HELP!!! Alarm is Setting Off HID's
Old Jan 26, 2007 | 12:22 AM
Dakine's Avatar
Concept in Motion Crew
Default HELP!!! Alarm is Setting Off HID's
Hey guys i recently did a retrofit and a couple of hours ago, i notice that when my alarm goes off, my HID low beams and the ones that light up. anyway i can reroute the alarm so that it lights up the high beams instead?
Old Jan 26, 2007 | 12:31 AM
BeetC's Avatar
1UP Crew
what kind of alarm do you have, the OE Toyota alarm?
Old Jan 26, 2007 | 12:32 AM
Dakine's Avatar
Yeah OEM Scion that comes as an option.
Old Jan 26, 2007 | 01:16 AM
Daskid's Avatar
Do you really want to make the hi beams light up?
Old Jan 26, 2007 | 01:20 AM
Dakine's Avatar
Wouldnt it be better to light up the highs than the HID's?
Old Jan 26, 2007 | 01:22 AM
stCx86's Avatar
Default alarm
you're afraid that your HIDs will get damaged because it keeps flickering on and off huh??
Old Jan 26, 2007 | 01:25 AM
Golden86's Avatar
Why not just make the parking lights flash instead? Im sure its pretty simple wiring, because the Scion Security isn't technicly factory, its installed at the dealer. You should just be able to snip a wire and re route it to another wire.
Old Jan 26, 2007 | 01:29 AM
_NeXuS_'s Avatar
I have my aftermarket alarm set to light up just the parking lights. You might want to do that instead of the hi beams
Old Jan 26, 2007 | 01:34 AM
Dakine's Avatar
well im retrofitted, so i have no parking lights. The only parkings lights i'll be having soon will be ccfl's. But how would i rewire them?
Old Jan 26, 2007 | 02:00 AM
Yanki01's Avatar
mMmMmM, not too sure but do it soon or dont set your alarm cause you dont want to hurt your ballast?
Old Jan 26, 2007 | 02:21 AM
_NeXuS_'s Avatar
Yeah HID's arent meant to be turned on and off because of warmup lol,
Old Jan 26, 2007 | 05:34 AM
Dakine's Avatar
any techs on how to rewire?
Old Jan 26, 2007 | 12:08 PM
phoenixtc's Avatar
I had the same prob. Took it to the dealer and they just pulled a wire so only my parking lights flash. Do it soon so your ballast does not get damaged.
Old Jan 26, 2007 | 05:22 PM
Daskid's Avatar
Try to trace the scion security module. Then find the wire from the module that originally makes the parking lights light up. Search around for the wire color coding. Then disconnect them from your low beams. Pull that out and tap them together with you hi beams. I think that'll fix it. Easy to say, but I think you need time and patience to do it.
Old Jan 26, 2007 | 05:32 PM
Dakine's Avatar
pheonixtc, did u have to pay for that service?
Old Jan 26, 2007 | 08:21 PM
phoenixtc's Avatar
Nope, took him all of two minutes.
lsjimenez
Apr 3, 2015 01:32 PM
idriveanxa
Mar 8, 2015 12:03 PM
toyotaisme
Jan 10, 2015 10:24 PM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
