Adjusting Sway Setting...
Old Dec 9, 2006 | 09:56 PM
mike6789k's Avatar
Default Adjusting Sway Setting...
...okay, so I just installed my hotchkis rear, and it isnt as tight as i want it to be, so im going to put it on race setting...
now, my question is, can I just unlink the endlink bolts on both sides of the sway, loosen the bottom bracket nut, spin the bar up a little, tightedn the lower braket nut, then put the endlink in the right hole?
do i need to torque down to spec on the lower braket nut and the endlink nut? that would be a serios pain, i cant even fit my torque wrench on the endlink nut, so i just did "very tight" with a closed end box wrench...
my bracket bolts though i did torque to 32ft-lbs, it is so tight that the sway bar will not spin in the bushings even if you were to unlink the end links, is that how it should be?
thanks!
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
SloTC1
Aug 16, 2018 02:45 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
Subaru86
Jul 31, 2015 04:00 AM
