View Full Version : Door Sill Tape Removal
BlueBox
12-06-2003, 07:09 AM
I know this controversial topic of stripping the door sill's black tape has been discussed...but i did it anyways. Although i didn't go all out on the whole door sill cuz alot of ppl seem to notice that it looked "chopped" off toward the rear...so i opted to just do the center sills...which came out looking nice and subtle...
here's how i did it... i was surprised how easy it was with proper tools...took me only 45 min for the whole thing...with no sweat.
wat you will need...
1. powerful hairdryer ( i have a japanese hairdryer..it's hot has a heat gun)
2. bug and tar by Turtle Wax..awesome stuff
3. credit card or ruler ( used a card cuz i don't have a ruler)
4. tweezer (i used it once to put the rubber lining back in place)
5. hobby type razor blade
http://www.scionlife.com/tech/images/door_tape_removal_xb/01.jpg
Step 1: Since i was not going to do the whole door sill..i used my law school (yes, i used to go to law school) copy machine card to align a cut along the tape with razor...please do not attempt this unless u have steady hands. I used very fine cut to just break thru the tape trying not to scratch the paint underneath.
Step 2: I began with Driver Side door from inside out. I heated the tape generously until i could easily peel the tape from the corner...then lead upward (along the inside door sill..to the cut line)
Step 3: Then I heated the outside sills until hot...then i started to peel away almost in full one piece...it was amazing how clean it came off with almost no goo.
http://www.scionlife.com/tech/images/door_tape_removal_xb/04.jpg
Step 4: Although most piece came off at once..some portion were stubborn and required abit more work. As you can see, there were some tape left inside the rubber lining of the sill. To cure this, I rolled the windows down and used my hands to pull the rubber outward...then heated the tape again. The inside portion came right off with one easy pull.
http://www.scionlife.com/tech/images/door_tape_removal_xb/05.jpg
Step 5: This is where most people will find difficult to do away with the tape cleanly. I found an easy solution...just heat the bottom portion area with extra heat...once heated... pull from outside (edge of door) inward slowly...this will pull out the whole bottom portion of the tape ...remember to use heat as needed. Your blow dryer will be key to this whole process.
Finished:
Here's a good pix of the difference between the tape and non-taped door sill.
http://www.scionlife.com/tech/images/door_tape_removal_xb/08.jpg
here's a view of the two center sills undressed... notice that i have bypassed doing the whole door due to the fact the rear will be create an illusion of being cut off... so i kept the black tape all around except for the center. Notice the glare/shine the center sills emit...alot better than the black tape.,which to my surprise came out pretty damn good. i will post some better pix later..but this is wat i have right now...
please forgive my messy garage...
http://www.scionlife.com/tech/images/door_tape_removal_xb/09.jpg
arinvolvo
12-06-2003, 08:11 AM
You know what....that looks absolutely great.
I am glad you just did the center sills....looks nice.
BlueBox
12-06-2003, 08:42 AM
i had a mental picture of wat i was trying to accomplish b4 i set out to unpeel the tape.
i've seen couple of xB with the tapes all stripped...some looked okay...and some did look "chopped off" at the rear.
i didn't want to create such look or illusion..so i brainstormed for couple of minutes and thought about still doing the stripping but slightly different and abit more subtle...
result was my idea of just doing the center sills...i took the risk of cutting the tap toward the center top..but worked out perfect. everything looks stock , if not better ...cuz i still have the overall uniform tape seam from front to back.
i'll take better pix tomorrow if weather permits...
scionracerxb
12-06-2003, 09:49 AM
looks sweet...i shall attempt this tomorrow..oh yah :wink:
BLKTOYBOX
12-06-2003, 10:11 AM
That looks super clean Blue. No disrespect to the other folks who did the whole thing but just doing the center looks pimpin' Kepp up the good work and nice goldline graphix.
James
bBted
12-06-2003, 12:40 PM
wow....thats a good idea.... :lol:
looks nice too....great job
DibujoB
12-06-2003, 06:24 PM
That looks awesome!
Mr_scion
12-06-2003, 06:52 PM
good idea
showpaojoe
12-06-2003, 07:48 PM
Nice job, nice graphics
Scionic
12-06-2003, 08:25 PM
bluebox....you rock!!! That looks sweet. Thanks for the FAQ
bBted
12-06-2003, 10:10 PM
any polar white wit tapes off??? :wink:
ScionVan
12-07-2003, 12:33 AM
That looks pretty dang interesting! I never would've thought to remove those to see what things looked like underneath them... I do wonder how they would look if you did on a lighter-colored xB though. Hmmm...
BlueBox
12-07-2003, 01:47 AM
I strongly recommend undoing the center door pillars/sills watever u call that area for darker color cars..cuz it blends in better with the tape and it's subtle. Although my mod doesn't necessarily stand out...i like the subtle tone of it.
GoldLine is sposorning me for the show next weekend, so they gave me some simple graphix to put on my car..i like it alot...although i wish it was even bigger...haha.
its_ikon
06-14-2004, 08:28 PM
added to tech section
BlueScionXB
06-14-2004, 08:35 PM
I did mine a while back, but I did the whole thing. You can see the pics in my profile... :D
its_ikon
06-14-2004, 09:01 PM
this post was in december before you even had the xB :wink:
shoutforjoy
08-08-2004, 04:43 AM
I removed the black matte on my Camo xB this week. I started by following the instructions, using a hair dryer on a pretty hot day. I found that the heat made the tape more sticky and weaker. It took me about 2 hours to do the right side of the car.
The next day was cooler. I tried it without the hair dryer. I carefully started from the edges on the backside. Once I got it started, I was able to pull it off, thumbs on front, forefingers on back edges, in complete strips. I completed the entire left side of the car in about 30 minutes. :D
hotbox05
09-23-2004, 02:49 AM
i know this is old but.. i wanna see pics with all the pieces removed
hotlava1886
10-03-2004, 06:20 AM
heres my lava w/it removed.
http://img21.exs.cx/img21/6610/picforcard.th.jpg (http://img21.exs.cx/my.php?loc=img21&image=picforcard.jpg)
http://img21.exs.cx/img21/6443/P1010328.th.jpg (http://img21.exs.cx/my.php?loc=img21&image=P1010328.jpg)
hope this helps ?
later,george
founder & president : ScionOwnersClub@yahoo.com
10-03-2004, 07:12 AM
here is a link to the topic on the xB forum too and my pics of my car with the sill tape removed. :D
mikochu
10-03-2004, 07:22 AM
where...?
SXT_HuntToKill
10-21-2004, 10:10 AM
lucky me i have the Black sand... they never put the tape on LMFAO
SHOW_BOX
03-07-2005, 04:03 AM
i just finished mine i will post pics tomorrow i did the whole thing in an hour but with no blow dryer casue mom burned it out
trigga
03-31-2005, 07:52 PM
any more pics of this maybe befor and after and diferant ones taken off?
bluebb05
04-07-2005, 12:26 AM
all i got is my finished pics
trigga
04-07-2005, 01:42 AM
well it looks good, im going it to my TCM right now and i think it looks sweet, do you take the black tape off the pillar also?
match-box
07-22-2005, 03:01 PM
it looks great but you can do it with just your fingers and a razor blade the key is to take your time when you do it
greenguyshrek
08-17-2006, 09:47 PM
does this work for the xA?
NeveNelEstate
08-17-2006, 10:41 PM
is it just me or is this in the wrong forum? xB...tC...just checking, but I did the same to my tC, the n ended up two toning it and painting them black :rofl: could've just left it there
titolito
08-17-2006, 11:02 PM
Threads have a nasty habit of coming back from the dead lately! Who the hell is searching this far back?!?! **cough couch** greenguyshrek **cough cough** :lol:
SecretAgentMonkey
05-08-2007, 11:59 PM
Werd. I wanna see how it looks on my PW box before I do it!
Bringin' back dead threads is fun! :)
LosXAngeles
06-05-2007, 06:08 AM
anyone try this on an xa? i'm gonna do it this week unless someone stops me! hehehe.
HoldFastHope
08-21-2007, 02:07 PM
anyone try this on an xa? i'm gonna do it this week unless someone stops me! hehehe.Did ya try it? Pics!
Djbarista
08-21-2007, 06:46 PM
don't forget the tape on the inside of the doors. Its located behind the closed door on the B Pillar. IT shows when the door is open.
dz302
08-23-2007, 05:04 PM
[quote="hotlava1886"]heres my lava w/it removed.
Now that looks damned fine. So I ask, what are folks talking about when they say that if you remove all the tape then it will look chopped off at the back??? Yours looks great.
mad-sciontist
08-25-2007, 12:51 AM
In my opinion removing the tape ruins the bodyline of the car.... Toyota put that tape there for a purpse, to make the car flow, and getting rid of it, causes chaos... Just looks unorganized when you take it off...
dz302
08-25-2007, 03:06 AM
In my opinion removing the tape ruins the bodyline of the car.... Toyota put that tape there for a purpse, to make the car flow, and getting rid of it, causes chaos... Just looks unorganized when you take it off...Beauty is in the eyes......you know how that saying goes. I took mine off and love it. I think it was chicken s*&t of them to tape it in the first place. They should have painted it if it was that big of a deal. You know eventually down the years the tape will cause problems, then it will be all dry and baked on and you could never get it off.
I like the look, that's why I did my car. You don't like the look, then leave yours taped.
Djbarista
08-25-2007, 04:08 AM
You remove the tape anyway for Custom painting, just do it now if you have the plans to paint.
monae_xa
01-31-2008, 05:46 AM
oh wow that looks great!!!!
Murbyrne
01-31-2008, 05:58 AM
it does look cool, but im going for a black and green look, and dont really think its worth it. I like how it looks now, but others that have their tape removed do look great.
bB2NER
02-01-2008, 08:33 AM
Mines been removed but thinking of replacing it but with gloss black to better match the tinted glass. Any thoughts on how that would look?
Djbarista
02-01-2008, 02:53 PM
goood Idea. I'd Love to see it. maybe Reference a tape removed BSP.....
burstaneurysm
03-14-2008, 05:49 AM
Holy eff. I just finished doing mine. I can't feel my thumbs, but it looks great!
I need to hit it with some bug and tar remover, and tweezer the little shreds that got caught in the weatherstripping along the rear most window.
Pics soon.
bB2NER
03-14-2008, 09:54 AM
I just replaced mine by using semi gloss spray paint. I can always remove it again cause I didn't sand anything. Actually looks better than the tape because no lines or seams where the tape overlapped.
