RedFox180
01-11-2007, 04:26 PM
My XB is such a pain to fill up at gas stations. It seems I have the get the pump in there just right and then I have to go slowly. I ALWAYS have to hold it b/c it keeps clicking off like it would if it were full, but it isn't.
Does anyone else have that problem?
usdmbB
01-11-2007, 08:53 PM
Had that happen a few times, mostly just a pain in the a**!
RedFox180
01-12-2007, 12:00 AM
Yeah! It's almost like there's too much curve or slant or something inside the tube and it's causing the gas to slush around so much the machine thinks the tank is full when really it's just the gas being tossed around. It really ticks me off
Sciond
01-12-2007, 01:21 AM
old news do a search for the TSB
Metro273
01-12-2007, 03:37 AM
I guess it depends on the year cause my '05 doesn't do it.
jwaj2002
01-12-2007, 03:47 AM
yea it must be, because my 06 doesn't do it, I think it also has to do with the pressure the gas is flowing in the hose does go nearly straight down though
See this:
http://www.scionlife.com/forums/viewtopic.php?t=4203
And go to your dealer. They swapped mine out and it made a huge difference.
scion08
01-12-2007, 04:05 AM
not mine.. when its full, it just clicks ones. if i try to push it, it just overfills.
Bsbox
01-12-2007, 04:11 AM
My 05 did do it but i got a new gas tank and fill pipe on warranty. I hate that you have to go looking for TSB's. Dealers should make you aware even if they do get a few people asking for warranty work they don't need. I went in and told the dealer about the TSB and he acted like i was trying to hustle him into getting free work done. I was like "yeah man, what i just said, the pump keeps stopping!" I understand it's not a recall but deezam.
rallying_the_scion
01-12-2007, 12:54 PM
never had that issue till i got to alaska...alot of gas stations i need to stand and fill it...which sucks when its about 10 degrees outside!!!! back in Tejas..no problems
ignatiusaids0o
01-12-2007, 04:03 PM
I used to work at a gas station. Most of the time it's air in the tank from topping it off too much.
xBen700
01-12-2007, 04:09 PM
I have the same problem sometimes.
I have found that if you angle the nozzle, so that the handle is pointing at the back of the car it doesn't happen at all!
ElChupacabra
01-12-2007, 04:14 PM
After checking the NHTSA website for a TSB on this issue Im seeing we can also get our fuel injectors cleaned for free. I might have to take advantage of that during my next oil change....
