Installed Dezod Black Box.
Old Dec 26, 2006 | 02:09 AM
Schuller's Avatar
Default Installed Dezod Black Box.
I installed the Black Box and sure enough it worked pefectly. Before the install my AFR would be in the 14s during partial throtle and boost. Now I'm in the 11s and 12s. At full boost (9.5psi) I,m at about 11.5. The map seems to be pefectly smooth and just right for My untuned Turbonetics kit set at 9.5psi witha MBC. The car runs perfect and the AFRs drop very smooth at any throtle position. Now I car drive at partial throtle to avoid wheel spin in first and second gear and NOT be boosting 6-7psi at 14.7 AFR.
The instructions are very accurate. I added a T for the vacuum. Spliced into the ECU with the suppied hardware. If you have the TN kit you will have to remove the black electical tape to make room for the splice. I mounted the BB under the stereo. Took about 1 hour.
Old Dec 26, 2006 | 02:29 AM
lil_will's Avatar
ScionERA
Old Dec 26, 2006 | 02:31 AM
ProshopXB's Avatar
Originally Posted by lil_will
I think he means... Black box= good...
Old Dec 26, 2006 | 02:44 AM
lil_will's Avatar
ScionERA
thats what I figured lol.
Old Dec 26, 2006 | 03:04 AM
DTRUONG_112's Avatar
Details on it man, I want to know ho it works with the Tnetics kit...TEASE.
Old Dec 26, 2006 | 01:22 PM
deathbyc4's Avatar
by any chance you downloaded a copy of the map to your pc?
Old Dec 26, 2006 | 04:10 PM
ERIC-TC's Avatar
Is the A/F wire on the tC ECU the orange one? I'm still messing with my black box -I'm not sure if it's working all the time. Some times at part-throttle A/F goes down and some times it stays at 14.7 like when I boost in the high-way. I will probably hook it up to my PC to make sure everything is working right.
Old Dec 26, 2006 | 05:00 PM
BOXMAN's Avatar
Eric have you tried calling Paul at Dezod? Also did you guys get the pre-tune box or did you tune it?
Old Dec 26, 2006 | 05:19 PM
deathbyc4's Avatar
i would like to see the dezod map, even though I'll end up retuning it since I have a different setup. problem is, for some reason, my map table font is way huge. anyone have that problem?
Old Dec 26, 2006 | 05:44 PM
BOXMAN's Avatar
Try calling Paul?
Old Dec 26, 2006 | 05:50 PM
paul_dezod's Avatar
Scionetics
KAD
Make sure your VAC line is not kinked. That happened to Joe once.
Old Dec 26, 2006 | 05:53 PM
318_tC's Avatar
Ummm why is it when I enter boost im never in the 14's???
its always like in the 12's and 13's
Old Dec 26, 2006 | 05:59 PM
paul_dezod's Avatar
Scionetics
KAD
5 speeds have this problem far more than autos.
Tap your throttle and hold it on 25% throttle and report back Jeff.
Old Dec 26, 2006 | 07:29 PM
Schuller's Avatar
I purchased this device to be in the 12s and 13s in boost. Why did you get your black box?
Old Dec 26, 2006 | 07:33 PM
BOXMAN's Avatar
318_tC is building a monster and any tuning help he can get will be needed. That's my guess
Old Dec 26, 2006 | 07:43 PM
paul_dezod's Avatar
Scionetics
KAD
He doesn't have one to my knowledge. He is an auto...FYI
Old Dec 26, 2006 | 08:23 PM
318_tC's Avatar
i dont have the problem with my AFR jumping around
Old Dec 26, 2006 | 08:44 PM
BOXMAN's Avatar
See 318_tC the auto is good for a few things.
Old Dec 26, 2006 | 08:58 PM
318_tC's Avatar
YEAH SLIPPING THROUGH EVERY GEAR
Old Dec 26, 2006 | 09:34 PM
BOXMAN's Avatar
Now now you will have that fixed soon right?
