Help My HID's :)
Old Jan 19, 2007 | 03:29 PM
ayS's Avatar
ayS
Default Help My HID's :)
hi, i just ordered some HID's and i have them installed. for the most part i think i got them connected right. i went to test them to see if they would turn on. but they did not. does anyone know what could be the reason why? i went back and made sure everything was secure. but...i still am coming up short and they are not turning on.
already did a search and came up with nothing.
Old Jan 19, 2007 | 03:57 PM
EZ-BAKED's Avatar
are the ballest tutching the frame or grounded in any way? you dont want the metal ballest touching any metal on the car mit blow a fuse and wont work proper
Old Jan 19, 2007 | 04:12 PM
ayS's Avatar
ayS
the unit is not grounded i believe.. i'm not sure if it's touching. if it is? what am i suppose to do?
Old Jan 19, 2007 | 04:25 PM
EZ-BAKED's Avatar
i mounted my ballest on some nylon. i have the McCulloch 10000K H.I.D. wich has a metal ballest when it touched the frame it would eather turn on and not turn off or it would do nothing and some times just blew the fuse. after mounting on some nylon or somthin not metal it worked great. check your fuse to mite have blown it.
Old Jan 19, 2007 | 04:31 PM
ayS's Avatar
ayS
so maybe because the ballast are touching metal to metal. it could cause the hid to not run? i haven't mounted the ballast they are sitting on the metal frame. if i mount it to some velcro. against the frame will it be okay or do i have to find something non metal to mount it on? or just make sure it's not physically touching metal to metal?
do you have a pic of your setup?
Old Jan 19, 2007 | 04:36 PM
EZ-BAKED's Avatar
check your fuse and set the ballest on some cardboard or somthing like that and try turning it and see if it turns the lights on. DONT LET THE METAL BALLEST TOUCH THE FRAME. I would not recomend useing velcro. mounting the ballest seems to be the hardes thing in the hole upgrade. I think that fuse is under the hood by the battery
Old Jan 19, 2007 | 04:45 PM
ayS's Avatar
ayS
can i test the old lightbulb to test the fuse to make sure my fuse is not blown? i'll try putting it on some cardboard first thought to see if it works. what if i've already tried turning it on. having the ballast touch metal to metal? have i damaged anything?
Old Jan 19, 2007 | 04:58 PM
EZ-BAKED's Avatar
yes you could do that to test the fuse. if metal to metal i think all you could have done was blow the fuse
Old Jan 19, 2007 | 05:22 PM
ayS's Avatar
ayS
also the rubber piece that comes off the old light bulb from the stock unit. am i able to put that back on? or that piece is no longer used?
Old Jan 19, 2007 | 05:30 PM
EZ-BAKED's Avatar
I used it. are the hids workin?
Old Jan 19, 2007 | 05:40 PM
ayS's Avatar
ayS
i'm actually at work at the moment. but when i get a chance. im going to go outside and try! i wll let you know.
dugzilla's Avatar
EZ-BAKED, you got a bad ballast. I have mine mounted directly on metal with no problems.
ayS how did you wire them in? are you running the power off the wiring harness or through a relay?
Old Jan 19, 2007 | 05:43 PM
web's Avatar
web
Um, ballasts can touch metal. They don't short the system out. If you look at some kits (like mine), they have metal bracket they slide into and then mount where ever. I have mine mounted right behind my steel front bumper re-enforcement and never had a problem. Make sure you have the ground hooked up and the power lead connected. Other than that, unless you never connected your stock harness to the new one, you should be good to go.
Old Jan 19, 2007 | 05:45 PM
ayS's Avatar
ayS
i believe mine is currently coming from a realay? but i'm getting a wiring harness. or vice versa. what clifford is selling. basically, im just following the plug and play for right now.
Old Jan 19, 2007 | 05:46 PM
hotbox05's Avatar
i double stickied them to the radiator support.
Old Jan 19, 2007 | 05:52 PM
dugzilla's Avatar
the set that clifford is selling comes with a wiring harness with a relay.
basically what you need to do is run the power and ground wires to the battery, then the stock wiring plug on the drivers side plugs into the hid kit. That is what tells the ballast to turn on.
hope that helps.
by the way I bought 2 kits from clifford and they work great!
Old Jan 19, 2007 | 05:53 PM
web's Avatar
web
^^looks good
Old Jan 19, 2007 | 05:54 PM
dugzilla's Avatar
yeah I glued one of the fog ballasts to the windshield washer bottle.
Old Jan 19, 2007 | 11:31 PM
ayS's Avatar
ayS
hi beams work, my HID's do not. what could be the problem?
Old Jan 20, 2007 | 12:05 AM
dugzilla's Avatar
your high beams get power from the oem harness, you are not getting power to the ballasts. You either don't have the harness wired correctly or a connection between the oem harness or to the hids is wrong.
I can't believe you are having such a hard time. once I mounted the ballasts it took like 5 minutes to plug everything else in.
Did you look at the installation write up that cliff posted?
