View Full Version : Discrete amp mounting
BumperLT 11-25-2006, 05:33 AM I am ordering a elemental designs box, and I want to mount the amp somewhere that isn't too intrusive. Also, the car only has 540 miles on it so I am trying to avoid any cutting, or slicing the fabric to sneak wires... its not a 93 Honda Civic :no: :P
So, show me some pics of some nice cleanly mounted amps!
jetlounge 11-25-2006, 05:37 AM behind one of the rear side panels will do...forward of the rear wheel well there is plenty of room.
BumperLT 11-25-2006, 05:43 AM Are those panels a pain to take off and replace?
jwaj2002 11-25-2006, 06:26 AM you need to worry about the heat in one of those panels, you want it where the amp can breath and stay cool
BumperLT 11-25-2006, 07:00 AM I understand, but its not going to be pushed much, while it may get wamr, im not going to push it to its limits and have it get hot to the touch.
jwaj2002 11-25-2006, 08:01 AM it doesn't matter, your best bet would be to build a rack that would mount behind the seats, if you wanted to get creative the back of the back seats just pops off with some christmas tree clips, you could build your rack, hide the amp in there and run the wires down the bottom and through the bottom of the back, just mount a little 12 volt pc type fan in the back of the seat and when your running it, leave a few of the clips out of it
ADRdesignCo 11-25-2006, 10:30 AM im not too sure which box you are getting.. but you can cut the foam part in the cubby hole on the right side to fit your amp then add a fan to get air cirulating. if not that i agree with the mount it behind the seats idea, just to keep it clean. and if you have access to a fish tool, you can skip the worry of taking the rear area apart. thats what i did and it was alot easier :)
jwaj2002 11-25-2006, 03:23 PM you'll still wanna take the seal plastic and kick panel out, I intend to mount mine in the back, and I'm thinking about mounting the sub amp in the back of the seat, but I can't mount the five channel anywhere descrete, once I get it, because its 2' by 1' by 3"
Toast89 11-25-2006, 03:34 PM here is my box and amp setup. i have the eD nine.2 amp and it sits perfectly in the center of the spare tire...
http://i35.photobucket.com/albums/d200/imjustakid318/boxamp2.jpg
kurt26 11-25-2006, 04:25 PM I have my amp mounted under my passenger seat and its the perfect spot... its been there for over 2 years no problem.
jwaj2002 11-25-2006, 04:31 PM mines under the drivers seat in my box, I'm not running but about 250 watts to two tens, but I had it cranked up decently last night and it was actually bouncing my suspension really good, I kept shutting the stereo off to see if someone was screwing with me
jwaggz82 11-25-2006, 04:31 PM First - find out what kind of heat that amp throws while on for a few hours. Thats going to help you w/ your decision. Some amps get hot while others barely get warm. It all depends on the quality of the amp and how long its on for. Second - you can drill the amp to the box w/ short screws. That prob will be the easiest way. You only need very short screws to hold an amp in.
Spect2K3 11-25-2006, 05:29 PM http://www.scionlife.com/forums/viewtopic.php?t=103100&start=0
This will give you some ideas as to what you can do.
jetlounge 11-26-2006, 02:55 AM my jl has been behind the rear panel for a year, no problems. don't know what you guys are talking about with 'fans'.
there is plenty of space in there and ventilation.
ADRdesignCo 11-26-2006, 04:10 AM its in the cubby hole area. and i currently have an audiobahn which runs fairly hot.. thats why i needed a fan. its also a safety issue too to make sure the thing doesnt always go into thermal protection mode.
jetlounge 11-26-2006, 02:01 PM ok well. maybe the jl audio just doesnt run as hot. i have never gone into a thermal protection mode.
when you say 'cubby hole', do you mean the styro foam storage area to the right of the spare tire? everytime you say cubby, i think of the little space in front of the gear shift and i think, "man, that is one TINY amp you have. i need to get one of those!"
nebster 11-26-2006, 02:33 PM the ed amp will be fine behind a rear panel. Mandos says its ok and considering he works with ed i think it will be fine. if not just return it. you do have a 3 year warentee
jwaggz82 11-26-2006, 03:48 PM the ed amp will be fine behind a rear panel. Mandos says its ok and considering he works with ed i think it will be fine. if not just return it. you do have a 3 year warentee
dont you have an ed amp?
nebster 11-26-2006, 03:59 PM yeah? whats your point
L4rry_B1rd 11-26-2006, 04:01 PM you need to worry about the heat in one of those panels, you want it where the amp can breath and stay cool
no heat issues, Mandos already demonstrated that it works fine...
ADRdesignCo 11-26-2006, 04:02 PM ok well. maybe the jl audio just doesnt run as hot. i have never gone into a thermal protection mode.
LOL! i would want one too that small. lol. yea that styro thingy next to the spare tire.
jwaggz82 11-26-2006, 04:04 PM yeah? whats your point
point is you should have the best idea how hot they get.
nebster 11-26-2006, 04:11 PM my install is still going. i haven't had a chance to fire them up yet so no i wouldn't know.
