View Full Version : Camry Navigation Install
wgeee7478
08-09-2004, 06:26 AM
Hey everyone, as much as I gained from this site, I would now like to donate back to it by posting this how to. It also covers removing the upper dash in case you want to paint it like others I've seen around here.
You are doing this at your own risk, I will not be responsible for screw ups! You've been warned.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0088.jpg
The '04 Camry navigation unit is a self contained unit meaning there isn't a seperate Nav ECU that you place in the trunk. However because it doesn't have an internal amplifier, it needs the OEM JBL amplifier for it's power and sound output.
I ordered the unit from Troy at http://www.oemvalue.com. For about the price of the AVIC-N1, this comes complete with the '04 Toyota Camry Navigation unit, the OEM JBL Amplifier, GPS Antenna, Wire Harnesses, and Navigation Disc. Other options you can add to it are, XM Radio, Reverse Camera, Voice Recognition, and Video Input soon to be released.
Before we begin the install you will need to remove the upper dash. You will know why later. In order to remove the dash the front radio bezel, the radio, the speedometer gauge cluster, the two small speakers on both sides of the dash, and also the A-Pillar covers all need to be removed. It's also easier to get to the VSS and Reverse wires with the upper dash off too.
- To remove the radio, pull the 3 control knobs and remove the two brass screws there.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0055.jpg
- Pull the entire radio bezel by grasping the plastic around the 2 vents and pulling with a fair amount of force. Next you will need to remove the 3 plugs connected to the radio bezel.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0058.jpg
- After that, there are 4 screws holding the radio bracket in place, unscrew these 4 screws and pull the radio out. Finally, disconnect the 2 plugs and the antenna from the back.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0060.jpg
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0062.jpg
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0063.jpg
- To remove the speedometer gauge cluster. Use a jewelry phillips screwdriver and loosen the plastic screw fastener located in the middle top of the status light area. Pull on the plastic gauge bezel with some moderate force and it should come loose. Next you will need to remove the gauge cluster, and this is done by removing the 3 screws that are around the edges of the gauge cluster. Then remove the gauge and then unplug the connector on the back.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0066.jpg
- The speakers can easily be removed by using a small flathead scredriver to pry off the speaker grill. Remove the 2 screws on the speaker and then disconnect the plug.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0071.jpg
- You should also pull the A-Pillar covers now as well. http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0074.jpg
- Now you are ready to remove the upper-dash section. In front where the radio was, remove the 3 screws there.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0070.jpg
- Remove the 2 screw from where the gauge cluster was.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0075.jpg
- Remove the 1 screw that attaches the dash to the bulkhead in each of the speaker locations.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0077.jpg
- Now, above the glove box in the storage well there is a small rectangular cover. Remove this cover with a small flathead and you should see a 12mm bolt. You need to remove this bolt because it secures the passenger airbag to the chassis support beam.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0069.jpg
- You will also need to disconnect the passenger airbag by disconnecting the yellow cable that can be found in the passenger side speaker location.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0082.jpg
- After all this, you can now pull the upper dash off with moderate force.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0084.jpg
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0085.jpg
- The best place to put the amplifier is on the driver side in the front section of the dash closest to the window. You may have to move the remote sensor control box, it's a red color box and it's bolted via bracket and 10mm bolt. It fits perfectly without modification to anything. However because it is so close to the wire harnesses located there, I went add padded the sharp edges with some weatherstrip foam tape.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0086.jpg
- Now that you have the upper dash off. This is the perfect time to splice your wires to connect the VSS and REV.
--> The VSS wire is the Puple\White stripe wire that can be found on the back of the fuse box. It's the 3'rd wire in a 18 pin plug up at top of the fuse box.
--> The REV wire is the Red\Black stripe wire that can be found on the front of the fuse box, It's one of the wires in the middle 9 pin plug.
- The radio brackets transfer to the navigation perfectly. And the display fits perfectly as well, there are no gaps on either side. It looks absolutely perfect sitting in there.
http://www.scionlife.com/tech/images/camry_navigation_xb/IMG_0090.jpg
- The best place to put the GPS antenna is in the flat section under the dash cover right above the gauge cluster. Remove the metal plate and place double sided tape on the white label side of the antenna and stick it up there.
I hope this helps you and good luck. If you are around my area I will be happy to help you out with this if you decide to DIY!
allblackxb
08-09-2004, 06:29 AM
wow very clean. Almost looks like the GPS unit in some japanese scion xb's.
DenZinz
08-09-2004, 06:49 AM
Damn! I like that!
Great job! Maybe I should 86 my indash..hmmmm....
wgeee7478
08-09-2004, 03:47 PM
Thanks for the comments guys. My wife liked the navi a lot in our E320, So she's been wanting one ever since. After I installed it, she likes the Toyota one better now, because it has more functionality then the E320's navi.
superjeer
08-09-2004, 04:27 PM
droool. That's great! I imagine I can't afford the unit though. Thanks for taking the time to write it up.
wgeee7478
08-09-2004, 04:57 PM
Hey Jere
Trust me if you can afford a Pioneer AVIC-N1, you can definitely afford this. I don't know if the mods let me place the vendor's website but here it is.
The guy who runs the place is Troy, a very nice guy and helpful.
*Mods* if the link is not allowed then I apologize and you may remove it.
Munch
08-09-2004, 05:02 PM
Sweet 8)
the_saint
08-09-2004, 07:34 PM
Looks really nice, almost like it belongs there :lol:
Pardon the stipidity, but where do the CDs go? :?
One more question (as my intrest grows) is it imperative that you get this unit with the JBL amplifier? Or can you use a line driver/output converter do-dad?
wgeee7478
08-09-2004, 07:46 PM
It's alright, asking questions is not stupid, it's not asking them when you don't know something, that's stupid.
Anyway. there is a OPEN button in the front, when you press this, the screen slides down similar to the Eclipse and Kenwood double din head units. Behind the screen are two slots, one is for CD and the other is for the Nav disc.
k4kas
08-09-2004, 09:31 PM
Man that thing is SWEET!
I want one!I may decide to sell my VRX925 indash for that mother!
I seen where they are working to use the screen as a slave.I hope that pans out.
Anyone interested in a 7"indash!!!?????
XBman
08-09-2004, 09:47 PM
i hope they put that on the TECH section
wgeee7478
08-09-2004, 10:08 PM
Yeah thanks guys for all your comments. Keep 'em coming. Anyway, I hope the mods put this in the Tech Section too, I think it'll help a lot of people out there who at least want to know how to take apart the upper dash, let alone install a factory navigation system.
dizzytc
08-09-2004, 10:11 PM
Sorry another stupid question...after looking at what you did...I dont see how it slides down so you can insert a cd...seems like its enclosed in that square area and has no way of going down...if you have a picture of you inserting a cd, that would really help...wondering would the Camry navi fit the tC?
Thanks
XBman
08-09-2004, 10:16 PM
humm i wonder if it would fit the TC? I think it prob would but u would need to install the JBL thing someware else. I think the face of the Deck does slide down. A pic of that would be nice
wgeee7478
08-09-2004, 10:18 PM
Thanks
Yeah, sorry I didn't have pics of the screen folded down to allow you to put discs in, I'll see if I can remember to take one tonight and I'll post it. Also, look on the website that I posted too. they have pictures of how the screen slides down so you can put the discs in.
I think it would fit in the tC but I'm not 100% sure because the knobs stick out a little and it might interfere with the cover. But it will definitely fit in the in the stock DIN space as it is the same exact dimensions as the Scion/Pioneer head unit.
dizzytc
08-09-2004, 10:22 PM
Thanks...let me check it out...and when you say fold out..do you mean towards you?
XBman
08-09-2004, 10:23 PM
http://www.oemvalue.com/pics/toyota/camrynav.JPG
http://www.oemvalue.com/pics/toyota/ToyotaNav2RAW.jpg
http://www.oemvalue.com/pics/toyota/toyotanavscreens/1.jpg
[/img]
Emodica
08-09-2004, 10:35 PM
So correct me if im wrong but the unit doesn't play dvd movies is that right? If so do i need to hook up a seperate dvd player to it xbox/ps2 ?
XBman
08-09-2004, 10:48 PM
yes u r right but i dont think u can hook up a DVD player to it
wgeee7478
08-09-2004, 10:50 PM
You are correct that it doesn't play DVD's. However there are a few companies that are working on video input to the system right now. And if you look at the Siennaclub.org forums, they have successfully connected the RSE (Rear Seat DVD Entertainment system to the head unit to play DVD's and have all the touchscreen controls like the factory.
And for those that are wondering, it doesn't play mp3's either, that's why I plan to put a wired RF modulator with RCA inputs to connect an iPod.
XBman
08-09-2004, 11:44 PM
couldnt have said it better myself
XBman
08-10-2004, 12:07 AM
Hey Wgee post this on the Faq page!!!!!! get it on the Tech poage
wgeee7478
08-10-2004, 12:31 AM
I tried, but it seems like only a mod can put it on there. So I guess depending on how many people think this is good information, then they will eventually put this in the Tech section.
-Keith-
08-10-2004, 01:41 AM
Hey do you have to use the JBL amp or can I use a aftermarket amp?
wgeee7478
08-10-2004, 02:16 AM
I'm not sure that you can, however I suppose anything is possible. You would have to get the pin outs of the the Navigation head unit and the pinouts of the Scion radio harness and see if you could create a new harness that would combine an external amp. I haven't really looked into this but since this is a Camry navigation unit, you could probably look around other Toyota forums to see if anyone has replaced their JBL amp with an aftermarket yet keeping their navigation unit in tact.
Spider13
08-10-2004, 03:47 AM
I wonder if our XM box will hook to this?
wgeee7478
08-10-2004, 04:09 AM
I wonder if out XM box will hook to this?
Hope this answers your question.
[img]http://img.photobucket.com/albums/v443/wgee7478/post-8-1081182577.jpg
This picture was blatantly ripped from SiennaSaurus @ Siennaclub.org, all credit goes to him as he has extensive knowledge about installing the Solara unit in his Sienna.
its_ikon
08-10-2004, 05:33 AM
added this to the tech area, but forgot leave a link in the forum
JdMBboFSD
08-10-2004, 05:38 AM
currently looking for a 04 camry navi system........haha......nice ...so jealous...
wgeee7478
08-10-2004, 05:43 AM
Thanks, been waiting for that.
wgeee7478
08-11-2004, 05:59 AM
This is in addition to the install instructions. Apparently, the JBL amp does not power the antenna amplifier as you'll notice when you compare the wire harness and your radio harness. There is one wire that is not used. So what you need to do is splice the ACC (It's the gray wire from the blue radio harness) with the ANT (the black/red stripe wire) together and then you will power the antenna amplifier when you turn on the ignition key. This is illustrated by the red circles.
There is also another wire that I didn't mention either. It's the single wire that comes attached on the Navigation wire harness and this needs to be attached to ground. Any ground will do just make sure it's grounded. I personally did not notice a difference when I didn't connect it and when I did, but that's what the instructions said so I just followed them. This is illustrated in yellow circle.
http://img.photobucket.com/albums/v443/wgee7478/IMG_0118b.jpg
I would like to thank Troy at OEMValue.com for helping me figure this out otherwise my wife would still be annoyed by the radio's weak reception. Now she's a happier person.
JdMBboFSD
08-11-2004, 06:01 AM
thanks for update.....
wgeee7478
08-13-2004, 09:20 PM
Here's yet another update to everyone who wanted to know if you can use an aftermarket amp. Well simply the answer is yes, but you may have to figure out how to splice the rest of the wires to go directly from your vehicle wire harness to the Nav unit. Here's how "petegaz" did it in his 4runner.
http://www.toyota-4runner.org/showthread.php?s=&threadid=2151&perpage=15&pagenumber=1
He also has a personal site explaining his install if you guys need more info.
http://www.norgetech.com/navsup.htm
I looking into the voice recognition right now, so I'll update everyone again later.
wgeee7478
08-13-2004, 09:21 PM
Here's a picture of what "petegaz" did if anyone wants to know.
http://img.photobucket.com/albums/v443/wgee7478/x-35.jpg
projxB
08-14-2004, 12:00 AM
that is one of the coolest mods i've seen yet. that looks awesome, nice work/. id really love to have that. but i have a DVD player right now and im not sure which one id rather have. DVD player i wouldnt mind getting rid of, but MP3 player is a must. decisions!!.. :twisted: :twisted:
wgeee7478
08-14-2004, 12:08 AM
Well I think PIE and Blitzsafe both have AUX controllers that will work on the navi head and this will allow you to connect a MP3/CD changer and still be able to control it from the screen. I think... lemme look into this more. :)
wgeee7478
08-14-2004, 12:35 AM
Well here's what I found out from the messageboard and siennaclub.org
http://www.siennaclub.org/forum/index.php?showtopic=4025
It's possible to add it and the screen controls work but it won't display the mp3 name.
On the other hand, someone else on the board also contacted Blitzsafe and they said they should have an video/audio adapter coming out sometime in the middle of August, which is about now. Here's that link.
http://www.siennaclub.org/forum/index.php?showtopic=4142&hl=changer&st=15
k4kas
08-15-2004, 07:33 AM
Hello again.
Just wanted to maybe help someone out with a link.
I have been looking around for this unit.
I am posting this link to help someone only.The only reason I am not bidding is because he says it is untested and for parts use only?
Could be a good deal if you have some money to risk????
Now the linky!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7914961911&category=38653
wgeee7478
08-15-2004, 11:39 PM
Hello again.
Now the linky!
Thanks for the find k4kas. I do have to warn people though that the 2002/2003 camry had a seperate Nav ECU that was located in the trunk. Plus the back of this unit looks like it came from a Solara which uses the digital JBL amp. The one that I installed is the Camry 04 with an analog JBL amp. The digital JBL amp was more for the upgraded 10 speaker package found is Sienna's and 4Runnner's. I'd get more information from the seller before bidding on that unit, as it might not work correctly.
big_guy
08-21-2004, 01:17 AM
Is there any way to change the intro graphics from Toyota w/ the Toyota Logo to Scion w/ the Scion Logo? Just curious. :?:
wgeee7478
08-21-2004, 02:24 AM
Unless you're a very good programmer (ahem hacker) and are good at hardware reverse engineering (ahem... hacker), then I'd highly doubt it. Scion were never meant to have navigation in the first place so there probably wouldn't even be a BIOS out there that has the SCION Logo. But if you find a couple guys that hacked the XBOX logo via modchip, then I think they might be able to do that.
foxSCION
08-22-2004, 04:17 PM
This is very cool. Just like the bBs. I hope they make it available in the near future as an option in the Scion with the Scion Logo.
wgeee7478
08-22-2004, 07:49 PM
I think if there is enough demand for it then Toyota would definitely consider it as an option. It's just one of those "must have" things for tech savvy people or people who travel a lot; and/or people who get lost a lot. Ever since I first used one, I've always known that this is something that I "must have" and I'll never resort back to unfolding maps and looking at gridlines and the such. Granted you are paying a lot for convenience but I believe that this kind of thing was developed for a purpose; to move us technologically forward. However, I think right now a lot of people who have gotten used to using maps wouldn't probably opt for this option because their biggest concern for paying a premium on this option is why would they need to spend $2K on something that they can easily find the same results with when purchasing a regular paper map (or Yahoo! maps for that matter).
Just my $.02, but enough with my B.S.ing, I think if people really want it as an option, we should tell Toyota Corp.
irv_usc
10-05-2004, 11:36 PM
I just want to clarify something here. you plug the outputs from the toyota nav into the existing scion harnesses that were previously plugged into the stock pioneer unit?
and then the jbl amp replaces the stock amp?
sorry for the dumb questions.
also curious as to whether you have the part numbers for the parts needed?
wgeee7478
10-05-2004, 11:59 PM
Well actually the plugs that normally go into the Pioneer HU plug into the JBL Amp first and then from the amp plugs into to the Navi head unit. Hope this was clear enough for you. Also the site I gave has pictures of what I'm talking about.
As for the part numbers, sorry I don't have any of that. But it was from a '04 Camry so you can probably contact a dealer for the part numbers. Let me know if you have any other questions.
irv_usc
10-06-2004, 06:04 PM
Yes, that makes everything crystal.
Thanks.
CamoBox
10-07-2004, 01:27 AM
Maybe a stupid question, but does the unit light up the same color as the rest of the Scion dash?
wgeee7478
10-07-2004, 01:46 AM
You mean like this
http://img.photobucket.com/albums/v443/wgee7478/IMG_0139.jpg
8) 8) :D :D
... Nope, I wish.
However, I did do this.
Link --> "Now this is what I call MAD stock, it's soooo JDM." (http://www.scionlife.com/forums/viewtopic.php?t=27889)
CamoBox
10-07-2004, 02:06 AM
Wow that just scared me away from considering the whole mod, I mean to get it to really look stock you will have to change all those LED's? That seems a little too much for the average do-it-yourself'er. But i give you props man that looks awesome.
wgeee7478
10-07-2004, 02:18 AM
Thanks. I'm not going to say it was easy, but basically any electronics repair place that you can find locally, should be able to do this mod. If not go to your local Chinatown and find places that mod LED's for cell phones, they are similar sized LED's and the people should be very experienced in doing this kind of work. Plus these LED's are a lot easier to get to than cell phone LED's, trust me - I know. :wink: You may have to flip a bill or two but trust me when I say it's damn worth it to have this in your car, and making it look stock, makes it so much better. It was worth it, in my opinion.
Hmmmmmm.... maybe I should just start a side job and do LED mod's for people... hehehe :lol: No but seriously I'm too busy with my real job as it is. Maybe I should just trade you my head unit and charge for the difference in cost and labor for swapping the LED's. hahaha I really have to think about that one a lot cause it was a lot of trouble. 8)
scioninla
10-07-2004, 02:34 AM
Nice set up. Really looks clean. Thanks for sharing the install.
XBman
10-08-2004, 11:49 PM
Sweet job. How long did that take??? like 10 hrs or 3 days????
wgeee7478
10-09-2004, 12:01 AM
Thanks everyone for your comments. The install really only takes about 1 - 2 hours at most, but it took me a better part of the afternoon until midnight to figure out how to take the dash out and where the wires were.
RACER-X
01-28-2005, 12:41 PM
ok i have one queestion can i do this to the tc as well?
wgeee7478
01-28-2005, 06:09 PM
To be honest, I'm not sure because I don't know anyone with a tC that has one installed. Most of the tC's I read on here usually install the Eclipse AVN2454, Kenwood DDX7015, or Pioneer AVIC-N1 (Soon to be AVIC-N2). But I've seen the clearance with the radio door on the tC's and I think it should still be able to close.
daemonite
01-30-2005, 11:00 AM
can we get a picture of the antenna, i want to see how it looks to see where it can be mounted on a scion tC
wgeee7478
01-30-2005, 04:16 PM
Here ya go -->
http://www.oemvalue.com/pics/toyota/navaccessories4,1.jpgv
It's the tiny black square mounted on the piece of metal with 2 screws. The plate can be removed and the antenna mounted possibly anywhere with double sided tape. I've even mounted it to the underside of the top dash for a discrete look and it was still very accurate but at the same time covert. The dimensions are roughly 1" x 1" x 0.4" (actually smaller since this is just going by what I remember and an eyeball measurement.) Hope it helps.
wgeee7478
01-30-2005, 04:17 PM
Sorry here it is, I messed up on the picture
wgeee7478
01-30-2005, 04:28 PM
Also if anyone was interested in the plug and play video input module that is soon to be available. the developors have just recently released video that shows their module in operation. It is a very sweet unit because it does several things other than just pipe video to your navi. It has the function to press the pesky "I Agree" key. It allows full functionality while the vehicle is in motion. It still also allows for a cd changer or XM addon. You can also plug in a iPod and the song name and touchscreen buttons for some functionality appear on the screen. All this added functionality without splicing any wires and without interrupting any of the navi's normal operation. Here's the link to the video http://www.coastaletech.com/test_video.htm. No pricing yet but as being the first to come up with a plug and play solution, it might not be cheap.
jatt
03-08-2005, 02:01 AM
i like my avic n1 better =)
wgeee7478
03-08-2005, 07:58 AM
Yeah, the AVIC is a nice unit. To each his own, I guess.
Charles
03-08-2005, 11:16 PM
Does this have touch screen as well?
wgeee7478
03-08-2005, 11:20 PM
Yes it does, and I love it cause my E-Class doesn't have it and I get annoyed by it.
CKGuY914
09-22-2005, 01:44 AM
I just bought an 06 camry navi headunit from oemvalue, I hope the retro-fit'll be a breeze >.<
bblhed
09-22-2005, 03:18 AM
Really nice mod! The thing that gets me is that this should have been available as an option in the first place. Whatever, I have forgoten about the carputer, I want this insted! I just hope I can squeze it into the xA
commandoe
10-02-2005, 04:15 AM
Well, I purchased the 06 Camry Navi unit for my xB from OEMvalue last week, but it didn't come with the AMP or the Jumper Harness. I have tried to contact Troy at OEMvalue for the last 3 days by PM, email (no phone number to call) and he has not responded as of yet, I've left my cell number and everything, and this guy won't respond. :nails: Hey, I undertand we all make mistakes!
Question is, if this guy continues to flake, do any of you know where I can get a compatable amp (would like the original JBL OEM amp, but no ones knows the part number) and a jumper harness I can use with that AMP and the HU.
Hopefully Troy over at OEMvalue will make right his wrong soon, and send my AMP and harness or even refund my money if he can't supply all the parts. No matter what, I will let the forum know what happens, Good or Bad!
Thanks Guys, and appreciate the help in advance! :clap:
Holla!!!
CKGuY914
10-02-2005, 08:43 AM
The kit that he sells now does not include an amp, I had to purchase a OEM amp seperately from him for $120.
So far he has been great with contacts through email but I haven't tried calling him yet.
If you have an aftermarket amp I believe you can still do some modifications to it to work with the unit, the mod instructions are on his site.
commandoe
10-03-2005, 12:34 AM
Thanks, let me check the site again! :pray:
Holla!!!
commandoe
10-04-2005, 07:23 AM
FINALLY, contacted by Troy today and he said what you said, that the amp is seperate and that for me to get it, it would be $120.00. Oh well, I was prepared to buy an amp anyway to finish my install. I hope that the "kit" includes the jumper harness too!
I asked him to change his website, cause it never mentioned a "kit", it says that everything is included.
Thanks for all your help, I even got a phone number from wgeee7478 incase I need more help with the install. All you guys have been great! I'll let you know how the install went, doing it Thursday.
Holla!!!
Moose411
02-05-2006, 08:43 PM
hey..do you know if that "iPod Drive+Play" is conpadiple with this? i assume it does because the nav unit is technacally from factory.
if you have the 6-cd changer and dont want to downgrade to only one (and you have an iPod) this is a good option. actually, if you dont have an iPod, getting the drive+play and an ipod is probabbly cheaper or only a little more expensive...
and if the mods dont mind..
[www.driveandplay.com
wgeee7478
03-20-2006, 04:07 AM
Sorry, haven't been on the message boards for a while. I don't see why not. I have a Pac Audio iPod adapter and it plugs into the existing CD changer socket.
Tuning69
03-22-2006, 09:36 PM
Great right up, shows how to perfectly take things apart
As far as the drive and play, its a univeral unit, the modulator uses a univeral antenna plug, any questions on it PM me.
Moose411
03-26-2006, 11:18 PM
thaks for the info, now all i need is the money for either of them...
midtowndesi
04-17-2006, 04:41 PM
I just came across this on craigslist for new york city. It's the camry navi unit for $400 - I am not sure what else it comes with - whoever is interested can contact the seller.
Just keeping an eye out for good deals! =]
- sh00k
http://newyork.craigslist.org/lgi/pts/151801249.html
JaEohEN
06-20-2006, 02:15 AM
sorry for the grave dig, but i was using this to install a navi on my moms XB, and im running into a problem....i got it all done, except for the reverse and speedo wires...
the guide says to connect to the fusebox...where is the fusebox? is it the blue box behind the dash? if so..then im good to go...
thanks for the writeup..i wasnt looking forward to this since im used to working on Lexus'....the guide made this a cinch!!
mushroomdreamer
07-17-2006, 04:09 PM
is it neccesary to disconnect the battery when dealing with the air bag?
i have my dash apart seemed pretty easy getting ready to do some stuff, not high tech :lalala: , just ok.
wgeee7478
07-20-2006, 10:12 PM
Wow... I haven't been back here in a looooong time.... Anyway I know this is late but I hope you found the information you were looking for. If you didn't, the fusebox is on the drivers side behind the kick panel closest to the door. You'll see it when you stick your head under the driver side footwell and then look up. You should see this big harness of wires leading to a certain location closest to the door. There's a lot of wires there but I assure you it's there. Actually I found out it was easier to go from the top when you have the top dash removed.
wgeee7478
07-20-2006, 10:19 PM
I always think it's safest to disconnect the battery whenever modifying the car. I might be being too careful but it's a lot less painful to reprogram your radio presets then to have an airbag activate in your face.
XbBully
08-04-2006, 08:13 PM
Very clean, i was looking at the kenwood screen that they are selling here on scionlife. does anyone have it? Im also looking at putting suede lining on the inside roof of the car. any recomendations?
XbBully :tap:
redneck69
10-20-2007, 02:39 PM
gm all
Cinderblock
10-30-2007, 11:39 PM
sweet, now i know howta remove dash haha
Styalz
10-07-2010, 12:51 PM
Great write up. Looks great also!
