amp under BACK seat?
Old Dec 28, 2006 | 01:21 AM
GreenLantern's Avatar
Default amp under BACK seat?
HEy before I go and tear out my seat and see if it willl work I was wondering if a smaller amp (around 500 w or smaller would fit under the back seat?
Anyone tried it ? thoughts?
Old Dec 28, 2006 | 01:29 AM
xBtenchu's Avatar
I'm sure you could make it fit.. But I dunno if it would have the proper venting for heat
Old Dec 28, 2006 | 02:15 AM
blubox04's Avatar
nowawdays amps comes with fans so you wouldn't need to worry about heat, all you have to worry is how long would it be.
Old Dec 28, 2006 | 02:47 AM
sounds good..I noticed a few I was looking at had fans and tyhis will be wheremy daughters car seat is so it's not like I'll have an adult sitting on top of it....
I'm in Hawaii so it's not like I go on long road trips eitehr...and, of course, Ionly crank my tunes when I'm in the car by myself.......
so does anyone know how much room I've got ot work with? dimensions?
Old Dec 28, 2006 | 04:49 AM
TerribleTed's Avatar
Hmmm there really isn't any space under the back seat. The seat base foam sits on the floor panel. Maybe if you cut some foam out?? or your amp is very very thin!! By the way the rear seat base center rear clip is a paint to get loose. It comes easily if you remove both seat backs first, then you can push the base back better to release this clip (seat backs come off with only 2 bolts each...pretty easy).
Old Dec 28, 2006 | 04:53 AM
okay thanks for the heads up...guess I'll just put it under the front passenger seat then.....wanted to keep it totally out of sight.....
Old Dec 28, 2006 | 05:25 AM
In the storage box in the right rear works. I built a box for 2 10's and 2 amps that I simply cover with the cargo mat when I wanna hide it. Looks stock with the mat installed. Only problem is I have no spare in there any more...But I have towing and roadservice on my Ins
There is a lot of space under the front seats. I am sure if you were inventive with mounting you could suspend amps right under the seats bases and the would be virtually invisible. I built storage boxes for under my seats.
Old Dec 28, 2006 | 02:44 PM
looking great! I love the rear area...very nice and clean look
Old Dec 28, 2006 | 03:52 PM
The only problem is when I really want to haul something, I have to cover the subs with a precut 1/4 ply sheet for protection. So no bump while hauling big things. I really like that when I put the cargo mat in over the box that looking in the windows it looks totally stock (unless you are very well versed in xB speak).
riotmonkey85
Mar 6, 2015 05:22 PM
evolving_machine
Jan 13, 2015 08:04 PM
tenten
Nov 24, 2003 05:46 PM
shaefner
12
Oct 8, 2003 01:46 AM
Roach
Aug 17, 2003 03:06 AM
