Old_Punk
08-03-2004, 06:42 PM
I saw a square exhaust tip I figure would be perfect for my xB. Square for the square. The question is, how do I get the factory tip off? Brute force?
View Full Version : Removing factory exhaust tip. Old_Punk 08-03-2004, 06:42 PM I saw a square exhaust tip I figure would be perfect for my xB. Square for the square. The question is, how do I get the factory tip off? Brute force? JDMbB 08-03-2004, 06:59 PM it is a pain in the ___. i think it pretty much is brute force. i raised the little flaps and then with a hammer and screw driver, i carefully began to lossen it up and it should wiggle off. be very careful if you use a hammer and screwdriver not to mess up the actual muffler piping. Al-Truistic 08-03-2004, 07:13 PM Yeah, many people have said how tough it is to get off, your going to have to just put some muscle into it. The easiest way is to just get an aftermarket exhaust...LOL :D ...that's what I did :wink: ... Pimpe_Ok 08-03-2004, 07:32 PM lol i took mine off it was a pain i just took it of like opening a can just tore the hell out of it it is only week aluminum any way lol i love my new tip though totaly worth it i say go for it....... 8) Houston40387 08-07-2004, 08:11 PM thats what i did but then it stopped tearing so I took my car to a friends house and we sawed it off. It was a pain half of it is still on but with the new exhaust tip it looks awsome 08-08-2004, 06:56 AM that tip is a pain in the ___ to take off!!! When I install tips on stock muffler, I get all cocky and remove the muffler and chop the tip off in half to remove it!! :lol: You will not be able to just pound it out, trust me!! :o RPMxB 11-16-2004, 11:11 PM that tip is a pain in the ___ to take off!!! ... You will not be able to just pound it out, trust me!! :o Today I installed my new Scion/Valor exhaust tip. I read so many posts that the stock tip was very difficult to remove. Then I read other posts that said it was easy and came right off. So I went in for battle. :twisted: BIG HAMMER; 2 vise grips, cold chisels; blade screwdrivers, etc. I shot it up with WD-40 and tapped it 3 times on each side with a heavy cold chisel (no hammer at all) and it popped right off. It wasn't even damaged. I read so much about others having problems that I think I did a mental Zen thing on it by my intense prep. :lol: I love my new Valor tip. Heavy duty, double wall construction... really a nice piece of work. I think it looks great. :P RPM Soon2BxB 11-17-2004, 12:46 AM that tip is a pain in the ___ to take off!!! ... You will not be able to just pound it out, trust me!! :o Today I installed my new Scion/Valor exhaust tip. I read so many posts that the stock tip was very difficult to remove. Then I read other posts that said it was easy and came right off. So I went in for battle. :twisted: BIG HAMMER; 2 vise grips, cold chisels; blade screwdrivers, etc. I shot it up with WD-40 and tapped it 3 times on each side with a heavy cold chisel (no hammer at all) and it popped right off. It wasn't even damaged. I read so much about others having problems that I think I did a mental Zen thing on it by my intense prep. :lol: I love my new Valor tip. Heavy duty, double wall construction... really a nice piece of work. I think it looks great. :P RPM agreed ---- i got the VALOR tip and it looks AWESOME .. and i had no trouble getting the tip off got underneath the car and took a flat tip and hammer and banged it off... no problems at all i think every xB should be rocking the VALOR tip - it looks so dumb without anything there RPMxB 11-17-2004, 02:11 AM agreed ---- i got the VALOR tip and it looks AWESOME .. and i had no trouble getting the tip off ... got underneath the car and took a flat tip and hammer and banged it off... no problems at all ... i think every xB should be rocking the VALOR tip - it looks so dumb without anything there Yes, I read your post where you previously said: its real easy .. i just tapped it off from underneath with a flat head screwdriver and a hammer ... then the other one slides right on perfectly (made for the xB) and clamps down .. VOILA ... done its DEF worth the 41 shipped You were one of my inspirations. Thanks. :D RPM T_Dot 11-17-2004, 02:30 AM hammer and a flat head. you can push it off really easy BrockAbabba 11-17-2004, 05:44 AM Kinda like anything on your truck. The sooner you do it, the easier it will be. Once stuff gets corroded and set in..... I sure am glad I painted my brakes after 3000 miles. If I hadn't, it would be ten times the job this spring! T_Dot 11-17-2004, 09:51 AM Kinda like anything on your truck. The sooner you do it, the easier it will be. Once stuff gets corroded and set in..... I sure am glad I painted my brakes after 3000 miles. If I hadn't, it would be ten times the job this spring! i did mine as soon as i got the car. which is probably the main reason why it took only 5 mins. most of that time was used on trying to figure out what tools to use. from there, it only took 2 hits of the hammer. beioski 11-17-2004, 05:16 PM I tried doing this a few weeks ago, but i got scared because of how it i had to hit it with a hammer. I was afraid I was going to rip off the entire muffler. Is it possible to damange your exhaust by banging off the muffler tip? RPMxB 11-17-2004, 05:34 PM ...Is it possible to damange your exhaust by banging off the muffler tip? I think it is possible to damage the muffler and exhaust. Fortunately, mine popped right off. If yours is stuck, I suggest having a second guy, wearing leather gloves, hold the exhaust pipe while you bang on it. Definitely use WD-40 and strike it in the tip's middle where the sides stick out. Alternate between left and right sides. Good luck. :D RPM Cameron 11-17-2004, 05:59 PM Yaaayyyy. Square tips rock! I did mine too. Check my thread link for installation, part number and pictures :D http://www.scionlife.com/forums/viewtopic.php?t=30680&postdays=0&postorder=asc&start=0 inspyre5 11-17-2004, 09:47 PM Did mine today.. the tip came off after tapping it with a hammer a few times. Thanks for your help guys. 8) http://users.adelphia.net/~everette55/images/personal/2004_1117_153004AA.JPG http://users.adelphia.net/~everette55/images/personal/2004_1117_152850AA.JPG T_Dot 11-17-2004, 10:03 PM Is it possible to damange your exhaust by banging off the muffler tip? if you are careful enough nothing will happen. it will be pretty obvious when something is being damaged. fyi just like i said before it took 2 swift hits, and it was off. worse come to worse, take it to the install shop that is going to put your tip on for you. removing the existing one should be free. WhEeLiEz 11-20-2004, 04:25 AM does a different tip change the sound of the exhaust? Soon2BxB 11-20-2004, 04:35 AM does a different tip change the sound of the exhaust? the valor tip did not change the sound of the stock exhaust Kruzr2andxBtoo 11-21-2004, 05:58 PM A little WD40 and a pair of gloves , a little muscle ,... and it came right off... Guess I was lucky..... Is there a good on line store that sells the Valor Tip??? Kruzr2&xBtoo inspyre5 11-21-2004, 06:18 PM Is there a good on line store that sells the Valor Tip??? Kruzr2&xBtoo The Valor tip is nice.. but I would check local muffler shops to see what they have too. You might like a different look on yours.. then the shop can weld it on for you for $5 or $10 bucks. RPMxB 11-21-2004, 06:27 PM ...Is there a good on line store that sells the Valor Tip??? I got mine from ScionSport.com: http://scionsport.com/store/index.php Exhaust Tip by Valor Manufacturing, Part # PTS18-52040, $38 + S&H http://scionsport.com/store/product_info.php/products_id/220? http://scionsport.com/store/images/xB_exhausttip.jpg You may also consider Partznet.com, although I have no experience with them. Valor tip: $34.80 + S&H http://www.partznet.com/toyota/scion/accessories/exhausttip.html :wink: RPM pileofmonkeycrap 12-06-2004, 02:28 AM Figured I'd add to this thread because 10 minutes ago I removed my stock tip. A few sprays of Liquid Wrench and tapping with a hammer and flathead made quick work of the tip. I installed a large round/slanted tip that filled the opening nicely. I'm looking for a large square tip, but so far the ones I've seen look too small. But for now this $9 tip looks much better than stock. :D MotoMan_YZ400 12-06-2004, 06:14 AM Did mine today.. the tip came off after tapping it with a hammer a few times. Thanks for your help guys. 8) http://users.adelphia.net/~everette55/images/personal/2004_1117_153004AA.JPG http://users.adelphia.net/~everette55/images/personal/2004_1117_152850AA.JPG Hey i like that... where did you get it, and how many dead presidents? inspyre5 12-06-2004, 07:12 AM Hey i like that... where did you get it, and how many dead presidents? I picked it up at a local muffler shop. The tip with weld install totalled about $50. The tip is a little more expensive than the others I saw at the shop but it had a "beefy" look to it. It also has an incription on the top that says "Silverline". 8) spstar 12-06-2004, 04:04 PM Mine came right off with a slight tap with a big screwdriver and hammer I then replaced it with a 4" chrome tip from Wal-mart auto dept $12.44 it sure beat the $79.00 price of theTRD tip at the dealership :D kacosta 12-06-2004, 04:25 PM the stock tips is installd like a chinesse finger trap try bending out the bent in flat portions with a screwdriver then rotateing left and right while pulling out pain in the a pileofmonkeycrap 12-06-2004, 04:46 PM Mine came right off with a slight tap with a big screwdriver and hammer I then replaced it with a 4" chrome tip from Wal-mart auto dept $12.44 it sure beat the $79.00 price of theTRD tip at the dealership :D My tip was from Walmart also. I had originally bought a few from Advanced Auto so I could decide what I liked best and return the others. Then when at Walmart I checked out their tips and found a better one for $9 or so. The comparable tip from Advanced Auto was $20. i'll have to take some pics and post. |
