed my konig 18" 7.5 with a 45mm offset on there and there is only less then 1/2 an inch bettwen the inside lip of the rim and the strut.
To me this dose not look good . however several ppl on here have said that i could get away with runing 7.5's with a 45mm offset without needing a spacer.
my ? is are they right? can i run thoses rims up front with out a spacer .
if not what spacer?
Old Nov 13, 2006 | 09:42 PM
cherryBox's Avatar
you think the front is bad, check the rears against the frame. dollars to donuts they're rubbing. I've got +45 and it was the biggest mistake of my box. I've now got project kicks spacers all around, 25mm in back and 15 up front.
Old Nov 13, 2006 | 09:44 PM
TerribleTed's Avatar
That should be enough clearance there as that dimension should never change unless you are bending something...like getting hit in the side of a wheel by another car Well actually it can change slightly as the suspension is loaded but I really think you wont have clearance problems to the strut. Some other places like in the rear suspension or in the front the closest clearances are at full turn of the wheel might get very skinny. My 42MM offset 7.5 rims and 215/40/18 tires slightly rubbed the tow hook behind the wheel at full lock turn (left only). A few blows with a big hammer fixed that for me. Good luck.
cherryBox's Avatar
ok, re-read... mine are 8's not 7.5 but i'd space those too.
Old Nov 13, 2006 | 09:51 PM
Xbguy1's Avatar
ok just so you know im droping it with the tein s-tecs and runing 10mm otg shim in the back. also what tire size should i go with. probably going to go with the falken beta's or the fk-451's
Old Nov 13, 2006 | 10:43 PM
Xbguy1's Avatar
any more help? plz
Old Nov 15, 2006 | 11:42 PM
Venom_Xb's Avatar
fk-451's are a nice tire. 215/35/18 seems to be the norm for an 18" or 19"
Did you get spacers for your box? Your rim doesnt have to be a mile away from the strut. Throw a spacer in there and you should be fine if im not mistaken.
Old Nov 15, 2006 | 11:55 PM
Venom_Xb's Avatar
I had to run a spacer on my 7.5's and mine are 42mm offset
Old Nov 17, 2006 | 12:38 PM
Xbguy1's Avatar
sweet thanks man.
yeah i have the 10mm OTG shims for the back and im thinking about the HnR 15mm spacers for the front.
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
