350 miles ohhhh boy
Old Dec 6, 2006 | 12:33 AM
Jiggaman's Avatar
Big Sky Scion
Default 350 miles ohhhh boy
ok i have a 2007 superwhite tc with only 350 miles on it, and i literally get like 17 mpg, and my dads 454 SS chev gets about the same!
Considering its winter here and i know that running the heater and stuff could be causing this, but will it get better once the motor gets broken in a bit more? I always get better MPG in the summer when i dont have to run the heat/AC all the time.
I have searched this topic but for some reason the search button just brings up results that have nothing to do with what i am asking.
Thanks All! - Jigg
Old Dec 6, 2006 | 12:40 AM
str8upheney's Avatar
it'll get better once your engine is broken in but with the heat on it will eat gas
OCTC's Avatar
its def not the heater cuz it doesnt run off the engine belt like ac does.
Old Dec 6, 2006 | 12:51 AM
SupaWhite's Avatar
That's really odd because I started off getting ~25 mpg when I first bought my tC. Granted, it's never really cold here in SoCal, 17mpg seems to be unusually low!
Old Dec 6, 2006 | 01:04 AM
ck123's Avatar
does the heater use more gas? i use it all the time in my civic and still get more about 33mpg
i dont own a scion but when i got my tsx, i got really crappy gas mileage, around 17 like you, now that it has 3k miles im averaging 26mpg. Should get better as you get more miles. Mine should be increasing still since honda engines take longer to break in. I heard around 10k then its fully broken in,,,
Old Dec 6, 2006 | 01:05 AM
Tcguy85's Avatar
i've gotten about 25-28 mpg ever since i've owned my 07. no matter how i drive, or if the a/c is on or what not, it seems to be about the same every tank.
Old Dec 6, 2006 | 01:08 AM
ck123's Avatar
how did u break in your car? hard or soft?
Old Dec 6, 2006 | 01:09 AM
CuRiOuSfIsH's Avatar
mechanically, only the A/C uses gas b/c it runs off the engine.
17MPG is very low, also your area might by using "winter gas" already...... and MPG is usually lower in the winter due to that.
Old Dec 6, 2006 | 01:22 AM
Jingbo's Avatar
I have about 200 miles on mine and if I keep it up, i'll get around 24-27 MPG.
and Yes, having the heat on SUCKS up ur gas like crazy, literally u can see the needle drop while driving....
so i recommend turning ur temputture control to heat and turn off the vent button which allows hot air from the engine to come inside.
ur prob getting bad milage cause all that cold air
Old Dec 6, 2006 | 01:23 AM
thekidblue's Avatar
wow I didn't know the heater uses that much.
Old Dec 6, 2006 | 01:30 AM
ck123's Avatar
just did a quick google
http://www.answerbag.com/q_view/43020/
http://answers.yahoo.com/question/in...2123558AA8T27Y
it actually saves gas and doesnt not impact your MPG
Old Dec 6, 2006 | 01:34 AM
davedavetC's Avatar
err yea you probly drive like a mad man. cuz its freezing here and i have the heat full blast and i get decent gas milage...
Old Dec 6, 2006 | 01:37 AM
yostc's Avatar
agreed. try shifting gears at a lower rpm =]
Old Dec 6, 2006 | 01:39 AM
obarajas's Avatar
Marvelous Scions
I'm getting 17mpg too since i bought my tc 2 months ago. i took it to the dealer when it had 1000 and they told me it was kind of early to do a test on it so to bring it back it when it has about 1500 well yesterday reach 1500 so I will be taking it in so they can check it again.
Old Dec 6, 2006 | 01:43 AM
djct_watt's Avatar
Team Sushi
What the heck are you guys talking about? Heat sucking gas? I dunno bout you, but this would be a MAJOR downgrade from what ALL cars have been doing for the last half century!
And you're needle will not drop while revving, as it does not use much gas at all. There is no load on the engine. . . are you holding the throttle at red line or something?
Somebody's been having too much of the peace pipe. . .
Old Dec 6, 2006 | 01:44 AM
Jiggaman's Avatar
Big Sky Scion
na not all all! but yes it freezes EVERY night up here in Zootown, and days dont get very warm either- usually around 30-40 here! damn you cold weather
Old Dec 6, 2006 | 01:50 AM
Old Dec 6, 2006 | 02:01 AM
paul34's Avatar
haha. I usually just set the HVAC **** to hot and don't turn on the fan at all. Just open the vent.
That way you don't instantly dry out everything in the car, including people's throats and eyes
Old Dec 6, 2006 | 02:05 AM
djct_watt's Avatar
Team Sushi
Another way to avoid drying things out is to leave the AC off, as it removes moisture from the air when it is on.
Old Dec 6, 2006 | 02:08 AM
djct_watt's Avatar
Team Sushi
By any chance, are you one of those pople that bought a "speed chip" of ebay, and are a big fan of the tornado intake enhancer?
