Agency Power & Wilwood
Old Jan 13, 2007 | 06:43 PM
gqdabien's Avatar
Default Agency Power & Wilwood
Does anybody know if the agency power stainless steel lines will work with the Wilwood big brake kit?
Old Jan 13, 2007 | 07:16 PM
KINGxOFxSKA's Avatar
Unique Scionikz
I would assume that the big brake kit would already come with ss lines.
Old Jan 14, 2007 | 06:13 AM
gqdabien's Avatar
The ss line fittings that came with my wilwood kit does not fit onto the car properly. However i have a set of Agency Power SS lines.
Does anybody have experience using a different set of SS lines with their wilwood BBK ? thanks
Old Jan 14, 2007 | 06:26 AM
iqbokc's Avatar
i encountered the same problem as you are experiencing. all you have to do is call the wilwood company and tell them that they sent you a set of ss brake lines that doesnt fit into the clip space. and make sure you tell them the yr of your car. i have a 05 and i dont know what yr ss lines they sent me but it didnt find. so i called them and had to wait 2 days before the new one came and it went/fitted fine the second time. wilwood packing company really blow monkey *****. when i first purschased the brake set i thought cool i got everything i needed. so like always i would check to make sure its the right stuff i ordered, but the day my kit came in i was leaving for work so all i did was checked the set on top and didnt bother looking at the secod set at the bottom. so when i went to install my brakes the freaking calipers were different. i was very upset. took my 3 weeks to finally install everything. why? because the messed up the entire package. one caliper was correct and the other was wrong, missing the entire set of bolts that uses to attach the hub to the disc itself, then the brake lines didnt fit. so all in all it took 3 weeks to have all my correct stuff so i could begin the install. so just call them and tell them ur problem and they will send u the correct one. but beware, dont think u got away with a set of ss lines. these ppl will actually tell u to mail the wrong ones back to them, of course they will pay via ups. good luck, hope this helped u..
Old Jan 15, 2007 | 05:00 AM
gqdabien's Avatar
Thank you very much. However when i contacted wilwood they wanted to know the exact measurements of the fittings that i needed, so they can send me a correct set. BC my fittings are all the right size, its just that the thread pitch is wrong.
Old Jan 15, 2007 | 05:12 AM
iqbokc's Avatar
make it easy for urself my friend. just call wilwood again tmw and just tell them that the set of brake lines doesnt fit at all. must be a wrong set. period. and demand them to give u a new set asap! if they want business and keep their good sales going i believe they will exchange it without any hassle. be demanding to them, dont let them hussle u. is ur flex line part number: 2209365 or something different?
Old Jan 15, 2007 | 05:19 AM
gqdabien's Avatar
I think the one that was included is stated 220-8336. is the number you provided the correct one?
I will give them a call again tommorw.
Old Jan 15, 2007 | 05:26 AM
iqbokc's Avatar
now u see why ur set of line doesnt fit? trust me, call them tmw and tell them wut i told u to go do. and just out of curiosity give them the part number i listed and ask would those be the ones im looking for. play stupid with them. pretend u r a new customer and ask them u like to know how much are the flex ss brake lines for ur model tc and yr and then ask for a part number compare it to mine and urs..and obviously u know ur part number does not fit ur tc so mine IS the correct one. why i know? because i had the same problem and later got the correct set. if u follow my way and call them. u will get the correct part and be a happy camper. good luck and update me on how it goes with them.
Old Jan 21, 2007 | 04:03 AM
gqdabien's Avatar
I recieved another set of adapters, can anyone confirm the size is right before i have a mechanic put them on?
-3 to 10MM x 1.0 IF Brake Adapter
StreetStandard
Jul 6, 2015 10:40 PM
CrowJenkins
May 4, 2015 04:52 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
