Regional - Deep South AL, AR, LA, MS
any big amps installed?
Old Jan 13, 2007 | 12:45 AM
lantzdarla's Avatar
Default any big amps installed?
hey,i was wondering if anybody out there has a high wattage amplifier installed in their xb?i just bought two rockford fosgate T1 12's and i want to put a rockford fosgate T10001bd amp with them and was wanting to know if anybody has close to the same setup?
Old Jan 13, 2007 | 03:32 AM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
i have an 800 watt MA Audio amp running two 8s and two 6.5s...
nothing close to yours tho ;)
Old Jan 13, 2007 | 04:37 AM
lantzdarla's Avatar
thats kinda funny because im about to remove an MA 800 and two MA12's from my box.the reason for my concern is the amp im getting has a 150 fuse and the requirements state that i need a minimum of a 100 amp altenator,2 gauge wiring and a 25 farad capacitor.my MA dont need all that.do you know what size altenator we have?
Old Jan 13, 2007 | 06:09 AM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
i think ours is a 90 amp...
Old Jan 26, 2007 | 04:32 AM
tctrs1's Avatar
I have a 600 watt RMS 1400 watt MAX JBL Amplifier with a 12" JBL 1600watt sub....what gauge wiring should I run? pls pm me with a response
Old Feb 5, 2007 | 10:12 AM
lantzdarla's Avatar
this is about half the stuff i'm installing...minus the cap and crossover..i'm not using the crossover and i have a 6 farad cap.i just bought a t4004 amp,a180 amp alternator and a stinger 1000 battery to go with this.now i need to upgrade the stock speakers. i may reinstall the stock back springs so the weight of the box and all wont make me sag.it ought to level out.i'm going to remove the back section of the rear seat and make an amp rack.i'll upload pics as i go.i have two more t112's but they are dual 2 ohm and this amp isn't matched to them so i wont be using them.
Old Feb 5, 2007 | 04:58 PM
Gothbox's Avatar
MA Audio's site is down right now so this was the only way I could find pics of what I got.
this is the amp that I have right now, I need a second one.
http://www.sonicelectronix.com/pictures.php?id=2695
I just have 4gauge running to the amp and it needs more power, it melted my last fuse block b/c it was pulling somuch power it got to hot. I need to run 0 gauge. I have the stock alt, and a Yellow top under the hood.
and here are the subs that I am running.
http://cgi.ebay.com/MA-AUDIO-HK12X2-...QQcmdZViewItem
Old Feb 5, 2007 | 05:45 PM
lxt_123's Avatar
Here are all the info regarding wires and gauges
Old Feb 5, 2007 | 05:46 PM
lxt_123's Avatar
here is again:
http://www.the12volt.com/wiring/recwirsz.asp
Old Feb 5, 2007 | 05:55 PM
Gothbox's Avatar
does anyone even make a 2 gauge? I have only known 10, 8, 4, and then 0.
Old Feb 5, 2007 | 06:24 PM
lantzdarla's Avatar
look on ebay..you'll find all the 2 gauge you want!
Old Feb 5, 2007 | 06:39 PM
lantzdarla's Avatar
this is some other stuff i tried in my xb.
Old Feb 5, 2007 | 06:42 PM
Gothbox's Avatar
well sure, you can find ANYTHING on E-bay.
I am just saying that I worked at a car stereo install place and worked in both sales and install and never came across 2 gauge in the product lines or installed it, always been 8, 4, or 0. I am going to go with 0 when I get the second amp. It is a pain in the butt to run in the xB, but I will need it.
Old Feb 5, 2007 | 06:51 PM
lantzdarla's Avatar
i'm about to find out!
Old Feb 5, 2007 | 07:06 PM
Gothbox's Avatar
you are going to have to run it under the seats, not along the door seal. there are holes in the ribs that the seats are mounted to that you can run them in to the back and you will have to pull the back seat up.
Old Feb 5, 2007 | 07:15 PM
lantzdarla's Avatar
thanks for the info!you just saved me a headache.
Old Feb 5, 2007 | 07:18 PM
Gothbox's Avatar
no prob, have 0 in a few xBs so I have learned the hard way. good luck
Old Feb 8, 2007 | 01:55 AM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
so what are you going to do with your ma audio stuff???
Old Feb 8, 2007 | 05:36 AM
lantzdarla's Avatar
probably going to sell it on ebay, unless you are interested.
Old Feb 8, 2007 | 06:07 AM
lantzdarla's Avatar
