View Full Version : Somewhat of a S-Tech problem.
SCIONbrouillard
08-09-2004, 07:51 PM
I noticed that my springs/shocks on the front driver side are a 1/4 of an inch lower than the other springs/shocks.
What's wrong or is this normal since I'm almost always the only one in the box.
If this is an obvious problem then don't mind me since I'm not a mechanic.
bB384
08-09-2004, 08:06 PM
Your xB should be lowered 1.7 inches in the front and 1.5 in the rear. So you should notice that the front is lowered more than the rear. But there shouldn't be a difference from left to right.
Minsk99
08-09-2004, 08:17 PM
Make sure you are on a very flat surface when measuring. Even a slight incline will show in the height of the suspension. Also, how long ago did you install the springs? Perhaps on side "settled" faster then the other.
SCIONbrouillard
08-09-2004, 08:19 PM
The front driver side is a 1/4 of an inch lower than the front passenger side. Thus making the car look weird and lopsided.
SCIONbrouillard
08-09-2004, 08:20 PM
It was installed on Sunday, August 1, 2004.
superjeer
08-09-2004, 08:52 PM
hmmm.. maybe the higher spring got twisted around so it's not in it's seat? Try pulling the wheel and taking a look.
J_A_Trevino
08-10-2004, 06:04 AM
the same thing happened to me with my previous vehicle, when i lowered it the spring wasnt set properly and the truck looked lopsided. try adjusting your springs and make sure they are set right in the strut.
