As soon as I started to paint my calipers it started to rain
Old Nov 22, 2006 | 09:49 PM
TSXB's Avatar
Default As soon as I started to paint my calipers it started to rain
But I do what I gotta do...
Color doesn't match, but I found that out too late. Maybe it'll look better in the day time. (Pix coming soon)
My first time ever removing a tire and painting with a brush I think it turned out okay
Before:
After:
More pix can be found on my car domain site in my signature.
Old Nov 22, 2006 | 10:18 PM
Jason_AZ's Avatar
it doesnt look that bad, a little orange-ish but waay better than stock
dcmcelreath's Avatar
Looks mighty good
As far as the color matching goes, once they bake from the heat of the brakes it might get closer. Still lookin good
Old Nov 22, 2006 | 10:37 PM
chubster41's Avatar
doesnt look bad...I like it
props
Old Nov 22, 2006 | 10:59 PM
UBOW's Avatar
I painted mine with yellow caliper spray paint from AutoZone. The color match was perfect and lasts about 15 months. It is time to redo mine as they are now faded - particularly noticable on the rear drums.
Old Nov 22, 2006 | 11:38 PM
Jenna's Avatar
I think it looks just fine. If anyone stupidly mentions "Hey, you're caliper doesn't match your car", give them a look as though they're completely stupid and tell them that you meant it to be different shade.
Old Nov 22, 2006 | 11:50 PM
Max's Avatar
Max
Any plans on painting the drums? They like to rust after a year or so.
Me? I powdercoated mine.
Old Nov 22, 2006 | 11:54 PM
flintgauge86's Avatar
Looks good! Painting your calipers is a very inexpensive way to spice up your ride a bit. Makes your rotors and rims stand out even more! Good Job!
Old Nov 23, 2006 | 01:35 AM
UBOW's Avatar
I wanted to powdercoat mine, but my wife was fresh out of bright yellow eye shadow.
Old Nov 23, 2006 | 02:30 AM
YELOSUB's Avatar
Wagonistas
Very nicely done!
Old Nov 23, 2006 | 04:45 AM
TSXB's Avatar
What exactly is powdercoating?
Thanks everyone...I tried
Old Nov 23, 2006 | 01:48 PM
UBOW's Avatar
Powdercoating is a coating process where the metal or metalized part you are wanting to "paint" is given an electrical negative, or ground, potential and the spray gun has a positive charge potential. When the spray gun trigger is open the positively charged powder is attracted to the negative, or grounded, part and the powder sticks to it like lint sticks to clothing because of static.
Next, the part is placed in an oven and is baked. The heat causes the powder to begin to liquify. At that point it is important to move the part to a cooling area for the paint to dry or runs may start.
For some plastic parts that can handle the heat the part is first sprayed with a metalic primer. This provides the necessary electrical conductor for the voltage differential for the poweder to be attracted to the part.
HTH
Old Nov 23, 2006 | 02:10 PM
p2filz's Avatar
HTH
couldnt have said it better myself
Old Nov 23, 2006 | 09:24 PM
TSXB's Avatar
How much does that run?
Old Nov 23, 2006 | 09:32 PM
UBOW's Avatar
Too many variables to give you an adequate answer. You have the total square inches to be covered, areas to be masked, thickness and type of coating, plus the type of finish you want to end up with. You should check with paint shops in your area and bring them the piece if you can.
One good point to bring up, powdercoating is a stronger coating that regular painted coatings.
Old Nov 23, 2006 | 10:16 PM
prboyxb's Avatar
nice clean job thank god you didnt know how to.
Old Nov 24, 2006 | 01:20 AM
TSXB's Avatar
lol, why do you say that?^^
Old Nov 24, 2006 | 01:46 AM
keg79's Avatar
good job
Old Nov 26, 2006 | 02:25 AM
Bartx7000's Avatar
KAD
Now it is time to blacken out the wheel wells. I painted my calipers red but I noticed how the wheels wells were kind a mix of overspray color of the body and the green oxide primer that Toyota uses. It is another cheap mod that i think improves the look of the car. Especial a light colored xb .
Old Nov 27, 2006 | 02:55 AM
TSXB's Avatar
^How do I do that? Spray paint the inside?
