Aaawwww crap.
Old Jan 5, 2007 | 02:27 AM
mike6789k's Avatar
Default Aaawwww crap.
Found out that we didnt put enough grease on the front sway and now it is creaking whenever it moves!
Will it be easy to grease with a grease gun through the zerk? Or will I need to grease the inside of the bushing?
If I need to grease the inside, can I just spray some lithium grease on the side and try to get it inside... there is no way in hell i'm going to lower the engine cradle again though!!!
Please help!
Thanks,
Mike
Old Jan 5, 2007 | 01:29 PM
trdsparks's Avatar
You should be able to get to the bushing to grease them. I don't see why you would need to take the whole thing out again.
Old Jan 5, 2007 | 03:27 PM
web's Avatar
web
If the bushings had the brackets that had grease fittings on them, you're good to go. Just get a flex extension and a 90 degree grease neck and you should get it easily.
Old Jan 5, 2007 | 05:47 PM
mike6789k's Avatar
woooooop ok thanks!!!
but will that grease the INSIDE of the bushing? (i.e., the part that touches the bar, not the bracket)
k1114
43
Mar 1, 2023 03:08 AM
nightfox915
Apr 17, 2015 07:06 PM
TOKYO-INCIDENTS
May 4, 2006 06:12 PM
XBRachel
Apr 26, 2006 12:54 PM
