View Full Version : Dash Board Rattling when acelerating
eight08xb 08-09-2004, 08:23 AM Hey guys anyone notice in the 2005 XB a rattle comming fromthere dash board from the instument cluster when you are accelerating from first to second gear. Vey irritating rattle. Make the car sound very cheaply built. does any else notice this?
cutebb 08-09-2004, 09:40 AM i have this rattle, too, and it's irritating! i also have a rattle coming from the right side of the rear. haven't been able to localize it. :cry:
CrackerBox 08-09-2004, 11:43 AM I have the same problem. I don't think it started happening until after the security system was installed at the dealership. I just have not had enough time to take it back. I am hoping they can resolve this issue.
trogdor 08-09-2004, 12:20 PM I have noticed this, but it doesn't occur everytime. It seems to occur more often after leaving the car outside in the heat. It has never happened when starting the trip from the garage. Maybe it's just coincidence, but I thought it was interesting.
supitsmark 08-09-2004, 06:04 PM i got this problem too, but i noticed it after installing the injen intake.
ThunderxBinNC 08-09-2004, 06:10 PM Hey Everyone. I had this problem too, when I drove my xB off the lot new. I took it back to them, and they said there was 2 things that can cause the rattle.
1. A speaker grill / guard.
2. The lense on the speedometer was loose.
They tightened both of these things on my xB 2 months ago, and I have never heard the rattle again.
Take it to the dealer and see what they say.
XBman 08-09-2004, 08:55 PM take it in to the dealer. Thell fix it
HotXB 08-09-2004, 09:03 PM I have both rattles. The one in the back turned out to be the rear seat latch. A little black electrical tape around the latch bar solved that one. The other is somewhere in the instrument cluster. Also only under acceleration. I have not solved that one yet. Taking it back to the dealer is not an option. They had it for 3 hours last time and did not find the rattle in the back. They will not get a second chance.
the_drizzle 08-09-2004, 09:09 PM Just to let you all know, I have the same rattle coming from my inst cluster and I have a manual xA... I wonder if this is characteristic of the lense they use to cover the gauges, or if its just loose? I installed the injen intake and it got way worse, but its so loud now that you can barely hear anything but the engine. :lol:
sciontc_mich 08-09-2004, 10:45 PM there is a service bulletin out for this.. i saw it.. the rattle from the dash is coming from the air vents by the radio.. and the rear latch is from the lock striker has to be moved up to make a tighter fit.. :) ask the dealer, they'll show you the TSB..
TOAST3R 08-09-2004, 10:50 PM i have a rattle from my drivers door if the window is all the way down, if i put it up a tiny bit to fill the gap it goes away. the dealer said its cuz i have the radio up loud, since thats only time i notice it.
but im also getting that rattle while accelerating
Back_In_Black_xA 08-09-2004, 11:01 PM My xA has a rattle coming from the front of the dashboard. Maybe next time I hear it I will press on the instrument cluster see if that is the problem.
applezz 08-09-2004, 11:10 PM I have the same rattle. I noticed that if I reached up and lightly pressed the clear plastic cover on the speedo the rattle stopped. If I wedge some folded up paper in the crack there it goes away totally, but looks like hell! I think a rubber gasket or something similar would fix the problem.
Back_In_Black_xA 08-09-2004, 11:12 PM Here I will host the TSBs on my website...
Here is the 2004 xB rattles TSB...
http://fourthgenhatch.com/scion/tsb/04xbrattles.pdf
2004 xA rattles TSB...
http://fourthgenhatch.com/scion/tsb/04xarattles.pdf
There are no rattle TSBs out for the 2005s yet but we can assume the same problems could exist.
sciontc_mich 08-10-2004, 12:15 AM Here I will host the TSBs on my website...
yes, that's what I read before!! that should help everyone.. thanks back in black..
breunor 08-12-2004, 03:00 PM I also had the rattle from the instrument cluster, went away when I pulled it out to make the speedo blue at night. There are a few plastic pieces that are held in place with snaps that could be loose, otherwise a little felt in there will also work to tighten it all up. Takes much less time to do it yourself than to schedule a dealer visit IMHO. Literally 10 minutes to check it all and apply felt in your garage. Read the tutorial on this site for changing the speedo color for pics and detailed steps to open it up, it's very easy to do.
eight08xb 08-17-2004, 05:24 AM Hey if you guys have that dash rattle. I fixed it myself just by pushing the glass in the speedo away from the bezzel. it was hitting the bezzel and pushing back made it stop rattling.
