Help! AIR PROBLEM (NOT BAGS)
Old Dec 31, 2006 | 09:21 PM
MikeC's Avatar
Default Help! AIR PROBLEM (NOT BAGS)
I was installing my new dvd player stereo, and when I put everything back togeather I realized that I can no longer use my fresh air switch. It has no resistance at all. Please help. Thanks in advance.
Old Dec 31, 2006 | 09:23 PM
TerribleTed's Avatar
Better go back in there and find out what you knocked loose or what wires are in the way blocking its action. Most likely is a mechanical problem from something popped out of place during the install.
Old Jan 1, 2007 | 11:45 AM
dudehitt's Avatar
There is a tiny little switch back there on one side. You probably knocked it out of position or got a wire stuck behind the metal actuator strip.
Old Jan 1, 2007 | 05:46 PM
MikeC's Avatar
The switch is still there, but there is no resitance when I move the lever, it just moves freely. Is'nt there supposed to be a cable or something hooked up?
Old Jan 1, 2007 | 07:35 PM
Pull the silver surround faceplate off again (if indeed the switch isn't changing modes, (IT DOES MOVE FREELY). The switch you move moves a lever that hits a little micro switch as you look to the center under the radio (it is red and black I think, but it has a little silver metal blade the the lever pushes on). If a wire has fallen in behind this micro switch it could keep it from actuating.
Old Jan 2, 2007 | 03:19 AM
MikeC's Avatar
Ah, I'll check that out and see if a wire came off. I know which part you speak of, but did'nt check the wire yet. Thanks and and I'll keep posting.
Old Jan 2, 2007 | 01:29 PM
dudehitt's Avatar
That's what I meant, thanks for clearing it up for me.
AxRxP
Jan 25, 2015 08:40 PM
toyotaisme
Jan 10, 2015 10:24 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
hotroddelux
Dec 3, 2014 11:33 PM
LinexA
Nov 21, 2003 02:54 PM
