View Full Version : MR2 engine swap?
getz31
01-12-2007, 11:15 PM
does any one know if the 93' 3sgte engine from a MR2 will fit into the XB?
bfurches
01-13-2007, 12:22 AM
i believe someone got the 4sgte to work
8psiXA
01-13-2007, 03:14 AM
i saw a rwd yaris with an mr2 turbo motor in it at sema.. so it can be done :)
getz31
01-13-2007, 04:51 AM
becuz i found a website where they are selling that engine with a fwd tranny
aveosam
01-14-2007, 07:08 AM
hmmm i think its too big for the front and would need to be rear mounted like it is in the mr2...imo a waste of time and money...mind as well just find a mr2 to stick that engine into
dexter_5000
01-14-2007, 11:36 PM
its usually done with the paseo and tercels. the tranny for the mr2 is still a transaxle design. which is why i can work in fwd cars. the thing your gonna fight with on this is having it pass an obd II system test.
cessblood
01-17-2007, 01:44 PM
I think someone is trying to put a 3sgte engine into a tC
javastan
01-17-2007, 02:02 PM
If you have enought money they could get an LS1 to fit.
cessblood
01-17-2007, 02:18 PM
Like I say all the time with enough money. you can do anything.
Sci0nXa
01-22-2007, 03:04 AM
im still waiting for someone in the states to put a 2zz in an xa.
ogerdgonz
01-23-2007, 05:00 PM
A company in Australia is putting the 3sgte into a vitz (yaris).
hotbox05
01-23-2007, 06:39 PM
3sgte is HUGE.
if you fit it it will most probably be a rwd tube chassis
trdsparks
01-24-2007, 05:43 PM
With enough time. motion, pressure, & money you can do anything.
hotbox05
01-24-2007, 08:41 PM
true. but that motor is large. and very , very expensive when it comes to parts and maintanence.
trdsparks
01-24-2007, 08:47 PM
A 3S-GTE? Expensive?
hotbox05
01-24-2007, 09:21 PM
yes. 3sgte and 2jz are the most expensive toyota engines to get parts for. both aftermarket and stock.
06charger
01-26-2007, 10:10 AM
2 MONTHS 2ZZGTE XB
aireck
01-26-2007, 11:53 AM
swaps are on their way... 2007 is the year of the breakthrough!!
hotbox05
01-26-2007, 03:26 PM
that's good cause i need a 1zz swap , 2zz swap of legal greddy supercharger soon.... this being totally slow thing is starting to get really, really annoying. 15.6 is way slow....
06charger
01-26-2007, 08:52 PM
you ran a 15.6 1/4mi?
06charger
01-26-2007, 08:58 PM
To do a 1zz swap maybe check out the new Toyota Vitz euro T-sport motor mounts I believe it comes with a 1.8 140hp engine which is the 1zz, the mounts should bolt up to our Box???????????????????????????? 6spd tranny might be custom mounted????????
Inuyashalover
02-06-2007, 07:20 PM
be nice is we had a company like hasport to start making motor mounts for scion swaps... oh well one can wish for the easy way. :pray:
ogerdgonz
02-13-2007, 04:25 PM
the rail needs to be cut back in order for the larger motors to fit in the xb. I have crappy photos of the yaris from europe.
Tamago
02-24-2007, 09:52 PM
narrow minded fool
kustom_play
02-28-2007, 07:59 PM
why not pull one from an all-trac celica
its a 3sgte with an AWD tranny
or if you didnt know already, they make a BEAMS edition engine
i dont know the specs since i cant read japanese
Tamago
03-01-2007, 12:11 PM
heavy ___ motor. ruins vehicle dynamics.
stick with light and small. like a 4AGE
kustom_play
03-01-2007, 12:15 PM
3SGTE is not a heavy motor, its a 2.0 200hp (usdm)
your better off to go with a BEAMS 3SGE 200hp non-turbo
cessblood
03-01-2007, 03:24 PM
3SGE Dual VVTI Beams is a good motor. it's 200hp to 210hp
kustom_play
03-01-2007, 04:19 PM
yea ive been looking into one for a long time for an MR2 project
they also make a Black top BEAMS for the Lex IS
its a bigger motor i think something like 230 range but i dont think it will fit
its a bit pricy though but well worth it
hotbox05
03-01-2007, 08:11 PM
why would you get the beams motor now? it's not even powerful. you guys do know that with a 3sgte you can get like 600 whp daily , and like 800 whp on a dyno queen right ?
kustom_play
03-01-2007, 11:58 PM
yea what do i know, i only owned/built one for the last 4 years
kustom_play
03-02-2007, 12:03 AM
600 HP is not a daily driven MR2, right now were pushing 480 and its starting to be a problem
im sure since you know so much, you know that the MR2 has a huge problem with snap oversteer
3sgte is not the best motor, the 5SFE is a much stronger block, which you can use the head of the 3SGE and build up that way
but once again im sure you know all this
http://www.mr2oc.com
sign up and learn a bit about the engines your talking about
Tamago
03-02-2007, 07:26 PM
3SGTE not a strong block?
will you specify which 3S you're referring to as there were a couple different variations?
hotbox05
03-02-2007, 08:51 PM
oh I know. and snap oversteer is a problem with most lightweight rear engines cars.
sorry mid engined. don't go getting high and mighty on me. and yes there are daily 600whp mr2's out there. it might not be the smartest way to build a car but I've seen it done more than a few times , have worked on one , and drove two others. all ranging from about 475rwhp to just over 620rwhp.
