General Tech and DIY Info for Any Scion
LCD Reversal
Old Dec 14, 2006 | 10:08 AM
SquallLHeart's Avatar
Default LCD Reversal
okay... blah blah.. i'm not responsible if you mess up.. blah blah.. legal tidbit... said... done.
best method would be to completely replace the filter with a new one that has adhesive on it... but those filter sheets cost alot of money..
so.... we're just gonna reuse one in this diy, k?
oh and yes.. this can be done to ANY LCD screen.. my old calculators... the HVAC.. the uhm... yeah. whatever
first step... take out whatever from car (i.e. gauges in diy)
you don't have to take apart the gauges completely (as in the board and such... as i did in the pic..) but as long as you get to lcd.. you're good..
so.. second step... where it begins... take prying instrument (i.e.. razor blade)
aim downwards and get under that filter..
pry a little bit more (NOTE:.. do aim the blade downwards... the filter CAN get scratched.. so take it easy..)
you don't really have to do too.. much... once enough... you can grab the filter and peel off the rest.. make sure not to angle it too much either... crease in filter... hmm.. bad? ohh and do support the lcd itself... it's glass afterall...
now.. to be able to reverse the LCD, the filter needs to be flipped around.. all that adhesive crap that was on there? it needs to be removed... cause that side is going to be facing outwards now... so... use adhesive remover of choice... and soak..
blah blah... clean all that crap off... and on the lcd too.. sure...
and place it back on.. (maybe tape the edges down..) and voila!
Old Dec 14, 2006 | 10:24 AM
chadfo's Avatar
Great write-up!!!!!!
Do you have an pics of it lit in the car? If not, can you take some? Please...
Old Dec 14, 2006 | 10:30 AM
alot of pics can be found here:
https://www.scionlife.com/forums/viewtopic.php?t=151534
Old Dec 14, 2006 | 10:38 AM
chadfo's Avatar
Awesome!! Thanks!!! I see a new mod in my future.
Old Dec 14, 2006 | 10:39 AM
Runawayrogue's Avatar
What kind of adhesive you using to put it back on?
Old Dec 14, 2006 | 10:43 AM
dugzilla's Avatar
Trung, great write up! I might have to do this!
Old Dec 14, 2006 | 12:42 PM
Jdogg440's Avatar
wow, feeling dumb now, thinking it was going to be more complicated than that. Thanks for the write-up. and the point in the right direction
Old Dec 14, 2006 | 04:31 PM
ADRdesignCo's Avatar
great write up trung.. but where are the cheese nips? lol
Old Dec 14, 2006 | 05:31 PM
Keeshwah's Avatar
Any pics of this without an led swap? I wanna get something to be black background with white numbers like my alpine HU.
Old Dec 14, 2006 | 05:34 PM
b_wet's Avatar
wow i never thought of that, well i never knew one could even do that. i def have to try now.
great DIY
Old Dec 14, 2006 | 05:36 PM
Tito_Cruz's Avatar
looks much better...
Old Dec 14, 2006 | 06:25 PM
none... reusing the orginal filter.. i had to remove all of it..
hmm.. a small piece of tape at the edges will hold it in place and you wont see it after you place the gaugeface back on.
Old Dec 14, 2006 | 11:03 PM
if you want white numbers, you are going to have to switch to white LEDs or else youd just end up with orange numbers against a black bg. i have white leds behind mine to give you an idea of how white would look.
Old Dec 15, 2006 | 12:50 AM
dmyers03's Avatar
you said the filter sheets cost a lot of money. ok, if somebody happens to break one, where do you get another one from and about how much would it cost? or do you just have to buy a whole new lcd unit?
Old Dec 15, 2006 | 01:39 AM
Keeshwah's Avatar
Thanks, I get it now.
Old Dec 15, 2006 | 02:52 AM
no-tec's Avatar
you have very nice nails for a man
Old Dec 15, 2006 | 03:00 AM
titolito's Avatar
Yes, Trung is a sexy bi+ch!
Old Dec 15, 2006 | 03:59 AM
arbnpx's Avatar
So it's just a plastic layer? I was assuming originally that it would be like a laboratory slide, with two panes of glass. Maybe I should dig out one of those el-cheapo calculators I always get for christmas (I have a TI-89 as well as a PalmPilot with a program that works like Matlab) and try this out.
What's being flipped here is the front polarizing layer. Was it flipped "top-to-bottom" or "right-to-left"?
Old Dec 15, 2006 | 04:48 AM
you call a TI89 and a palmpilot cheapo? lol
and its flipped top to bottom. what was once sticky, is now the side up.
Old Dec 15, 2006 | 05:46 AM
it's more cleaner... my buddy took these pics with his camera phone.. the color is a little off.... can't beleive my nails look so ugly yellow in some pics....
break the filter? or break the lcd? you break the lcd.. you're screwed.. you damage the filter? you gotta either buy a sheet....
or sacrifice a calculator...
