View Full Version : need help on side mirror removal
Sid_xBicious
08-02-2004, 06:56 PM
I already took off the 3 nuts holding it. but can't find the harness head/end. how do i take off the harness?
thank you so much,
sid
TheScionicMan
08-02-2004, 07:59 PM
There should be a couple of screws underneath, and in the door. I'm not sure which ones you have already done.
Sid_xBicious
08-02-2004, 08:03 PM
yes i also tried to take off the star screws but no luck, no harness head.
any body knows how to take off the door panels?
thanks,
sid
Sid_xBicious
08-02-2004, 08:22 PM
nevermind, that freaken harness is inside the door panel. door panel has 2 screws and i pop screw out side. after taking that off, i began to pull the panel from the bottom first then lift up.
thanks,
sid
TheScionicMan
08-02-2004, 08:23 PM
That's an easy one. Theres a screw in the door handle and the pull handle and a faky screw tab thing near the front edge of the door panel. Remove those, grab the bottom of the door panel and pull outward. It has several plastic clips that hold it on. They slip into the brackets, not like the old ones that were glued on and would break off.
Pull the panel outward. Unhook the wiring and lift the panel over the locking rod.
TheScionicMan
08-02-2004, 08:25 PM
Damn, see you can take this things apart faster than WRITING about taking them apart. :lol: :wink: I love the Box...
Sid_xBicious
08-02-2004, 08:43 PM
thanks, every help counts!!!
sid
