question...? tein S techs and tire alignment
Old Nov 20, 2006 | 12:08 AM
professor-xb's Avatar
Default question...? tein S techs and tire alignment
I installed tein S Tech spings on my xb that lowered it about 1.75 IN , then i put on some 17 inch wheels and tires , i noticed exesssive tire were on the inside of the tire (the front is bad ) My question is , if i take it for a wheel alignment, will they be able to adjust this ... or will i need to buy a camber kit or somthing of that nature?
thanks in advance for your responce...
Old Nov 20, 2006 | 04:29 AM
thegoatlord's Avatar
from what i have always read, whenever you do anything to your suspension to go get it aligned.
but as for specifics, i draw none to mind
Old Nov 21, 2006 | 01:47 AM
Default ok thanks
i guess i will find out when i take it to get alligned
Old Nov 21, 2006 | 05:31 AM
Scibox's Avatar
An alignment will fix your excessive tire wear. If this doesn't help, try getting some camber bolts. It will be cheaper and easier if you installed the bolts yourself rather than having a shop do it for you. About 8 years ago, Discount Tires raped me for 120 dollars for two camber bolts and installation. Believe me, it didn't feel too good. The bastards could have at least lubed me up with some Astroglide first!!
afoulk
Dec 31, 2016 02:53 PM
Icanmanifest
Apr 9, 2015 02:10 AM
sciontcguy15912
Mar 24, 2015 12:36 PM
sciontcguy15912
Mar 21, 2015 03:58 AM
yardleyTC
Mar 6, 2015 10:03 PM
