autometer DPPS gauge (installed PICs)
Old Nov 16, 2006 | 04:29 PM
vvtiTc06's Avatar
Default autometer DPPS gauge (installed PICs)
Hi guys looking at buying this gauge from auto meter http://www.autometer.com/cat_accesso...st.aspx?pid=47
it says that it works with a 5-6 pulse ignition signals, i wanted to make sure the TC has this type of signal before buying it. I talked with summit racing tech, auto meter tech and even Toyota dealer and no one can say yes or no, auto meter started talking all crazy tech words i was like WTF. but in the end he said they done no testing on TC but he thinks it would work!! what do you guys think! i am just putting this gauge and boost in for the S/C
thanks
Old Nov 22, 2006 | 09:08 PM
vvtiTc06's Avatar
Wow! So no one knows anything about this? No one ever hooked up a rpm gauge?
Well anyways I orded it and got it in last night but have not yet tryed to install waiting for my dual pod but looking at it! It only has 4 wires red - power , black - ground, green- goes to positive place of the coil , and blue someting about brake light negitive spot? But don't seem to hard, any idea or does this make more sence now? Thanks if you can help!
Sorry if there is a lot of bad grammer I'm using a cell phone while at work!
Old Nov 22, 2006 | 10:18 PM
jjos1's Avatar
What style did you get ? can you post pics when you are done
Old Nov 22, 2006 | 10:28 PM
vvtiTc06's Avatar
Default pic
ya i will soon! i orded it from summit racing but here is the pic of it on the auto meter web site! http://www.autometer.com/cat_accesso...st.aspx?pid=47
i got the green one because im dooing all my LED's in green
Old Dec 15, 2006 | 04:35 AM
vvtiTc06's Avatar
Default HELP
Ok guys! i got everything instilled BUT the digital rpm the autometer dual gauge pod fit perfect as a replacement by the way! who ever cut theirs to make it fit was not thinking! ill take pics later...ANY ways this gauge is driving me crazy it has 4 wires and 2 are easy ground and positive DONE now i have 2 more i have blue (break light "positive" should be easy follow the break peddle) but the green one ( goes to negative out put on coil) well i went to the dealer today to try get wire diagram, and or color of wires i need to find! they were some what helpful. but since are cars have 4 coils also makes me think it wont read right from there so the other option for green wire it Tack out put i figure since are car have stock rpm gauge that we have a out put wire running from that back of it this should work as well but i need the color of this wire or witch one it is! any ideas?
has any one installed a rpm gauge on there TC yet hahaha!
thanks for any help or ideas before i just go do it!
Old Dec 15, 2006 | 04:43 AM
tCTaco's Avatar
You can either run it to the ecu, or run it to coil one......
you only hook it up to one coil......hence revolution....everytime that one cylinder moves up and down is one revolution meaning all cyliders have completed one full rev..........I installed a tach in my Tacoma, I chose to tie in to the ECU....but you need to find out the wire colors....
Old Dec 15, 2006 | 04:52 AM
vvtiTc06's Avatar
here some pics of the pod and gauges, they are from may cell phone so my not be great, ill get better one later!
You can go to my car domain i just started it so it nothing much! lol go here for bigger pic http://www.cardomain.com/ride/2515309
Old Dec 15, 2006 | 04:59 AM
vvtiTc06's Avatar
yah i figure that the wire from the ECU runs to the back of the stock RPM gauge i find that i should be fine i would assume that someone has done it and i hope they read this!!! but yah just gotta find that color!
Old Dec 15, 2006 | 05:05 AM
imsonofagun's Avatar
Take a look at http://trdsparks.com/install/00602-83400-005inst.pdf It might help.
Old Dec 15, 2006 | 05:06 AM
tCTaco's Avatar
Yeah, Cant tell you the color.....
but from the tach, you have 4 wires, one for 12v supply, one for ignition, one for ground and one for the coil.
good luck....I wish I could mount a pillar pod.....stoopid side airbags.....Im looking to get the ATI center pod for mine.
Old Dec 15, 2006 | 05:16 AM
vvtiTc06's Avatar
WOW thanks! imsono___un that will help a lot i read the first few pages and i think i found the colors i needed! i was about to buy that too but i desided not too after a while!
tCTaco...I almost got the ATI pod too i even made my own out of fiberglass first was not happy with it and decided to go with Autometer and i am very happy now but having a side airbag may be a bit of a issue even though i heard it comes out from the head liner.
thanks! I think ill try hooking it up tomorrow now! ill let you guys know how it goes.
Old Dec 15, 2006 | 04:41 PM
vvtiTc06's Avatar
It WORKS it WORKS!!!!!!!! that TRD DIY on shift light worked GREAT ill take some pics later THANKS GUYS
Old Dec 15, 2006 | 05:09 PM
jjos1's Avatar
Nice, where did you get the paint from ? the color looks pretty close. Also how was the fit ? I have the cc one and the bottom does not fit the way I want si I was thinking of getting the autometer one.
Old Dec 15, 2006 | 05:10 PM
AbstractRacing's Avatar
Looks pretty nice.
Old Dec 16, 2006 | 11:10 PM
vvtiTc06's Avatar
The Fitment is great! the instructions tell you to place it over your stock A-piller and use these plugs and drill into stock A-piller t mount it. i did not like the idea i just used the pod as a direct replacement for the A-piller and it fit perfect. no gaps or any thing and as far as getting it to stay ill have to take pictures it hard to say how i did it. For the Color i took a plastic part of the hatch that is the same color as the A-piller took it to a Orilleys that has a pint station and left it over night to get color match and placed in a regular spray can! it cost me 20$ not bad. I will take more pictures and post them tonight if i can on how it mounted and the gauge working it pretty nice very accurate!
Old Dec 17, 2006 | 12:00 AM
vvtiTc06's Avatar
more pics and fitment!
If you look close that the red circles those are the black plugs it came with that will snap it in place i decided to drill though the black liner on the side of the door there and though the edge of the pod behind it to hold it up and unless i show you or tell you to look at it you would never see it! it a real clean install.
Here are some more of it working the small version if you want the big go to my page http://www.cardomain.com/ride/2515309/2
in that last pic you can change the shift light color to about 7 different colors i like green! it also comes with 4 shift points and a lunch point! and few other option i still have to learn!
Old Dec 17, 2006 | 12:40 AM
nauticac's Avatar
Is that the Autometer gauge pod?
Old Dec 17, 2006 | 07:11 AM
vvtiTc06's Avatar
yes!
my06tc
Jun 25, 2015 12:18 AM
Frustratez
Feb 26, 2015 04:03 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
