Scion_XXXBoX
12-08-2003, 07:57 PM
my buddy got a set of 18" wheels for his 2001 civic and gave me his old 17" rims. . . .i am wondering if it is possible for it to fit properly onto my car? will i need to do something about the offset? or is this just not recomended??? any info will help!
Infiz
12-08-2003, 09:00 PM
The Scion & Civic both have a 4x100 lug pattern & a very similar offset - just about any wheel that fits a civic should fit a civic with no problem.
bBted
12-08-2003, 09:07 PM
it will fit...remember to get hubcentric rings 8)
cuz they have different centrebore sizes
debris
12-09-2003, 03:42 AM
io had a honda 94 accord....my tires are enkie's with a 4 bolt pattern but they would not fit my xb.........the holes were like 2 mm off.
bBted
12-09-2003, 04:01 AM
thats becuz 5th gen accord use 4x114.3, but civic use 4x100 just like scion
Scion_XXXBoX
12-09-2003, 08:11 AM
Thanks for all the reply's. . .i'll make sure to pick up some hubcentric lugs. . .i'll post pics when they are put on. . .
ScionVan
12-09-2003, 08:28 AM
Actually, do be careful because Hondas can take wheels up to, and over 45mm in offset. And if the wheels are that high of an offset, and more than 7" in width, they WILL rub on your Scion. As long as they are 42mm or below though, you *should* be safe.
its_ikon
12-10-2003, 12:40 AM
just do a test fit and see how everything lines up.
Scion_XXXBoX
12-10-2003, 08:37 PM
once again, thanks for the information. . .does anyone know where i can pick up the hubcentric rings in the sf area???
ScionVan
12-11-2003, 10:55 AM
Your best bet is to call up some of the local wheel works or smaller wheel/tire shops. Check out mach III in the SF area too.
