JasonH
08-06-2004, 08:22 PM
I took yesterday off from work and installed my factory Bazooka VSE sub and the amber factory interior lighting kit. As always, I bought my stuff from McGeorge Parts (http://www.mcgeorgeparts.com). Go buy stuff from them so they can keep offering the best prices on Scion and TRD accessories! I even got FREE TRD valve caps! How's that for service!
Anyway, I installed both at the same time, as recommended by the installation instructions. I won't give every step, but I'll try to point out a few things I found tricky. Per the instructions, remove the negative battery cable. Basically, you start by ripping your interior apart. As many have said, it's pretty easy to take out the shifter surround, stereo surround and other interior panels. Make sure you have a clean surface to put everything on (like a blanket or something,) since you'll end up with quite a pile of parts that you don't want to damage:
http://www.scionlife.com/tech/images/sub_and_lighting_tc/parts1.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/parts1.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/parts2.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/parts2.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/parts3.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/parts3.jpg)
Taking everything out is easy, with one exception: the passenger side plastic cargo hook at the upper rear of the trunk. It has a small hole that you need to shove something in to release the clip. I did not have a small enough screwdriver (and I have a lot of screwdrivers) so I ended up using a small allen key. With a little fiddling, I got it to release. If you don't release the clips, you will probably damage the hook or panel removing it, so take your time and find something suitable to "pick the lock" as it were. Once everything is out, your car will look like this:
http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior01.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior01.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior02.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior02.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior03.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior03.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior04.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior04.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior05.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior05.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior06.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior06.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior07.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior07.jpg)
(You don't have to remove the cupholder unless you're doing the lights.)
I also found the place for the cabin filter, so I took some pics. Does anybody know if the Corolla or Matrix filter fits?
http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior08.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior08.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior09.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior09.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior10.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/interior10.jpg)
So, back to the project at hand. Once you have your interior apart, it's time to straighten out your subwoofer wiring harness and route it through the car along the passenger side. Not difficult, just follow the directions. Make sure your subwoofer connector reaches to almost the back of the car. You have plenty of harness length and you don't want to get it all in only to find out you can't plug in the sub.
One modification I made was to add a switch to the remote wire for the sub. Normally, it's on whenever the ignition is turned to "ON" or "ACC". With the switch, I can turn it off even if the stereo is on. I figured this would be much easier than having to turn the bass on the head unit all the way down when listening to Howard Stern or whatever. It's easy to do: Find the blue/white wire going to the subwoofer and cut it near the stereo connector. Strip the ends, add enough wire to each to get to the switch panel on the left of the steering wheel, then install a SPST switch (single pole, single throw = least fancy kind of switch.) My subwoofer switch is on the right. Down is on, but you can do it however you want:
http://www.scionlife.com/tech/images/sub_and_lighting_tc/switches.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/switches.jpg)
Now you'll want to prepare the sub to go in. You need to remove the speaker grille and remove the driver. A blue nylon cord was on mine, pull the cord hard and the grille will come off. The cord isn't attached to anything, so remember to reinstall it later if you want to get the grille off easily (the gain control is behind the grille.) The quality looks pretty good. It almost looks like a custom sub, kind of hand-made. I don't think these are rolling off a huge assembly line. It seems very solid and fits the car perfectly. Even the driver is a decent dual voice coil unit with a good deal of heft. Here are some pics of the sub and driver:
http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub01.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub01.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub02.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub02.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub03.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub03.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub04.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub04.jpg)
http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub05.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub05.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub06.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub06.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub07.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub07.jpg)http://www.scionlife.com/tech/images/sub_and_lighting_tc/driver1.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/driver1.jpg)
http://www.scionlife.com/tech/images/sub_and_lighting_tc/driver2.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/driver2.jpg)
Once the harness is run, you'll mount the hardware for the sub. Once the upper hardware is mounted, you'll get to a step that I found confusing, about using a 5/8" punch to put a hole in a panel. Well, the panel they mean is the interior carpeted panel that will go over the bolt that the sub attaches to. You put the panel in place, mark the spot and make a hole. I used my step drill bit and it worked fine. A regular drill would be ok too.
Now you start reassembling everything. Once I finished getting the trunk area back together, I started on the lights. Once again, the instructions are straightforward. Use the templates to drill your holes. A step drill bit makes drilling the switch panel plates simple. For the cupholder holes, it calls for a "J" size bit. Well, I found out this is a little bigger than a quarter inch. I drilled a 1/8" pilot, then 1/4", then used a round file to deburr and enlarge the hole. Worked fine. You will need a rivet gun to install the under-dash lights. You can buy them cheap or borrow one from somebody. The lights go in pretty quick once you get going.
http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights1.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights1.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights2.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights2.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights3.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights3.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights4.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/lights4.jpg)
Next, I installed the sub. You might need to move it around a little to get the two bolts to line up. DON'T FORGET to put the big flat washer on the upper bolt before you put the sub in. Then the other washer goes inside the sub. Make 'em nice and tight so it doesn't move around. A stubby wrench or small ratchet will make the upper nut inside the sub easier to tighten. Then hook up and reinstall the driver. I left the cover off so I can adjust the gain until I get it "right". Here are some pics:
http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub08.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub08.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub09.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub09.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub10.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/sub10.jpg)
Next, you hook the harness to your head unit, reinstall the head unit, then replace the stereo surround/climate control panel, THEN the shifter surround. Remember to reconnect the cigarette lighter. That should be everything, clean up your tools or whetever, then reconnect your battery cable. You'll need to reset the windows and sunroof (in the instructions) and your clock and stereo settings. Here's a back pic of the single-disc head unit. The far right square connector is where the subwoofer harness connects. The one next to it is for power and stuff.
http://www.scionlife.com/tech/images/sub_and_lighting_tc/stereoback.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/stereoback.jpg)
It took me about 4 hours working steadily, but not quickly, to install all this. I took my time since I didn't want to damage anything and I wanted to do it right. The sub sounds great, although I'm still playing around with settings to get it all right. It has more than enough volume for the car, in fact, I might even block off the port to add some tightness and lower the volume. If you turn the gain all the way up, you get deafening volume from the sub with the volume at 20 on the head unit. I think my gain is set just above the middle, which really cranks at higher volumes, but doesn't overpower the music at lower ones.
The lights are cool, too, but hard to take pictures of. They match the instrument and dash lighting prefectly, and are bright enough that if you dropped something on the floor you could find it, but not so bright as to be distracting. Although the tubes are visible in my pictures, they are not visible if you're seated and not leaning over or anything.
http://www.scionlife.com/tech/images/sub_and_lighting_tc/night1.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/night1.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/night4.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/night4.jpg) http://www.scionlife.com/tech/images/sub_and_lighting_tc/night3.th.jpg (http://www.scionlife.com/tech/images/sub_and_lighting_tc/night3.jpg)
I hope you found this useful and enjoyed it. Let me know if you have any questions or comments.
