Toyota FT-HS Hybrid Sports Concept Revealed
Old Dec 24, 2006 | 09:22 PM
scionlife's Avatar
Founder
Default Toyota FT-HS Hybrid Sports Concept Revealed
Our Toyota FT-HS homepage is located here:
http://www.toyotalife.com/toyota/fths/
It's only a concept car for the Detroit auto show, but it might become the next Supra
By Scott Oldham , Inside Line Editor in Chief
Date posted: 12-24-2006
The Detroit auto show is a huge theater, a Las Vegas-like stage where carmakers do their best to thrill and amaze a world audience. Toyota will step up this year and present its FT-HS Hybrid Sports Concept, a futuristic sports car that would be powered by a 400-horsepower hybrid powertrain.
Of course, the Toyota FT-HS Hybrid Sports Concept is just a concept, little more than a container for the overheated dreams of a bunch of designers at Calty Design Research, Toyota's design studio in Newport Beach, California. In fact, what you see here is only a two-dimensional animation, a computer-generated image of the show car that Toyota will roll out at the Detroit auto show on Sunday, January 7, 2007.
Whatever, it's enough to get us thinking about the next Toyota Supra, which the automaker feels it needs to compete with Nissan's one-two high-performance punch of the 350Z and the coming Skyline GT-R.
Introducing a Prius on steroids
"We feel there's a hole in our lineup," says Kevin Hunter, the vice president of Calty Design Research. "Toyota hasn't had a sports car since the Supra was dropped in 1997. We need some emotional punch in our lineup, a halo product."
Toyota envisions that punch to be a rear-wheel-drive Hybrid Sports Concept (HSC) that develops 400 horsepower. "It's a new kind of sports car for the 21st century," adds Hunter. "Eco and emotion in a sports car concept with a performance target of 0-60 mph in about 4 seconds and a price tag in the mid-$30,000 range."
A 3.5-liter V6 engine would deliver most of the thrust, and it doesn't require too much brainpower to connect the dots to the DOHC 3.5-liter V6 in the Lexus GS 450h, which already makes 292 hp at 6,500 rpm. You wouldn't have to look too far to find an electric motor to deliver the rest, because the water-cooled, 650V electric motor used in the GS 450h makes 197 hp at peak output, though this is just for seconds at a time.
The Calty designers, who have been working on the FT-HS for an entire year, are even willing to suggest that once the future arrives, a hybrid powertrain will be necessary to achieve the feeling of ultrahigh-performance that you want in a sports car. In a fuel-efficient future, a jolt of acceleration from an electric motor might become the equivalent of an injection of nitrous oxide into your gas-powered engine.
All this has overtones of ecological friendliness, of course, but as the buzz about global warming and greenhouse gases becomes a part of daily life, Calty's designers remind us that a hybrid powertrain will have a certain quotient of respectability that you won't find in a supercharged big-block V8. The FT-HS is even painted white because white is not only a pure motorsports color, but it's clean which, Hunter tell us, supports the car's hybrid message.
Putting it in a package
The FT-HS Hybrid Sports Concept that Toyota will roll out at the Detroit auto show is about the size of the Lexus SC 430. The HSC measures 170.3 inches from tip to tail, and it has a wheelbase of 104.3 inches. It's 73.2 inches wide and 50.8 inches high. Much like the SC 430, the front track is narrowly wider at 63 inches, while the rear track measures 61.2 inches.
This is meant to be a 2+2-style car, large enough for occasional backseat passengers. We probably shouldn't be surprised that it's nearly as big as a Corvette, since it's going to take a lot of space to package an engine, a fuel tank, an electric motor and a battery pack. The restrictive trunk volume of the Lexus GS 430h shows us just how difficult this task can be.
The HSC's long wheelbase should help balance the weight of the sizable battery pack that will be required. In fact, the HSC's weight distribution might even approach the magic mean of 50-percent front/50-percent rear as a result.
Shaping the future
The HSC has a hyperaggressive triangular profile, and this theme is repeated throughout the design. Meanwhile, much of the mass has been subtracted beneath the surface to create a shape that looks like an insect's exoskeleton.
Apparently the design has been inspired by the look of a downhill speed skier, in which individual aerodynamic elements are more important than overall streamlining. "Vibrant clarity is our new Toyota design language," Hunter tells us. "And the car is packing plenty of J-Factor, which is the local and global acceptance of Japanese design."
As envisioned by the Calty team, the engine will be visible through a hole in the hood to emphasize its hybrid nature. That dark portion in the middle of the hood is actually the engine cover poking through, much like a shaker hood scoop from the 1960s.
"We were thinking about the Formula 1 aesthetic," Hunter tells us. "An aesthetic driven by function. The hard edges all over the FT-HS are aerodynamically functional. We also wanted to boil down the shape of the car to its minimum requirements. We wanted it to look lightweight. We call that 'Subtractive Mass.'"
Also functional are the large air intakes ahead of the rear wheelwells, which will direct cooling air to the rear-mounted battery pack. A full belly pan enhances aerodynamic slipperiness. The car rides on carbon-fiber wheels that carry 245/35ZR-21 tires in front and 285/30ZR-21 tires in the rear and according to Hunter were very difficult to make.
Solo space
Toyota's designers also postulate a unique retractable roof, which will slide and then lie down inside the car covering the backseat, rendering the car a two-seater. Thanks to the tiny servo-motors we see in motorized hardtops these days, perhaps anything is possible, and the top is functional on the concept car.
The interior has the same aggressive style as the exterior, and the sharp edges look to us like the work of Edward Scissorhands. Toyota calls it "Solo Space." "The interior is all about the driver," says Hunter. The seats are little more than thin pads attached to the surrounding structure, and the driver is meant to hold a hubless steering wheel, an ever popular feature of design renderings since the 1960s. There are also paddle shifters on the unique steering wheel, which has a unique outer red ring that turns around an inner ring.
If Toyota builds it, will they come?
There's a lot about the Toyota FT-HS Hybrid Sports Concept that reminds us of the far-fetched sketches that production designers create for bad sci-fi movies. It's pretty unlikely that the muscle-car fanatics within Cobo Hall at the Detroit auto show will spare it a second glance. But we still think there's a glimmer of a good idea in this concept.
The Toyota Supra left these shores 10 years ago and Lexus took over the prestige role for the whole company. But as Toyota has crafted generation after generation of reliable yet uninspiring automobiles, the family of Toyota buyers has begun to look a little old. A sports car might be the right thing to wake up a new generation, especially since Toyota has a relevant performance heritage thanks to ownership of a Formula 1 team since 2002, a piece of victory at the 2003 Indianapolis 500, and a new fleet of cars in NASCAR's Nextel Cup for 2007.
The technical challenge presented by a hybrid sports car isn't small. Lithium-ion batteries are about half the weight of nickel-metal-hydride cells, but they are extremely sensitive to temperature and burst into flames when overheated. In addition, lithium-ion batteries don't like to be recharged quickly.
Yet efficiency is a cool thing in our culture these days. It's even about to become cooler, because the power structure in Formula 1 is talking about regenerative braking for the racing cars by the 2009 season and the reuse of waste engine heat by 2010. Since Toyota's F1 team will be on the leading edge of this development, the technology should find its way into its street cars like the HSC.
There's a lot about the look of the Toyota FT-HS Hybrid Sports Concept that might seem awfully speculative to the crowd at the 2007 Detroit Auto Show, but it's probably a mistake to dismiss it. Inside this computer-generated image is a dream of a Toyota Supra for the future.
Backtrack: http://www.edmunds.com/insideline/do...ticleId=118933
Old Dec 24, 2006 | 09:26 PM
mikochu's Avatar
interesting... it reminds me of the 7th gen Celica...
Old Dec 24, 2006 | 09:40 PM
paul34's Avatar
My comment from Autoblog:
Not too original: -1
I only see two pedals: -infinity
forget it, Toyota. Didn't you learn... stop making people laugh at you
Make it a proper sports car and it just might work
Old Dec 24, 2006 | 10:31 PM
06CStC's Avatar
psh..i'd still hit that..
Old Dec 24, 2006 | 11:46 PM
thekidblue's Avatar
it's beautiful. *sniff*
Old Dec 25, 2006 | 12:23 AM
604toaster's Avatar
I hope the next gen Celica looks something like that.
Old Dec 25, 2006 | 03:11 AM
scionlife's Avatar
Founder
It IS beautiful. And did you see the price? Mid 30s!?! I doubt it, but still... can you imagine?
Old Dec 25, 2006 | 03:18 AM
davedavetC's Avatar
:sigh: ill never have it
Old Dec 25, 2006 | 04:06 AM
hunterUnknown's Avatar
thats hot.
Old Dec 25, 2006 | 04:08 AM
v12's Avatar
v12
make it a lexus....
Old Dec 25, 2006 | 05:51 AM
ra24man's Avatar
Originally Posted by v12
make it a lexus....
F that...Lexus been too stingy with all the glamor...Bring that to the US shores...you'll have boy racers lining up like drones
Old Dec 25, 2006 | 06:45 AM
scionlife's Avatar
Founder
Yeah! ...and what the hell are you doing on the computer this late on Xmas Eve? Haha...
Old Dec 26, 2006 | 01:50 AM
BalistC's Avatar
if they just made a base model v-6 NA with a 6speed it would be the new Z-Car. I hope that we get back into the sports car game. I could easily see that NA being in the 30's range and then the hybrid High Ouput in the low forties to compete with things like the vette and Shelby Mustang GT's rollin around out there. I dunno, I guess I may just be old school, I like having the clutch even if it is costin me in fuel. there is just something about controlling every aspect of the car that is appealing. Its hard to get that same emotional experiance out of what I have seen of our hybrids.
Then again, max torque at 0 RPM could be some serious slammin you in the back of your seat action. Love the look, I hope we put them into production like we did the FJ!!
Old Dec 26, 2006 | 04:22 AM
ashiva's Avatar
i love it...almost....dunno about the lines in the extreme front and extreme back from a side view. i can't wait for a fully developed eco-friendly sports car to come out...
i'll be in the market in 6-10 yrs...but then 400hp will be nothing...think GRANDER!! as for going back the supra i dunno...i'll look forward to the new _____?
anything is possible.
still...i'll be ready for a testdrive as soon as she rolls of the truck ;) hope the final product is a thriller!
Old Dec 26, 2006 | 04:51 AM
ashiva's Avatar
make it a lexus....
lexus is for old people (my opinion). i loved the 400h but i dont think i've seen one person under the age of 45 driving it...totally agree that there is a hole in the toyota lineup ---
as for making this concept car a lexus, well the whole point of filling the hole would be defeated; am i correct in saying that the 350z and g35 have similar engines? let toyota make a 350z competitor and leave lexus to handle the luxury aspect of the new ride's technology to challenge infinite.
but on a side note toyota/scion cud really use the lexus design of a place to put our handbags...
if u have this on the future car and its a fair price and a fun drive AND could take a skyline in a race...i'd put cash down on the spot
Old Dec 26, 2006 | 01:04 PM
ra24man's Avatar
oh Shi...no delete privilages
ra24man's Avatar
Playing Santa!! HAHA!! Hope you had a great Christmas Darren!
Old Dec 26, 2006 | 04:09 PM
scionlife's Avatar
Founder
And here is an entire page of images related to the FT-HS:
http://www.autoblog.com/photos/toyota-ft-hs-concept/
Old Dec 26, 2006 | 06:04 PM
chrischoi's Avatar
why do they all seem like tuner concept cars?
Old Dec 26, 2006 | 06:18 PM
scionlife's Avatar
Founder
Not sure what you mean by "they". Can you expand on that?
