NEED HELP finding wire for amp turn on
Old Jan 5, 2007 | 12:17 AM
low_wgn's Avatar
Default NEED HELP finding wire for amp turn on
i am needing to find out the color wire i need to hook into to turn the remote on the amp. i am keeping the stock stereo as i do not know what i want right now. what wire do you tie into to that only comes on when the stereo comes on?
Old Jan 5, 2007 | 12:43 AM
XB_BOY_2005's Avatar
the antenna power wire, i believe its orange/black if i am not mistaken..
Old Jan 5, 2007 | 12:46 AM
Tamago's Avatar
umm there is no power antenna on the xA/B/TC
i'd use the ACC wire, tap into the cigarette lighter circuit
Old Jan 5, 2007 | 01:02 AM
there is a wire for it or something.. thats the one i used
Old Jan 5, 2007 | 01:04 AM
zinker's Avatar
The gray one
Old Jan 5, 2007 | 01:10 AM
yeah... that works too hehe
Old Jan 5, 2007 | 04:48 AM
low_wgn's Avatar
thanks for the help... i went with the gray one.
Old Jan 5, 2007 | 09:10 PM
kzhorse's Avatar
Strictly Scionized
[quote="Tamago"]umm there is no power antenna on the xA/B/TC
It may not be a power antenna but the B does have a power antenna amplifier that is where he wants to connect the amp remote turn on to.
Scott
Old Jan 11, 2007 | 10:53 PM
snowromance's Avatar
are you plugging an amp directly into the factory head unit via RCA cables?
Old Jan 12, 2007 | 12:17 AM
low_wgn's Avatar
i am having to use rca converters....cause the factory head unit does not have the rca jacks. also does anyone ever have the problem of a constant hum?
Old Jan 12, 2007 | 12:23 AM
yea thats what i thought but i wasnt sure. im still new to the XB and thought for some crazy but good reason the manufacturer put RCAs from the factory. yea right.
where's the best deal for the converters man?
Old Jan 12, 2007 | 09:35 PM
low_wgn's Avatar
i already had them but i am sure that best buy or someone has them and they cant be that much.
Old Jan 19, 2007 | 12:35 AM
robmir's Avatar
Default Amp power on
[quote="kzhorse"]
Scott
Unfortunately this is not a solution because when you switch the HU input to CD or aux, the HU +12V out which powers the ant amp (black wire on mine), turns off.
Old Jan 19, 2007 | 04:20 AM
SanchezHacker's Avatar
I used this PDF when I was seting up my subs and amp, it tells what each wire does.
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
Sounds like a ground loop but yeah, thats definatly not normal.
Old Jan 19, 2007 | 06:20 PM
UV7's Avatar
UV7
It is either a ground loop or interference. Does the hum tend to go up and down in pitch with the RPM of the motor? If so, then it is most likely a ground loop caused by an inadequate ground. Make sure your amp is securely grounded. The ground location should be clear of any and all debris and, for best results, should be down to bare metal. This may require grinding away any paint from the ground location.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
minter66
Dec 15, 2014 01:45 PM
TJ
Nov 6, 2003 01:16 AM
vpkb
Sep 30, 2003 07:48 AM
