FUEL PUMP HELP!
Old Nov 27, 2006 | 07:02 PM
318_tC's Avatar
Default FUEL PUMP HELP!
Ok, is the Install Kit a have to buy? If I can get just the pump, do I need the install kit? DIY write up anyone? What all did u have to splice? Help?
Old Nov 27, 2006 | 08:15 PM
paul_dezod's Avatar
Scionetics
KAD
Default Re: FUEL PUMP HELP!
Here is a pic of the Supra one.
Old Nov 27, 2006 | 08:21 PM
318_tC's Avatar
I was told i didnt need to buy the install kit that i can splice and install the new one? Im just trying to make sure,
Old Nov 27, 2006 | 08:23 PM
paul_dezod's Avatar
Scionetics
KAD
Either way. Install kit just makes life a little easier and a tad cleaner.
Old Nov 27, 2006 | 08:27 PM
318_tC's Avatar
Gotchya! Thanks paulie.
Old Nov 27, 2006 | 08:30 PM
paul_dezod's Avatar
Scionetics
KAD
Welcome Jeff!
Old Nov 27, 2006 | 09:49 PM
unvdistc's Avatar
At what point do you think the fuel pump is needed? HP numbers?
Old Nov 27, 2006 | 10:06 PM
paul_dezod's Avatar
Scionetics
KAD
That is based upon BSFC used on the car. When you try to add more fuel and it just will not add it and your injectors have a fair amount of fuel to push, this is when a fuel pump and/or regulator is determined.
Old Nov 28, 2006 | 01:18 AM
unvdistc's Avatar
^^^sweet thank you... im running 550 injectors so as soon as i start running lean after tuning i should look into a fuel pump......
Old Nov 28, 2006 | 01:24 PM
318_tC's Avatar
^Are you tuned yet?
Old Nov 28, 2006 | 04:05 PM
BOXMAN's Avatar
Which pump did you go for? Also any word from BDL?
Old Nov 28, 2006 | 04:25 PM
318_tC's Avatar
No word from them....
Universal Walbro 255 and you have to have the install kit to install the pump cause the clip from the factory pump is much smaller then the walbro one and you have to hardwire the pump.
Old Nov 29, 2006 | 01:47 PM
bluesciontc's Avatar
It is the same part number as a STI by the way. There is a site out there that you can get it for $71. Also how easy is it to get to the fuel pump?
Old Nov 29, 2006 | 02:05 PM
318_tC's Avatar
You want the 342 Pump and Supra Clip.
Pretty Easy
Take the backseat out, like 10 screws, unclip 3 harnesses, pull out, disconnect, un assemble the shell, put new pump in, reinstall
Old Nov 29, 2006 | 04:23 PM
supdawg240's Avatar
so there a clip you need to buy to install a aftermarket fuel pump? any site
318_tC's Avatar
Dezod.com
Old Nov 29, 2006 | 04:33 PM
supdawg240's Avatar
deaod only sell fuel injector no fuel pump
Old Nov 29, 2006 | 04:35 PM
supdawg240's Avatar
where can i find the supra clip?
Old Nov 29, 2006 | 05:28 PM
318_tC's Avatar
dezod.
Old Nov 29, 2006 | 05:36 PM
paul_dezod's Avatar
Scionetics
KAD
http://www.dezod.com/pd_walbro_fuel.cfm
