PLX SM-AFR Wideband
Old Nov 17, 2006 | 04:02 AM
bkuhl's Avatar
Default PLX SM-AFR Wideband
Has anyone installed this yet? I have one but I don't have a soldering gun yet and I'm in the middle of a move and my car is sitting on a boat waiting to be shipped to England.
Old Nov 18, 2006 | 05:57 AM
bkuhl's Avatar
buuuuuuump after topic was "moved"
Old Nov 18, 2006 | 03:30 PM
tikbhoy's Avatar
the sm + dm products barely came out
the sm afr doesnt come with a display
Old Nov 18, 2006 | 04:16 PM
Prototype_xB's Avatar
http://plxdevices.com/products_SMAFR...FSRFGgodnjEwPg
Wow, thats a nice looking product for $200. What do you need to soder? Use splice clips
Old Nov 18, 2006 | 04:29 PM
jwaggz82's Avatar
Default Re: PLX SM-AFR Wideband
you need to cut a hole in your spipe and weld the bung in - you cant solder it.
Old Nov 18, 2006 | 04:47 PM
zer0's Avatar
Im selling my M-300 for one. :D
Old Nov 18, 2006 | 08:27 PM
bkuhl's Avatar
I'm referring to the sensor module. It requires that you connect it to your ignition power source. The 2.1mm 12-18v power connector for the sensor module (the little red box) isn't attached to any cables so you are required to solder the wires to the power plug and then attach it to the IGN pwr src (and attaching the ground as well.)
Old Nov 18, 2006 | 08:49 PM
bkuhl's Avatar
Here's the kit:
Here's the connection side of the Sensor Module:
Old Nov 19, 2006 | 03:10 AM
jwaggz82's Avatar
just tap into your cig lighter.
Old Nov 19, 2006 | 02:48 PM
bkuhl's Avatar
I don't smoke so I've never used the lighter...but I believe that it's an always on power source am I correct?
Old Nov 19, 2006 | 03:00 PM
jwaggz82's Avatar
yes.
Old Nov 19, 2006 | 03:05 PM
bkuhl's Avatar
then wiring the sensor module to the cigarette lighter would mean that the gauge [and O2 sensor] will be on even when the car is not. I guess if I took that route I would need to add an inline switch to the power line. That's why it says to hook it up to the IGN power.
Old Nov 19, 2006 | 03:22 PM
zer0's Avatar
no the cigarette lighter isnt always on, its a good source for power for gauges. the guage will only be on when the car is on.
Old Nov 20, 2006 | 03:35 PM
BOXMAN's Avatar
^^^ Correct^^^
Old Nov 20, 2006 | 03:57 PM
splice the power into the AUX cig outlet in the armrest if you use anything on the main cig outlet like a radar detector or something. I spliced my AEM UEGO into this and found out today that it is NOT an always on source. I even switched the circuit and feel so stupid now
(Its an excellent Ignition ON I & II 12v source.)
Old Nov 20, 2006 | 09:34 PM
bkuhl's Avatar
so the questions now are:
1) what gauge is the wiring for the cig lighter
2) butt splice or vampire taps
Old Nov 20, 2006 | 11:51 PM
jwaggz82's Avatar
you can use that wire for anything you dont want constant power going to (so any kind of light that you want turned off when the car is off) or put your gauges on the parking lights so they only go on when your parking lights are on.
Old Nov 21, 2006 | 12:51 AM
bkuhl's Avatar
i meant gauge as in wire diameter...
Old Nov 21, 2006 | 01:31 AM
zer0's Avatar
18 I believe
Old Nov 21, 2006 | 01:51 AM
ERIC-TC's Avatar
Nope it's actually closer to 20. I can't believe they would use 20 gauge for a 10A circuit but they must plan on the fuse taking care of any issues... I used the cubby-light (white and green wires) to power the back-light on my gauges.
