tattoo2u
08-03-2004, 01:11 AM
Does any know where to get a hitch for the xB? I know the book says towing is not recomended but they make a hitch for the Matrix and it says the same thing. I just want to tow a motorcycle not a yaht.
Thanks for any help. :?:
Fr8mvr
08-03-2004, 02:32 AM
http://www.scionlife.com/forums/viewtopic.php?t=7645&highlight=trailer+hitch
http://www.scionlife.com/forums/viewtopic.php?t=20412&highlight=trailer+hitch
LeetXB
08-03-2004, 03:45 AM
You folks are pretty good at staying between the lines for people who bought such a different car. 350Lbs for the bike and a trailer that will likely be less than 500Lbs does not mean you are going to fly off the road instantly. Towing a trailer can increase your braking distance by 100% or more easily. If you have never pulled a trailer I'd start off light, (pull lighter loads a bit to get a feel for it, you will have to modify your driving habits significantly) but I believe the echo is rated for 2000Lbs trailer weight. And before it comes up, GVWR is not the number to look too for towing capacity - but could give you an idea of a limit you'd certainly be safe at. Towing capacity is always significantly higher than GVWR. As far as the short wheel-base, I towed quite a few trailers with my Broncos and it was great: I never had any problems underway - and was fantastically maneuverable backing and forward. Actually, it would have been possible to damage the truck with the trailer by turning to sharply and I wonder if this might be one reason why they suggest against pulling a trailer.
