Help Multiple Engine CEL codes, O2 sensor, Misfires, MMW
Old Jan 20, 2007 | 09:03 PM
articis's Avatar
Default Help Multiple Engine CEL codes, O2 sensor, Misfires, MMW
I Installed the Monster Motor Werks Header on my car and have a cel thrown. The first time I installed the header I had no problems but when I took it off to send it to Jet-Hot and put it back on there was a cel light. I went to autozone to check it out and here are the codes It came up with the OBII thing.
P0031 (oxygen sensor 1, in bank 1, low voltage)
P0300 (PCM determined that multiple random misfires have occurred)
P0301 (PCM determined that multiple random misfires have occurred in Cylinder #1)
P0303 (PCM determined that multiple random misfires have occurred in Cylinder #3)
P0304 (PCM determined that multiple random misfires have occurred in Cylinder #4)
I disconnected the battery but comes back on.
I think the misfires are stored codes or something and maybe I messed up the upper O2 sensor. But does this mean I need a new one or is it something else. Where can I get a oem sensor or better?
Is this one good enough?
http://cgi.ebay.com/ebaymotors/Oxyge...spagenameZWD1V
Old Jan 21, 2007 | 05:04 AM
sddykstr's Avatar
Go with oem, you can get it from the dealer. You probably effed up an 02 which is causing it to run lean or rich, thus causing the misfires. Replace 02 sensor 1 and that should solve your problems, you also need an antifouler for your header's 02 sensor which I would buy before going with a new sensor. They can be found cheap on ebay. Good luck.
Old Jan 21, 2007 | 05:14 AM
articis's Avatar
so I also need an antifouler on the upper sensor? The bottom one has the mmw angled piece.
Old Jan 21, 2007 | 05:19 AM
sddykstr's Avatar
AFIK, but someone else help me out here...
Old Jan 21, 2007 | 05:49 AM
KINGxOFxSKA's Avatar
Unique Scionikz
You only need the anti-fouler on the s-pipe, not the header.
Old Jan 21, 2007 | 08:04 AM
darkalice's Avatar
don't monster mw header comes with their anti fouler for free?
Old Jan 21, 2007 | 08:05 AM
thespottedcow's Avatar
www.autotube.net has the antifouler for like $10.
Old Jan 21, 2007 | 08:51 AM
TheQuietThings's Avatar
look at the first code
its telling you the O2 sensor is broken
time to order one from the dealer
Old Jan 22, 2007 | 04:25 PM
articis's Avatar
well thanks guys, i guess ill get the new O2 sensor 4 wire one and try that.
Old Feb 1, 2007 | 02:31 AM
blackheart's Avatar
how much does that O2 cost?
Old Feb 1, 2007 | 03:35 AM
exige's Avatar
i have the mmw headers and s-pipe......if i have a high voltage code for sensor #2...but it only comes on once a month, and only in the winter in the cold, and only when im going at least 70 mph....the sensor's just acting up, its not actually broken is it??
Old Feb 1, 2007 | 05:05 AM
sddykstr's Avatar
Might be... If it is acting up, that leads to it failing...
Old Feb 1, 2007 | 05:12 AM
exige's Avatar
damn...anyone else got an opinion before i throw in the towel?
Old Feb 5, 2007 | 11:30 PM
articis's Avatar
Default Update
Ok I got an OBD2 code reader now.
I also installed the new O2 sensor. Here are the new codes thrown... Please help me
P103 Mass or volume air flow circuit high input (this one is new to me)
P2239 O2 sensor positive current control circuit high bank 1 sensor 1
P2252 O2 sensor positive current control circuit low bank 1 sensor 1
I followed the directions on the new O2 sensor but dont know if maybe i got the 2 black wires mixed up or something, theres no way to tell.
Old Feb 6, 2007 | 12:34 AM
sddykstr's Avatar
P103 is your MAF on the intake I believe. Donno jack about the other problems.
Old Feb 6, 2007 | 05:40 AM
articis's Avatar
Yea I think thats what it is but does anyone know what might be my problem?
Old Feb 6, 2007 | 06:03 AM
exige's Avatar
ive had that one....your maf is gone dude....i dono what you did but for mine, i accidentally nicked my injen cai with the wrench i was using to disconnect the positive battery cable. my car immediately went into limp home mode....is yours doing tha tyet?
Old Feb 6, 2007 | 08:22 AM
articis's Avatar
Well I never hit anything around the intake to damage it. I ran the obd2 a couple of times without that code thrown. then I didnt drive my car for like 3 days and now it is there. What do you mean by limp home mode? The car seems to be running normal as usual.
Oh and the O2 sensor was 34.48 shipped off of ebay.
Old Feb 6, 2007 | 12:15 PM
exige's Avatar
limp home mode=car wont go above like 3k rpms or itll stall
Old Feb 6, 2007 | 12:44 PM
blackheart's Avatar
which O2 did you get off e-bay and how is it working for you so far ?
