Garage1217
09-22-2008, 03:55 PM
Actual pink leds will fade in the next 3-6 months to a ugly color. The only proper way to do it is to use a white led and make pink lenses with the vinyl I sell. That way the color will last.
View Full Version : LED Swap Diagrams (Gauges / HVAC) Pages :
[2]
Garage1217 09-22-2008, 03:55 PM Actual pink leds will fade in the next 3-6 months to a ugly color. The only proper way to do it is to use a white led and make pink lenses with the vinyl I sell. That way the color will last. trrocks03 09-22-2008, 04:57 PM How much time would you guys estimate this to take? I am going to do the gauges, HVAC, and needles. 2 hrs? 5 hrs? a whole day? a whole week? Garage1217 09-22-2008, 05:17 PM For someone that has never done one, 5-6 hours would be a good estimate. trrocks03 09-22-2008, 05:42 PM ^^ Well, thats not too bad, probably try to knock it out in a weekend. New problem, what about the '07 HVAC LED failure problem? I don't want to start this and have that problem arise and have a warrenty issue. Any suggestions? Bought the '07 car in May 2007 Garage1217 09-22-2008, 06:10 PM It is not an LED problem but a board problem. Some fail and some do not. No way to tell if they will or not as it is totally random. Some fail with an led swap and some fail without an led swap. Just happens and stinks. trrocks03 09-22-2008, 07:41 PM So making the swap will void the warranty and not allow me to get the HVAC replaced from Toyota, even though the cause is not from that? Are they douches or just techinical? Garage1217 09-22-2008, 09:15 PM You modify anything electrical to the car and it will void warranty. They have no idea or no way to prove if you did somthing or if it flaked out. audioandy 09-29-2008, 06:06 PM if i were to do this myself how much would i be looking at for all parts for gauges and hvac in blue and white with reversed lcd screens? Garage1217 10-05-2008, 10:10 AM Usually comes out to around $50-$60 in parts if you order everything possible to do. wRadar 10-08-2008, 02:25 AM Hey, Jeremy: after doing the HVAC LED swap, the three button lights on the top right (defrost front, defrost rear, and mode, I believe) were dim or did not light UNLESS I pushed on the circuit board. This led me to believe that I had a weak solder connection on one of the LEDS or the new resistor (the 43 ohm one at R304) installed on the rear portion of the circuit board. I went through and re-soldered them, but now none of those lights work at all. I'm not sure where the breakdown is in the circuit, since I believe they're run in series and I can't test the LEDs or resistor individually. My best guess is that I may have fried the resistor by overheating it during re-solder. Any ideas? If it's the resistor, where can I find just one of those? Thanks! Have a great night, -Radar Garage1217 10-08-2008, 03:12 AM If they all stopped working, it sounds like you have a more serious issue. Do the gauge cluster lights work? If so the best bet would be to send it in and have me to an eval on it. wRadar 10-08-2008, 07:21 AM Sorry, I wasn't very clear with what I was saying there... Just those three lights (Mode, front defrost, and rear defrost) are inoperative. All of the other lights on the HVAC are working properly. If the resistor was bad, would that cause all three to burn out (since I assume they're wired in series)? izedaman 10-08-2008, 07:23 AM take a detail pic of the area on the board n post it up? wRadar 10-08-2008, 08:19 AM I could tomorrow (I'm on duty all night tonight), but the board looks just like any board that's had the LEDs swapped... Only those three lights don't light up. That, and you can probably look really closely at my soldering job and tell why I don't do it for a living. ;) izedaman 10-08-2008, 08:31 AM that was my problem, I had a splash of solder on some parts and bridged a cap, i was gettin a lil carried away with the solder sucker. If you have a multimeter you should be able to test the led's individually(in circuit), I was able to with mine. wRadar 10-08-2008, 08:44 AM I half-heartedly checked the LEDs with a multimeter, but I didn't really see if I had a good connection. I'll have to try again in the AM. Thanks for the help! Garage1217 10-08-2008, 04:58 PM Sounds like a bad solder joint or an led was nuked upon install / if one is overheated / toasted then all 3 will not work in the series. jbae1221 10-10-2008, 01:40 AM quick question. i'm about to buy some leds and resistors from you garage, but if i want a nice dark blue would it be better to do white led with blue vinyl or just use blue leds izedaman 10-10-2008, 02:44 AM white led with blue vinyl, would be my bet. Garage1217 10-10-2008, 07:00 AM I would just use blue leds, the vinyl will match blue leds anyways. If you want it darker, you could do the vinyl and then double layer it... jbae1221 10-10-2008, 12:35 PM hey garage.. i've emailed you a couple of time but i guess you didn't get them.. yea but i want a two tone blue and white.. so i'll order soon and send payment.. Garage1217 10-11-2008, 06:32 AM Hello, I was out of the country, I literally just got home :) I will be catching up on emails in the morning :) electrongeek 10-12-2008, 01:15 AM http://i125.photobucket.com/albums/p54/electrongeek/My%20Ride/interior2.jpg After hours of cursing and a six pack, I'm finally done with my swap. I bought all my stuff from garage. My radio will go under the hot iron next after my leds come in. Overall its been a fun project that I'm so proud of. I love driving at night! izedaman 10-12-2008, 01:17 AM reminds me to do my steering wheel hehe. those screws are tight jbae1221 10-12-2008, 01:29 AM so did you do white leds with blue vinyl or blue leds with blue vinyl.. because your numbers look white but the glow behind the needles look a little blue electrongeek 10-12-2008, 01:39 AM I used white leds with blue vinyl. izedaman 10-16-2008, 06:59 AM Finally finished http://i166.photobucket.com/albums/u106/izedaman/P1050686-1.jpg Garage1217 10-16-2008, 03:16 PM Looks hot man congrats! jbae1221 10-16-2008, 08:13 PM garage i placed an order about 2 days ago and payment sent via paypal Garage1217 10-16-2008, 09:31 PM Appreciate it :) Garage1217 10-27-2008, 11:03 PM Monday BUMP! Dade 11-04-2008, 08:47 AM Well, I decided to fly down to see Jeremy [Garage1217] and have him do my Cluster, HVAC, steering wheel, door locks LED swap. The results are amazing, and I had to post some pics of it. The new gauge faces are made by BlackCatCustom, which I bought on eBay. They are white during the day, and two-tone blue at night. Enjoy. http://i462.photobucket.com/albums/qq348/dade49/Car_Gauge1.jpg http://i462.photobucket.com/albums/qq348/dade49/Car_Gauge2.jpg I'd like to note that Jeremy does incredible work, and is priced for the quality. He's also not the most expensive either. I would reccommend him to anyone. trrocks03 11-04-2008, 08:33 PM Nice setup. I need to finish/post picks of mine. I havent done the steering wheel controls or the HVAC yet. I am also not very happy with my needles (I did them myself). The lights are very good though. Good job Jeremy. Garage1217 11-10-2008, 02:22 PM Back up and running! All order shipped out over the weekend since I was closed last week because of travel. Appreciate all the support fellow scion owners! Garage1217 11-19-2008, 09:24 PM Almost turkey week BUMP! Garage1217 11-24-2008, 10:09 PM Monday blues BUMP! aryan13 11-25-2008, 01:54 AM bump for info Garage1217 12-04-2008, 02:37 PM Best time of the year BUMP! aryan13 12-04-2008, 03:11 PM How did you get the needles to be white. I painted mine white but they pick up the blue from the guages. Did you have to change color of the LEDS nearest to the needles to achieve that look? Garage1217 12-04-2008, 03:15 PM You use white leds & apply my blue translucent self adhesive vinyl to the back of the gauge faces. So the white light shines through on the needles, while you see led blue on the gauge faces. That simple :) aryan13 12-04-2008, 03:30 PM Thanks for the info. Was hoping I could just paint them white. Looks like I will have to go with a diiferent color. When i have the OEM orange needles they seemed to work. You think red will show up? Garage1217 12-04-2008, 03:48 PM Red will look mostly red with a hint of purple depending on the paint. aryan13 12-04-2008, 03:59 PM Depending on the paint? What paint do you suggest? I used acrylic model paint when I painted my needles white. Garage1217 12-04-2008, 04:11 PM Will have to look up the exact color when I get home, but I use Kustom Kolors brand. mossfan15 12-04-2008, 05:57 PM im actually doing my led mod today :silly: do i have to pain my needles in order for them to be the color of my lrds when they are lit up? :tap: aryan13 12-04-2008, 06:21 PM Painted mine white and they lit up the same color as the LEDs. Garage1217 12-11-2008, 01:31 AM Gloss white is the color I use. Turns out stellar :) Garage1217 12-19-2008, 12:23 AM Happy Holidays from garage1217!! Get your orders in by tomorrow for a possible before Christmas delivery or just after! Garage1217 12-26-2008, 05:26 AM Merry Christmas everyone! Hope it rocked for all of you! Garage1217 01-06-2009, 06:19 AM New year bump! xbbox 01-06-2009, 11:04 PM Ordered a resistor kit from you yesterday, now get it here! Lol! Garage1217 01-07-2009, 12:21 AM Already shipped :) xbbox 01-07-2009, 10:01 PM You rock!!! Garage1217 01-07-2009, 11:12 PM No YOU ROCK! xbbox 01-09-2009, 10:21 PM Ok, maybe just a little bit, lol! Why can't we both rock? Lol! Garage1217 01-14-2009, 12:38 AM Tuesdays gone with the wind BUMP! Garage1217 01-20-2009, 02:39 AM Weekly bump! xbbox 01-23-2009, 06:45 PM What would cause the numbers to be all mucked up on the screen on the hvac after you install everything back? Did in blue with the resistor kit that you offer. Garage1217 01-23-2009, 07:07 PM Sounds like you cracked the display screen. Other than that, not sure? ScionJim23 01-23-2009, 09:06 PM Usually occurs when solder merges from one pin on the LCD screen to another on the screen. Make sure all pins have their own solder and no two are accidentally connected....lol.....A local person in my area did this and I fixed it for him. His HVAC screen had all sorts of wierd things displaying. He accidentally let some solder connect to prongs. Serrith 01-24-2009, 07:16 AM Just got done reading all 16 pages of info and I am definitly excited to start this project. I have a couple of beginner questions before I order all the equipment from Garage1217. On an automatic, shifting from Park to Drive and so on lights up that letter green. I am not sure how this occurs considering I have not taken it apart yet, but will this effect cease when you change out the LED's? My plan is to use white LED's with a couple different vinyls. Meaning I have to swap resistors. Now does that mean I have to change out all the LED's including the warning lights? I don't really mind the tire pressure and engine being amber. And last of all, I noticed that on alot of the two tone pictures it looks like the blue is kind of blue/white blended. Is it often that you would need to double up the vinyls to create more of a blue look? Thanks in advance for your time :o ScionJim23 01-24-2009, 03:17 PM The lights on an automatic are just amber LEDs. simply change them to white and use any vinyl you want. Just for a heads up, there is no need to swap resistors on the gauge cluster...they are only needed for the HVAC. you can use them on the ckuster to make them brighter if you want but they are bright already as they are supplied with a 13volt power supply. the HVAC needs the resistors as its power source is only 8volts. Serrith 01-24-2009, 04:03 PM Just for a heads up, there is no need to swap resistors on the gauge cluster Thats a relief. I know on one of the diagrams I saw it said that when using White LED's to switch the resistors. But if thats not necessary all the better. xbbox 01-24-2009, 04:16 PM Usually occurs when solder merges from one pin on the LCD screen to another on the screen. Make sure all pins have their own solder and no two are accidentally connected....lol.....A local person in my area did this and I fixed it for him. His HVAC screen had all sorts of wierd things displaying. He accidentally let some solder connect to prongs. Yeah, this was the problem. When I was desoldering it, some solder fell through the hole and was touching 2 of the prongs and I didn't see it when putting it back together. Whew, easy fix, glad it wasn't nothing major. I'm real careful with the screen, treat it like a baby, so hope I never crack any. Just freaked me out a bit cuz this was probably my 9th tC HVAC I take apart and that's the first time that's happen to me. Thanks everyone, and sorry I just getting back to you. Garage1217 01-24-2009, 05:22 PM Just got done reading all 16 pages of info and I am definitly excited to start this project. I have a couple of beginner questions before I order all the equipment from Garage1217. On an automatic, shifting from Park to Drive and so on lights up that letter green. I am not sure how this occurs considering I have not taken it apart yet, but will this effect cease when you change out the LED's? My plan is to use white LED's with a couple different vinyls. Meaning I have to swap resistors. Now does that mean I have to change out all the LED's including the warning lights? I don't really mind the tire pressure and engine being amber. And last of all, I noticed that on alot of the two tone pictures it looks like the blue is kind of blue/white blended. Is it often that you would need to double up the vinyls to create more of a blue look? Thanks in advance for your time :o - If you use a white led in the shifter area, it will look much better & also keep the colors which are printed on the auto tranny area. If you use any other color, some letters look funny or dark. - With any two tone, I recommend the resistor kit. It makes the overall two tone effect look much more defined. Every single one of my in house swaps have full resistor swaps performed on the gauges, hvac & steering unless they are going with a red theme. - Only one layer is needed with the vinyl unless you are going with the sky blue "very light blue color" The normal blue that I offer is a very very close match to a blue led. And the white areas will be very bright white. Looks stunning in person! Garage1217 01-24-2009, 05:23 PM Usually occurs when solder merges from one pin on the LCD screen to another on the screen. Make sure all pins have their own solder and no two are accidentally connected....lol.....A local person in my area did this and I fixed it for him. His HVAC screen had all sorts of wierd things displaying. He accidentally let some solder connect to prongs. Yeah, this was the problem. When I was desoldering it, some solder fell through the hole and was touching 2 of the prongs and I didn't see it when putting it back together. Whew, easy fix, glad it wasn't nothing major. I'm real careful with the screen, treat it like a baby, so hope I never crack any. Just freaked me out a bit cuz this was probably my 9th tC HVAC I take apart and that's the first time that's happen to me. Thanks everyone, and sorry I just getting back to you. Stellar! Glad Jim got it straight for ya! I had not seen this before so kind of hard to picture and troubleshoot. ScionJim23 01-24-2009, 06:36 PM Yea, I only learned from that one cluster I fixed for a local person. Other than that I would of been lost to without seeing it. haha.....as for resistors in the cluster, they definitely make the colors more pronounced with two-tone swaps...I just wanted to clarify that It was not needed if he did not feel like doing it, But yes, it makes it look better with two-tones. Garage1217 01-24-2009, 06:52 PM Correct, not a must, especially with single colors, but with two tones, it adds the magic touch! Serrith 01-24-2009, 07:21 PM Ok I will go ahead and swap the resistors. If I'm gonna do it, I want to do it right :o If you use a white led in the shifter area, it will look much better & also keep the colors which are printed on the auto tranny area. If you use any other color, some letters look funny or dark So if I switch out all the gear LED's to white on my cluster, will it still light up green to tell me which gear I am currently in? I know it's not necessary (as you should know which which gear you are in) but I am just curious. Thank you for your replies. ScionJim23 01-24-2009, 08:22 PM no if you switch them to white on the cluster they will all light up white when you go from one gear to the other. the current leds that are on the cluster are green.......switch them to white and you will be set.....I think Jeremy may be talking about the actual Shifter area in the center console area? Serrith 01-24-2009, 09:10 PM I see now, thanks for clearing that up. And I think you might be right about what Jeremy was speaking of. I was getting that impression as well. All though I haven't seen any diagrams or info for changing the lights in the center console area. Garage1217 01-25-2009, 05:02 PM Correct, on the cluster, each letter has it's own separate led on the auto tranny area. You can make them any colors you want :) I was speaking about the shifter area. xbbox 01-26-2009, 12:05 AM Anybody know what would cause just the speedo needle not to do the sweep? And yes, I've checked to see if it was on to tight. It's just bearly on, but no movement from the post itself even when the needle is off. Garage1217 01-26-2009, 12:23 AM Do all the other gauges sweep? xbbox 01-26-2009, 02:08 AM Got it. For some reason the sweep had turned itself off. Turned it back on and also found out that you can turn the seat belt buzzer off, WOO HOOOOO!!!!! Thanks! jbae1221 01-29-2009, 03:52 AM do you have a diagram of the resistors that are needed to be swapped on the gauge cluster.. i bought the resistor kit but i'm not sure of the resistors that i need to replace jbae1221 01-29-2009, 04:56 AM nm.. i found it Iceman04503 01-29-2009, 05:05 AM any posts on how to remove the HVAC? I don't want to break anything. Garage1217 01-29-2009, 02:46 PM HVAC 1. Take off your shift knob by twisting it counter clockwise many times. 2. Pull hard on the lower console towrds the back of the car and slightly up. Will pop out. 3. Unplug cig lighter from lower console 4. Shut the radio door 5. Pull off entire top console 6. Unplug hvac wire harness 7. Take out 6 screws that hold on the hvac unit. 8. Pull hard on the HVAC unit box "backside of console" and the temp knob will pop off Iceman04503 01-29-2009, 03:45 PM cool thanks man. jbae1221 01-30-2009, 08:00 PM are there 2 different kinds of polarized film?? my hvac lcd blue is a different blue from my cluster lcd... both are backed by white leds and i've turned the film many different ways and it still won't get right.. i'm just wondering Garage1217 01-30-2009, 08:36 PM It will be a slightly different blue as the gauge cluster LCD is backed with a silver lining & the HVAC is backed with a white plastic lining. They should be close, but not exact. I have been contemplating removing the silver backing from the GC & useing two layers of white paper or plastic under it. jbae1221 01-30-2009, 11:10 PM ok... i have good news and bad news... good news.. i took the backing off the cluster lcd and put a piece of polarized film there and put a piece in front and got close to the color of the hvac lcd... now if we could put a solid piece of white plastic behind that on the curve to get rid of the reflection and it would be perfect... now the bad new.. my middle 2 led for the knob aren't working.. sometimes they work and sometimes they dont'... now i did kinda mess up the ic power chip and this could be the problem... but all the other ones work... any way i can get a new ic power chip and any way to trouble shoot that.. thanks in advance jbae1221 01-31-2009, 04:31 AM yea... you need white plastic i tried paper and it didnt' look right but some plastic/// to me it seems like you need something to polarize behind it for the polarized film to work on front... that's why i put film on front and back Garage1217 01-31-2009, 05:00 AM You do not need anything behind it to change the front. Honestly I am not understanding why yours is so different, I do a ton of these and they are all super close, just a hair off color wise. Nothing drastic. Shoot me pics via email to jeremy@garage1217.com so I can see whats up :) jbae1221 01-31-2009, 05:13 AM will do... but i already change my gc lcd... but i'll shoot you a pic of my hvac one and my gc was way darker than my hvac one.. give me a day Garage1217 02-15-2009, 02:37 AM Weekend BUMP! jovan_gonzales 02-18-2009, 09:22 PM So, I bought my resistor kit from you, and I don't think they are correct? Can I e-mail/pm you bc none of mine are the correct values, jw if they're supposed to be off. Thanks! Garage1217 02-18-2009, 09:24 PM They are correct values :) Reading a resistors read a little funny. Examples are... 430 = 43 ohm 131 = 130 ohm 561 = 560 ohm 681 = 680 ohm 4220 or 422a = 420 ohm jovan_gonzales 02-18-2009, 09:31 PM bwahahahaha, thanks. I am le retarded. And to think I took electricity and optics ... my physics prof would be upset. Thanks! Akrylic09 02-18-2009, 10:00 PM hey jeremy did you ever end up making those "replacement" needles? Garage1217 02-18-2009, 10:04 PM Hey no prob! Just shoot me a pm if you have any other questions! Actually the most common complaint I get is "You did not send me a 681 or a 561.... You sent a 189 and a 195" And I have to tell them to rotate them 180 degrees and re-read the resistor value :) Happens to the best of us! Garage1217 02-18-2009, 10:05 PM I did not, the local manufacturer never came through with my order after 3 months. He was quite busy and the product was good but I had to ask for a refund as I was hoping to have them in the first few weeks. I am not sure if he still makes them at all. Garage1217 02-22-2009, 03:26 PM Sunday BUMP! Garage1217 02-27-2009, 03:33 PM Friday BUMP! silver_bullet05 03-02-2009, 06:21 AM pics arent working for me SquallLHeart 03-02-2009, 07:30 PM ^^ i'd blame your dial-up connection. cavalierkid888 03-06-2009, 05:09 PM Is there anything like this that shows the placement of the gauge resistor upgrade and steering wheel resistor upgrade? Garage1217 03-06-2009, 06:04 PM Yes, check my website :) And on the steering wheel controls, it only has one resistor on it from memory... http://www.garage1217.com/album1_004.htm cavalierkid888 03-06-2009, 06:56 PM :bow: Thanks! Garage1217 03-12-2009, 08:08 PM Almost the weekend BUMP! WiCkeDImG 03-20-2009, 09:11 PM its prolly been mentioned before but what r the LED's the go in the door locks and steering wheel controls, they are smaller than the gauge face ones, im looking to buy them but dunno their name/part #. Garage1217 03-20-2009, 09:23 PM You can use plcc-2's in the door locks. They are technically 1206 sized, but as stated, plcc-2 works just fine & are brighter :) The steering wheel controls are normal plcc-2. cavalierkid888 03-22-2009, 05:51 PM Just did the resistor upgrade for the steering wheel controls, and gauges that are both swapped with blue led's. Looks much better now! Garage1217 03-23-2009, 03:12 AM That is what I am talking about :D Garage1217 03-30-2009, 04:13 PM Monday BUMP! kphyle22 04-01-2009, 09:56 PM so all the LED's in the gauges are plcc-2's right? So i would only have to buy however many i need of those? and no resistors or anything else. all I think i'm gunna do is swap some out for blue. Garage1217 04-01-2009, 10:09 PM Yes they are plcc-2. I highly recommend the gauge cluster resistor kit & the hvac resistor kit is a must if you plan to change those. kphyle22 04-01-2009, 10:12 PM is that the two dollar part on your site? the resistor upgrade? or is there a different resistor kit that i need and thats just an upgraded one from that Garage1217 04-12-2009, 03:18 AM Correct :) The $2 kit on my site. Garage1217 04-23-2009, 01:36 AM Evening BUMP! Garage1217 05-03-2009, 06:02 PM Sunday BUMP! Garage1217 05-15-2009, 01:29 AM Almost FRIDAY bump! chadfo 05-17-2009, 10:40 PM awesome post! Garage1217 05-25-2009, 05:25 AM No charge for the awesomeness! Garage1217 06-01-2009, 10:25 PM Monday BUMP! STlTCHES 06-04-2009, 08:23 AM Hey there Garage I did the resistor swap on my hvac which i have white LEDs in already and for some odd reason when i switch the headlights on on the car the hvac wont light up but when the headlights are off the LCD screen lights up. Note: i did some how manage to lose the 130ohmresistor in my stupid shag carpet would that effect it? Garage1217 06-04-2009, 03:06 PM Do you own an 2007..? STlTCHES 06-04-2009, 07:22 PM Nope i own an 06 Garage1217 06-04-2009, 07:41 PM That is very bizarre... Does the gauge cluster light up fully..? STlTCHES 06-04-2009, 07:45 PM I did an LED swap and resistor swap on my gauages and they light up/work just fine Garage1217 06-04-2009, 07:50 PM Not sure man, something is not right, that is for sure! Without seeing the unit first hand, I could not diagnose it. You are welcome to send it in. Just shoot a PM for specifics. Garage1217 06-05-2009, 10:23 PM FRIDAY BUMP! Thank goodness for the weekends! Garage1217 06-13-2009, 04:44 PM What a nice weekend BUMP! Garage1217 06-21-2009, 09:27 PM Right on! Another weekend come and gone BUMP! Garage1217 07-20-2009, 08:15 PM Monday BLUES bump! Garage1217 07-31-2009, 07:37 PM TGIF BUMP!!! The new forum is running great! Garage1217 08-09-2009, 04:52 PM Weekend BUMP! Order parts today, they ship tomorrow "Monday"!!! Expected arrival would be Wednesday - Thursday! Garage1217 08-18-2009, 08:56 PM Tuesday blues BUMP! Garage1217 09-01-2009, 03:17 PM The highly desired aluminum ringed 194/168 bulbs will be back in stock any day now! Get yours before this next large shipment sells out again! Oh and BUMP haha :) Garage1217 09-16-2009, 05:06 PM Mid week BUMP! Garage1217 09-24-2009, 07:22 PM Thursday BUMP! Garage1217 10-12-2009, 04:13 PM Monday blues BUMP! Hope you all had a great weekend! Garage1217 10-21-2009, 08:21 PM Wednesday bump! Friday here we come! Tagnal 10-21-2009, 10:52 PM Has anyone tried using different colored leds for the LCD Display in the HVAC unit before? It takes 3 LEDs, so for example, if someone changed the left-most one to blue and the right-most one to red. (maybe left center as orange? or white? i dunno). How does that make the LCD look. Any pictures? Garage1217 10-21-2009, 11:02 PM I have years ago, but not on the tC. It was on an xb1. It was actually a red / white / blue fade with reverse screen. You can see it on this page. And below it, was a red, white and blue not faded, but cutoff sharp. http://www.garage1217.com/album1_009.htm SquallLHeart 10-21-2009, 11:02 PM i have on a tC.. no pictures though of the hvac.. effects are similar like mentioned above. here's a blue and green on the speedo and odo lcd http://i16.photobucket.com/albums/b28/SquallLHeart/LED%20swaps/DSC_0336.jpg Tagnal 10-21-2009, 11:12 PM Ahh so that's how that effect was done. Was trying to decide how to do my HVAC colors. maybe everything on the left side (buttons and left half of temp display) blue and everything on the right red. Then I was looking at the lcd screen and wondering if doing a fade from blue to red would look decent there too or if it would just look weird. I'm not really feelin that faded look i guess. oh wells. Thanks for the example! :) Tagnal 10-21-2009, 11:29 PM i have on a tC.. no pictures though of the hvac.. effects are similar like mentioned above. here's a blue and green on the speedo and odo lcd http://i16.photobucket.com/albums/b28/SquallLHeart/LED%20swaps/DSC_0336.jpg Ohh, the 2 led change does look pretty nice. Maybe for the HVAC one using 3 white leds with colored film over it would work. blue-purple-red. That might blend pretty well. Garage1217 11-02-2009, 03:10 AM Holidays are coming BUMP! I would sure love to earn your business! Hit us up anytime via PM, Email, Aim or Yahoo! I have been around for years rocking the scion community & plan many more years of quality LED work & products! Garage1217 11-18-2009, 01:43 AM Tuesday night BUMP! Getting cold out, even here in Az! Garage1217 11-28-2009, 12:59 AM Hope you all had a safe & fun holiday! Garage1217 12-06-2009, 08:58 PM Christmas is coming BUMP! Cannot wait! get your orders in asap for a quick delivery! Garage1217 12-23-2009, 02:06 PM Happy Holidays! I hope everyone stays safe on the roads and may you all have an excellent Christmas! Garage1217 01-09-2010, 08:43 PM Weekend bump! Wow 2010 already? Garage1217 01-23-2010, 12:26 AM Been a very busy few weeks with the new products on the website! Do not forgot to check out the new flagship LED dome lights! They are wicked! http://store.garage1217.com/new-flagship-36-chip-dome-light-36led-output-wi3636.html We also now stock a longer festoon for the xA as well! http://store.garage1217.com/new-aluminum-3175-festoon-bulb-color-matches-the-194168317519416839.html And for those that have older clusters with twist style bulbs, we have our custom built led replacements that cast a very even light! Mr2 guys are going nuts for them! I bet the Lexus guys will catch on quick as well! http://store.garage1217.com/custom-twist-socket-aluminum-ringed-high-output-bulb.html Garage1217 02-08-2010, 03:07 PM Monday BUMP! tito07tc 02-15-2010, 06:26 AM how do i remove the plastic thats attached to the gauge cluster? and to the lcd screen? i took it all apart but that one plastic that is there dont let me get a clear shot at all of the gauges. Garage1217 02-15-2010, 03:53 PM Which plastic are you speaking about? The clear front, black surround or white back? tito07tc 02-15-2010, 04:41 PM its the last plastic that is in betweek the lcd screen and the leds. cuz i could see all the gauge leds but really cant get to them and the rest of them are covered by that plastic. would you like for me to take a pic? Garage1217 02-15-2010, 04:55 PM Oh I think I know what you mean. You actually have to take the white back plastic off the cluster. Also remove the needles & LCD itself. Then remove the circuit board and place it into the white plastic backing while you work on it. Hope that makes sense. Garage1217 02-26-2010, 02:11 PM Friday BUMP! This week has gone by way to slow! Garage1217 03-11-2010, 04:28 PM Almost Friday bump! Garage1217 03-26-2010, 08:48 PM TGIF BUMP!!!! Man this weekend could not come soon enough! Garage1217 04-15-2010, 09:53 PM Almost FRIDAY bump! Garage1217 05-04-2010, 08:37 PM Tuesday BUMP! Man this year is FLYING! Is it May already? Garage1217 05-27-2010, 03:16 AM Super ninja Wednesday BUMP! 3 day weekend, here we come! Garage1217 07-12-2010, 03:45 AM Happy heatwave BUMP! Garage1217 08-21-2010, 02:04 PM Bump! PLCC-2 LEDS JUST 0.49 CENTS!!! Garage1217 09-09-2010, 01:35 AM Weekend coming up BUMP! Cannot wait! Garage1217 10-05-2010, 04:50 PM BuMp! Garage1217 10-26-2010, 02:56 PM Cooler weather is finally here BUMP! Bertmagik 10-27-2010, 12:41 AM sooooo i know im gonna sound like a total noob... probably because i am when it comes to this stuff... but is the hvac mod like the heater knob and buttons and such? Garage1217 11-24-2010, 04:50 PM No worries and you are correct. HVAC = AC / Heater control unit. Bertmagik 12-05-2010, 08:46 PM awesome thanks! ive been spending a lot of time on ur website lol next time the car is in the shop im pullin it all out and sending it your way for sure! Garage1217 01-05-2011, 05:50 PM 2011 Already BUMP! Hope all of you had an excellent new years! Garage1217 01-20-2011, 05:26 PM Bump! To note, all colors of all bulbs are back in stock! And of course all other items are in stock and good to go! Browse around our web-store at http://store.garage1217.com/ Garage1217 02-22-2011, 08:34 PM Hope you all had a great Presidents day weekend! Garage1217 03-11-2011, 05:48 PM TGIF Bump! Garage1217 03-29-2011, 02:24 AM Monday is OVER WOOHOO BUMP! Garage1217 06-01-2011, 03:07 AM Tuesday BUMP! Garage1217 08-06-2011, 04:36 PM Saturday BUMP! Garage1217 08-27-2011, 08:36 PM Hope this helps ! Garage1217 09-20-2011, 06:36 PM September BUMP! Garage1217 10-13-2011, 11:02 AM October BUMP! Garage1217 12-22-2011, 04:03 PM Merry Christmas / Happy holidays to all my friends & customers on here! Garage1217 01-17-2012, 12:13 AM January BUMP! Garage1217 04-30-2012, 07:45 PM Random April BUMP! Hope you all are doing awesome! Garage1217 05-27-2012, 04:43 PM Hello Friends! Within the hour, Many select LED's and LED bulbs will be on a drastic sale on my website for Memorial Day. I am talking BIG Discounts! A direct link to my webstore: http://store.garage1217.com/ Sale will go through Tuesday the 29th! |
